What is the difference between kW and kVA
النتائج 1 إلى 10 من 26
    eng ali elec.
    eng ali elec. غير متواجد حالياً
    الأخوة والأخوات الكرام ،كثير منا يتسأل عن الفرق بين الوحدات الكهربائية ومن بين هذه الوحدات المستخدمة لقياس القدرة الكهربائية هي الواط والكي في اي Watt ,kVA لذلك احببت أن اطرح هذا الموضوع ليتسنى للجميع الاستفادة منه.
    [What is the difference between kW and kVA?
    Answer : There are 3 types of electrical:
    Real Power, measured in Watts (W). This is the power drawn by a resistive load, e.g. a heater element in a kettle, and has a power factor of 1. (unity power factor, cos F=1, 1.0pf or pf=1)
    Reactive Power, measured in Volt Amperes reactive (VAr’s). This is the power drawn by a reactive load (a load with a winding around a core), e.g. an electro-magnet, and has a power factor of 0. (zero power factor, cos F =0, 0pf or pf=0)
    Apparent Power, measured in Volt Amperes (VA). Many loads have a combination of resistive and reactive elements. (in fact it is not possible to produce a purely inductive load, since the wire used to form the windings has a resistance). This combination of elements means that both real power (W) and reactive power (VAr) are drawn together.
    The proportion of Real Power to Reactive Power is defined as the power factor. [Nearly all resistive load (e.g. Universal motor used in hand tools) then power factor 0.95 to 1.0, nearly all inductive load then power factor ~ 0.3]
    The vast majority of single-phase loads have power factors approaching 1. Therefore, single-phase generator power ratings are taken at power factor =1, and are consequently in Watts (W) or kilo Watts (kW), where 1 kW = 1000 W.
    Three-phase loads tend to have lower power factors, approaching 0.8, therefore, three phase generator power ratings are taken at power factor =0.8 and are in VA or kVA.
    There is obviously a relationship between real power, reactive power, apparent power and power factor….
    i) Apparent Power (VA) = Ö [(real power (W))2 + (reactive power (VAr))2]
    And
    ii) Power factor = Real Power (W)
    Apparent Power (VA)
    Therefore…
    Apparent Power (VA) x Power factor = Real power (W)
    If the Power factor =1, then all the Power is real, and
    Apparent Power (VA) = Real Power (W)
    (W = VA @ 1.0 pf)
    For a single-phase generator, the rating should be at 1.0 pf, in which case
    Watts = Volt Amperes.
    But, for a three-phase generator the rating is at 0.8pf.
    This is where confusion can arise!
    Example.
    A three-phase generator has a continuous rating of 5 kVA at 0.8 pf.
    Now, at this rated load, the Real power (kW) will be …
    Real Power (kW) = Apparent Power (kVA) x Power factor
    Real Power = 5 x 0.8 = 4kW
    This means that a generator producing 5kVA at 0.8pf is actually producing 4 kW of Real power, but it is also producing some reactive power.
    From i)…
    5000 VA = Ö [( 4000 W)2 + ( Reactive Power)2]
    Reactive Power = 3000 VAr’s
    It is this combination of 4kW of real power and 3kVAr’s of reactive power that has defined the limit for the generator rating.
    If the same generator was loaded with a resistive load only, then it may be capable of more than 4kW, however, there is no formula that can be used to find this limit from the 0.8pf rating. It can only be found through testing of each machine.
    Similarly, a single-phase generator rated at 4kW, cannot be expected to produce 5kVA at 0.8pf !!!![/LEFT][/LEFT]
    مع أطيب تحياتي وأنا بانتظار ردودكم
    أخوكم
    م.علي المياحي
    من مواضيع eng ali elec. :
    محمد قاعود
    محمد قاعود غير متواجد حالياً
    الصراحة انا عارف الفرق, و خفت اقرى الكلام ده اتلخبت :)
    التقني
    التقني غير متواجد حالياً
    يعطيك الف عافية على هالمعلومات ..
    شكرا لك
    م. محمد عبد الحميد
    م. محمد عبد الحميد غير متواجد حالياً
    الصورة الرمزية م. محمد عبد الحميد
    Received: 10
    No Difference
    No Difference
    Va=w
    Kw=kva
    The Difference Can Be When The Circuit Has Capacitance Or Inductance
    There U Can Find Difference
    But When U Have Capitance U Can Not Have Problem In Ur Circuit
    The Problem Will Be When U Have Inductace There U Will Have Over Charge In Ur Conductor
    To Correct That U Must Put Battery Of Condonsator
    Why
    That Is The Real Question
    محمد قاعود
    اقتباس المشاركة الأصلية كتبت بواسطة محمممد مشاهدة المشاركة
    No Difference
    Va=w
    Kw=kva
    Why
    ايه يا بنى اللى بتقوله ده؟؟ غلط طبعا
    مبدئيا الW=VA فى حالة التيار المستمر فقط, اما فى دوائر الAC يختلف النظام, حيث لا يوجد عمليا دائرة AC Pure resisitive , لازم يكون هناك Inuctdance and capacitance
    و من هنا يظهر الباور فاكتور و لا يكون VA=W
    و بعدين مين قال لك ان ما فيش مشاكل من الCapacitance
    ما هو الباور فاكتور بيقل بردو مع زيادة الCapacitance ?
    و بعدين بتقول السؤال الحقيقى ليه بنحط بنك مكثفات؟؟ طيب علشان الCapacitance تعادل الInductance حيث يتم زيادة الباور فاكتور الى 0.9 او اكثر. و يمكنك فهم هذا اذا رأيت مثلث القوى, ستجد ان الباور فاكتور يزيد مع زيادة الCapacitance , بس طبعا ليه حسابات مش اى مكثفات و خلاص
    م. محمد عبد الحميد
    Received: 10
    شكرا اخي علئ الرد الوافي و الشافي
    ومعلوم ان للinductanceوالcapitanceشان كبير
    و بالخصوص في عالم الالكترونيك
    محمد قاعود
    [QUOTE=محمممد;454461]شكرا اخي علئ الرد الوافي و الشافي
    و بالخصوص في عالم الالكترونيك[/QUOTE
    لا شكر على واجب الله يكرمك.
    ENG_ASHRAF
    ENG_ASHRAF غير متواجد حالياً
    Received: 16
    جزاكم الله خيرا على المعلومات القيمة
    eng ali elec.
    الاخوة والاخوات كافة
    اطلب منكم تقيم الموضوع لكي يتسنى لنا طرح المزيد من المواضيع المفيدة في المستقبل
    شكرا لكم جميعا .
    اخوكم
    م . علي المياحي
    م.أبو أديب
    م.أبو أديب غير متواجد حالياً
    الحقيقه ليس هناك فرق جوهري بين قياس القدره بالوات والفولت امبير
    ولكن اصطلاحا اذا قرأت القدره مكتوبه بالوات فاعلم ان المقصود بها القدره الحقيقيه واذا قرأتها بالوات امبير فاعلم انها القدره الفعاله
    وهذه المعادله تحقق لك المزيد من القهم للمعنى
    real power = active power + reactive power
    ودائما ال reactive power يكون اصغر قيمه في هذه المعادله
    تحياتي
    [RAMS]http://www.da3y.org/index.php?cat=06&act=01&id=87[/RAMS]
