عاجل جدا.. shutdown script
النتائج 1 إلى 4 من 4
    user1396
    user1396 غير متواجد حالياً
    أحتاج لـ shutdown script لـ Windows 2000 Server
    بحثت في موقع Microsoft لكن للأسف لم أستطع إيجاد الملف لتحميلة .. أرجوا المساعدة
    م.رائد الجمّال
    الصورة الرمزية م.رائد الجمّال
    Received: 15
    How to Assign Computer Shutdown Scripts
    loadTOCNode(2, 'summary');1.Open the Group Policy snap-in.2.In the console tree, go the following location:Policy_name Policy/Computer Configuration/Windows Settings/Scripts (Startup/Shutdown)
    3.Click Scripts, and then double-click Shutdown in the right pane. 4.Click Add.5.Configure any of the following settings that you want to use, and then click OK: •Script Name: Type the path to the script or click Browse to locate the script file. By default, the Shutdown script is located in the following location on the domain controller:%SystemRoot%\SYSVOL\sysvol\<DOMAIN>\Pol icies\<GUID>\MACHINE\Scripts\Shutdown
    Script Parameters: Type any parameters that you want to use in the same way that you type them on the command line. For example, if the script includes the //logo parameter (display banner) and the //i parameter (interactive mode) parameters, type the following text://logo //i
    6.In the Shutdown dialog box, configure any of the following settings that you want to use: •Shutdown Scripts for: This box lists all of the scripts that are currently assigned to the selected Group Policy object. If you assign multiple scripts, the scripts are processed according to the order that you specify. To move a script in the list, click the script, and then click either Up or Down.•Add: Click Add to specify any additional scripts that you want to use.•Edit: Click Edit to modify script information such as the name and parameters.•Remove: Click Remove to remove the selected script from the Shutdown Scripts list.•Show Files: Click Show Files to view the script files stored in the selected Group Policy object.NOTE: Shutdown scripts are run on the Local System account.
    http://support.microsoft.com/kb/322241
    [SIGPIC][/SIGPIC]
    اعقل الناس اعذر الناس للناس
    user1396
    مشكور استاذي .. ولكن لو بعض الشرح العربي .. إن أمكن
    wd bob
    wd bob غير متواجد حالياً
    thak you man
