برنامج ... Sigma Plot 10.0-Scientific Graphing Software ... للمهندسيين
النتائج 1 إلى 10 من 15
    Mu7ammad
    Mu7ammad غير متواجد حالياً
    Received: 8
    Windows OS | Size: 28.30 Mb
    SigmaPlot software helps you quickly create exact graphs
    SigmaPlot graphing software from SYSTAT takes you beyond simple spreadsheets to help you show off your work clearly and precisely. With SigmaPlot, you can produce high-quality graphs without spending hours in front of a computer. SigmaPlot offers seamless M'zoft Office integration, so you can easily access data from M'zoft Excel spreadsheets and present your results in M'zoft PowerPoint� presentations.
    Graphing software that makes data visualization easy
    Graph creation starts with SigmaPlot's award-winning interface. Take advantage of industry-standard menu design, menu toolbars, right mouse button support and graph preferences. Select the graph type you want to create from the Graph Toolbar's easy-to-read icons. The interactive Graph Wizard leads you through every step of graph creation. You get compelling, publication-quality charts and graphs in no time. SigmaPlot offers more options for charting, modeling and graphing your technical data than any other graphics software package.
    Compare and contrast trends in your data by creating multiple axes per graph, multiple graphs per page and multiple pages per worksheet. Accurately arrange multiple graphs on a page using built-in templates or your own page layouts with SigmaPlot's WYSIWYG page layout and zoom features.
    More than 80 2-D and 3-D technical graph types
    From simple 2-D scatter plots to compelling contour plots, SigmaPlot gives you the exact technical graph type you need for your demanding research. And, to help you see interactions in your 3-D data, SigmaPlot powerfully renders multiple intersecting 3-D meshes with hidden line removal. With so many different chart and graph types to choose from, you can always find the best visual representation of your data.
    Customize every detail of your charts and graphs
    SigmaPlot offers the flexibility to customize every detail of your graph. You can add axis breaks, standard or asymmetric error bars and symbols; change colors, fonts, line thickness and more. Double-click on any graph element to launch the Graph Properties dialog box. Modify your graph, chart or diagram further by pasting an equation, symbol, map, picture, illustration or other image into your presentation. [/center]
    SigmaPlot 10 new features
    New General Features
    The New Startup Screen lets both new and power users quickly jump into their workflow with easy access to recently used documents, use existing documents as templates for new work, or fast import of Excel and Access documents.
    The Submission Assistant will save users time from having to research publication graph requirements, and prevent editor bounce-back.
    More efficient integration with SAS and Minitab preventing duplicate copies of user data
    Get real-time feedback of the graph coordinates with your mouse cursor on a graph
    Laboraties can easily track and log changes to notebooks from multiple users, simplifying security and 21 CFR Part 11 compliance
    Other features include importing popular graphic files directly on to the Sigma Plot graph page, a new Installer and Network License Manager, and improved Graph Defaults
    New Graphing Features
    Visually differentiate groups within your data and achieve the desired graphical aesthetic with more Line Types and Fill Patterns
    New 3D Mesh Plots with Contour Projections enhance the visualization of three-dimensional data coordinate values
    Sigma Plot 10 automatically interpolates and graphs irregularly spaced three-dimensional data to quickly generate smooth and highly accurate mesh and contour plots from any 3D data sets
    Polar Plot angular direction support allows users customize the angular direction that best fits the conventions for their data
    New axis scales for two and three-dimensional graphs including Weibull axis scale, Reciprocal axis scales, and Arrhenius scales
    Easier manipulation of the graph elements even with object is buried under other items
    Quickly customize the size and position of multiple graphs and graph page objects
    New Data Analysis Features
    You can be confident that the best curve fit was found when using Sigma Plot's New Dynamic Fit Wizard
    It is now easy to add confidence and prediction bands to nonlinear regressions
    Optional Chi-Square Regression Weighting gives the flexibility to do curve fitting according to the statistical conventions of the user's research area
    Perform computations, run macros, and perform curve fitting with the twelve new probability functions
    Transforms can now be stored in Sigma Plot notebooks to tie them to a particular worksheet, password and audit log protect the transform, or build a custom transform library
    benadem
    benadem غير متواجد حالياً
    الصورة الرمزية benadem
    جـــــــــــزاك الله خـيـرا على البرنامج
    aalmasri
    aalmasri غير متواجد حالياً
    عضو تحرير المجلة
    الصورة الرمزية aalmasri
    Received: 10
    بارك الله فيك مشرفنا العزيز
    eng_s_elbehery
    eng_s_elbehery غير متواجد حالياً
    رابط الجزء الاول حذف من موقع الرفع برجاء رفع الملف مره أخرى
    تحياتى
    م/ سامى البحيرى
    HASAN13
    HASAN13 غير متواجد حالياً
    you can download from this link
    [http://www.4shared.com/network/searc...gma+Plot+10.0]
    with my regards
    abbas zubaidi
    abbas zubaidi غير متواجد حالياً
    بارك الله فيك وجزاك الله خير الجزاء
    HASAN13
    اقتباس المشاركة الأصلية كتبت بواسطة abbas zubaidi مشاهدة المشاركة
    YOU WELCOME MY DEAR BROTHER
    عمر شيخ
    عمر شيخ غير متواجد حالياً
    Great effort ,,,downloading in progress
    thanks a million
    HASAN13
    اقتباس المشاركة الأصلية كتبت بواسطة عمر شيخ مشاهدة المشاركة
    thanks a million
    YOU WELCOME
    THIS FOR YOU
    http://www.4shared.com/file/26909313...aStat.html?s=1]
    AND THIS
    http://www.4shared.com/file/26667752...ve_3d.html?s=1
    MANY THANKS
    WITH MY REGARDS
    amn_hassan
    amn_hassan غير متواجد حالياً
    مشكور الأخ الكريم
    و جزاك الله عنا خيرا
