اسطوانة طيارة فى الصيانة
النتائج 1 إلى 7 من 7
    hithams2004
    hithams2004 غير متواجد حالياً
    هذه الاسطوانة تعمل الاتى :-
    ERD Commander 2003 repairs dead Windows
    NT4/2000/XP/Server 2003 systems
    ERD Commander 2003 can recover deleted files,
    change administrator passwords, edit
    the dead system’s registry, enable or
    disable services and drivers, and
    much, much more. It includes tools
    that make it easy to move data or
    entire volumes off the system over the
    network, view detailed information on
    the system’s OS and services packs,
    and compare files, services, and drivers
    with a functioning system. ERD
    Commander 2003 even makes the
    powerful Windows XP System Restore
    feature available to dead systems so
    you can roll them back to a previous
    working state. With ERD Commander
    2003, you can repair systems that
    would otherwise be unrecoverable.
    And by repairing dead systems –
    rather than reinstalling – you’ll avoid
    hours of repetitive work and lost productivity.
    With ERD Commander 2003,
    you can repair DEAD SYSTEMS
    using the following tools:
    Locksmith: Change Administrator
    or other passwords
    RegEdit: Import and export
    registry files
    Disk Commander: Repair damaged
    partition tables and retrieve data
    from corrupted or deleted volumes
    (only in Administrator’s Pak)
    Service and Driver Manager: Enable
    or disable services and
    drivers
    FileRestore: Quickly find and
    File Explorer: Copy and move files
    Disk Management: Partition disks
    and create or format volumes
    System Compare: Compare the
    files/services/drivers of an
    unbootable system and a
    functioning system
    System Restore: Rollback Windows
    XP systems to a working state
    Console: Run batch files or CHKDSK
    from a command prompt
    Notepad: Edit/create text-based
    files such as INI files
    File Sharing: Copy files to or from
    a dead system via the network
    Search: Quickly locate files
    and folders
    hithams2004
    الرابط
    انا الان برفع فى الاسطوانة فى الربت شير
    hithams2004
    م.عمرو عوض
    م.عمرو عوض غير متواجد حالياً
    جاري التحميل ومشكور علي المشاركة
    محبة الله ورسوله*
    Received: 30
    Given: 13
    مشكووووووووووور
    وربنا يعطيكـ العافية
    متغيبه عن الملتقي دعواتكم
    ريمون عدلي
    ريمون عدلي غير متواجد حالياً
    الصورة الرمزية ريمون عدلي
    شكرا علي هذه الاسطوانه
    ولكن هل ممكن الاسطوانه دي تعالج تعليق الكمبيوتر
    ع الغزالي
    ع الغزالي غير متواجد حالياً
    عضو متميز جداً
    الصورة الرمزية ع الغزالي
    متشكرين اوي ياعم
