أطلب اي بحث أو موقع بحثي
صفحة 22 من 57 الأولىالأولى ... 1218 19 20 21 2223 24 25 26 32 ... الأخيرةالأخيرة
النتائج 211 إلى 220 من 565
  1. [211]
    صبرى ابوعجيلة
    صبرى ابوعجيلة غير متواجد حالياً
    ارغب فى الحصول على اوراق بحثية فى مجال السيراميك
  2. [212]
    rmz3003
    rmz3003 غير متواجد حالياً
    الرجاء المساعدة ( مشروع التخرج )
    ارجو ان تساعدوني في مشروع التخرج بالله عليكم هذا اول طلب لي في المنتدى ساعدوني بليييييز
    Your company has recently acquired the production rights to a natural gas field. The upstream production facility is in
    the final stages of design and construction will begin soon. The design specification of the upstream facility has shown
    that the treated NG will have the following composition:
    Name Formula Volume (%)
    Methane CH4 85.0
    Ethane C2H6 8.0
    Propane C3H8 2.0
    Carbon dioxide CO2 1.5
    Nitrogen N2 2.5
    Helium He 1.0
    Exploration analysis data showed that our upstream facility will have a production rate of 450 Million SCF/DAY.
    Due to the remote location of this resource, a decision by the upper management has been made to investigate the
    construction of a complex to convert the NG gas into other products. Initial investigation by our senior engineering team
    proposed a possible block diagram for the complex as shown in Fig 1. A number of engineering teams are formed to
    study the design and the economic feasibility of this large scale petrochemical complex. Your team is assigned to the
    design and economic analysis of two sub
    plants of this facility: the syn gas plant and the methanol to olefins plant
    (MTO). Your project team shall deliver the following:
    1. A preliminary design of the two plants, including estimates of all required utilities and costs (at least one
    favorable flowsheet should be developed for each plant).
    2. Economic feasibility studies for the plants.
    Other Design Data and Information:
    1. Syn Gas Plant:
    All produced NG will be processed through this plant
    Design the syn gas plant to meet the syn gas product ratio (H2/CO) required for the methanol plant (ignore
    any requirement for the ammonia and GTL plants at this stage)
    Only 35% of the Syn gas products are processed through the MeOH Plant
    2. MTO Plant:
    Desired products are C2 and C3 olefins
    It is unclear that the production of olefins should go through an MeOH synthesis step, other routes must be
    considered as they have considerable savings in capital investment
    If you decide that MeOH plant is needed, base your calculation on 5200 Mt/Day MeOH feed to the MTO plant
    without designing the MeOH Plant
  3. [213]
    engjasy
    engjasy غير متواجد حالياً
    اريد مساعدة في موضوع
    effect of paper pulp slurry on the rate of corrosion
  4. [214]
    المعلمي
    المعلمي غير متواجد حالياً
    السلام عليكم اختي
    بس بغيت بحث يبين لي طريقة حساب ال Flooding and Loading in packed tower
  5. [215]
    sel
    sel غير متواجد حالياً
    [QUOTE=normalization;453815]جزء ASTM الخاص بالمياة من يريدة هو
    http://rapidshare.com/files/8335639/...r__I_.rar.html
    http://rapidshare.com/files/8335643/...__II_.rar.html
    اما ااخ م / حسن سوف ارسلة لك عي ال******[/QUOT
    عفوا الرابط لا يعمل
  6. [216]
    desalination
    desalination غير متواجد حالياً
    تكفى لاهنت يا normalization أبي هالبحث وهذا عنوانه
    http://www.sciencedirect.com/science...9d770795e9f6bf
  7. [217]
    مهندس سامر
    مهندس سامر غير متواجد حالياً
    اخي العزيز احتاج بحث عن التاكل corrosion ياريت تساعدني و*****ي هو samir.mech***********
  8. [218]
    رمرر
    رمرر غير متواجد حالياً
    احتاج بحث عن
    Carbon Dioxide Fire Suppression Systems
  9. [219]
    white hand
    white hand غير متواجد حالياً
    pickling
    السلام عليكم ,ارجو تزويدى باى كتب عن البكلنج و الفلكسنج و وحدة pre treatment قبل الجلفنة وك\لك عملية الجلفنة بالزنك . لو سمحت اعتبر الموضوع هام جدا ولكم جزيل الشكر
  10. [220]
    الكيميائي007
    الكيميائي007 غير متواجد حالياً
    water treatment economics
