برنامج ... Calculator of Area,Centroid & Inertia of Polygons-Freeware ... للمهندسيين
النتائج 1 إلى 10 من 10
    Mu7ammad
    Mu7ammad غير متواجد حالياً
    Received: 8
    Calculator of Area, Centroid and Inertia of Polygons (Freeware)
    Windows OS | Size: 2.00 Mb
    Software that calculates cross sectional properties. The results obtained from Section can be used in a structural analysis. Section allows the user to create custom cross sections graphically using rectangular elements. Area, location of centroid, and moments of inertia (including principal moments of inertia) are automatically calculated. Original, centroidal,and principal axes can be toggled on and off. A grid is also available to aid in construction of the cross section.
    This engineering calculator computes geometric properties (area, centroid, moment of inertia, etc.) of any polygon in XY plane (Polygonal section).
    The following properties are calculated:
    About XY axis:
    • Area
    • Centroid (x,y) coordinates
    • Moment of Inertia about X-axis (Ixx)
    • Moment of inertia about Y-axis (Iyy)
    • Product of Inertia (Pxy)
    • Polar Moment of Inertia (Jo)
    • Radius of gyration about x-axis (Kx)
    • Radius of gyration about y-axis (Ky)
    • First Moment of Area about X-axis (Mx)
    • First Moment of Area about Y-axis (My)
    About X'Y' axis (centroid axis):
    • Moment of Inertia about translated X'-axis (I'xx)
    • Moment of Inertia about translated Y'-axis (I'yy)
    • Product of Inertia about translated axis (P'xy)
    • Polar Moment of Inertia about translated axis (Jo)
    • Radius of gyration about translated X'-axis (Kx')
    • Radius of gyration about translated Y'-axis (Ky')
    And also:
    • You can graph any section perimeter
    • User-friendly interface
    • Incredibly fast calculations
    • Accepts any imaginable section defined using lines (polygon) Graphical display of centroid location
    • Graphical display of centroid location
    • Freeware !!!
    Works on M'zoft Windows XP. You will need .Net Framework 2 installed before.
    DownLoad
    Original Site
    .... والله ولى التوفيق ...
    جلال ثابت الأغبري
    جلال ثابت الأغبري غير متواجد حالياً
    الصورة الرمزية جلال ثابت الأغبري
    Received: 9
    ألأخ محمد .... الله يعينك بعونه ويحيطك برعايته والسلام ختام
    mrniceguy2932000
    mrniceguy2932000 غير متواجد حالياً
    الف شكر اخي الكريم
    الموسوعي
    الموسوعي غير متواجد حالياً
    أحسنت،، برنامج رائع!
    تحياتي
    المهندس2000
    المهندس2000 غير متواجد حالياً
    شكراً لك و جزاك الله كل الخير ...........................
    المهندس هاني السميري
    المهندس هاني السميري غير متواجد حالياً
    بارك الله فيك
    ehabebo84
    ehabebo84 غير متواجد حالياً
    بارك الله فيك
    ibrahim1hj
    ibrahim1hj غير متواجد حالياً
    الصورة الرمزية ibrahim1hj
    Received: 19
    Given: 4
    thank you mu7ammad and i hope you always give us more and usefull , this is a usefull software and i need it , thanks alot.
    bye - eng ibrahim
    Asem Hamed
    Asem Hamed غير متواجد حالياً
    بارك الله فيك أخي الفاضل
    AHMADHALAB
    AHMADHALAB غير متواجد حالياً
    جـــــــــــــــــزاك الله خـيــــــــــرا
