تطلب شركة المحمول الجديدة اتصالات مصر الوظائف التالية فى الهندسة
النتائج 1 إلى 3 من 3
    محمد سمير وحيد
    محمد سمير وحيد غير متواجد حالياً
    برجاء ارسال هذه الرسالة لكل من تعرف
    التقديم يتم عبر الانترنت فقط وليس عن طريق ارسال بريد الكترونى
    اضغط على الوظيفة المطلوبة للتقديم وتأكد من ادخال الكود الموضح فى كل وظيفة
    DT& Configuration Senior Team Leader
    NSS Support Test Senior Team Leader
    Customer Support and Perfection Senior Team Leader
    International Gateway Senior Team Leader
    DT& Configuration Team Leader
    NSS Support Test Team Leader
    Customer Support and Perfection Team Leader
    International Gateway Team Leader
    DT& Configuration Senior Engineer
    NSS Support Test Senior Engineer
    Customer Support and Perfection Senior Engineer
    International Gateway Senior Engineer
    DT& Configuration Engineer
    NSS Support Test Engineer
    Customer Support and Perfection Engineer
    International Gateway Engineer
    Server Management Senior Team Leader
    Transmission Operations Senior Team leader
    Network Database Management Senior Team leader
    Server Management Team Leader
    Network Datbase Management Team Leader
    Transmission Operations Team Leader
    Network Operations Team Leader
    Server Management Senior Engineer
    Network Performance Senior Engineer
    Transmission Operations Senior Engineer
    Network Datbase Management Senior Engineer
    Server Management Engineer
    Network Performance Engineer
    Transmission Operations Engineer
    Network Datbase Management Engineer
    Network Operations Engineer
    Access Suport-BSS Team leader
    Access Suport-3G Team leader
    Access Suport-Transmission
    Team leader
    Access Suport-CME
    Team leader
    Access Suport-BSS
    Senior Engineer
    Access Suport-3G
    Senior Engineer
    Access Support- Transmission Senior Engineer
    Access Support- CME
    Senior Engineer
    Access Support- BSS Engineer
    Access Support- 3GE Engineer
    Access Support- Transmission Engineer
    Access Support- CME Engineer
    Radio Planning Team Leader
    Radio Optimization Team Leader
    Radio Planning Senior Engineer
    Radio Optimization Senior Engineer
    Radio Planning Engineer
    Radio Optimization Engineer
    http://www.zcorner.com/
    engineer_id
    engineer_id غير متواجد حالياً
    Thank You Very Much
    mohamed abouzahra
    mohamed abouzahra غير متواجد حالياً
    الصورة الرمزية mohamed abouzahra
    مشكوررررررررررررررر
