رسالة لا اعرف سببها
النتائج 1 إلى 10 من 11
    محبة الله ورسوله*
    Received: 30
    Given: 13
    رسالة لا اعرف سببها
    ظهرت رسالة على الجهاز بالذات عند الضغط على برنامج لغة C++
    وكذلك على برنامج لغة الprolog وتظهر بشكل مختلفة
    وهذا شكلها
    ومشكورين سلفاً
    من مواضيع محبة الله ورسوله* :
    متغيبه عن الملتقي دعواتكم
    م.رائد الجمّال
    الصورة الرمزية م.رائد الجمّال
    Received: 15
    Resolution Steps: Apparently this error message, or a similar one mentioning config.nt, can occur when one of the following files is missing or corrupt:
    * Autoexec.nt
    * Config.nt
    * Command.com
    The erorr can occur when installing or uninstalling a program.
    In my case Autoexec.nt was missing from the C:\WINNT\System32 directory. Looking in the C:\WINNT\Repair directory I found that Windows had automatically made a backup copy of Autoexec.nt, so I just copied this into C:\WINNT\System32 and the problem was fixed.
    Note: The C:\WINNT directory on my computer may be C:\WINDOWS on other systems. Substitute as necessary when following the above instructions.
    Note: If you can't find a copy of the missing file in your Repair directory, use your original Windows OS disk to get the missing files. At the command prompt type the following commands:
    expand e:\i386\config.nt_ c:\windows\system32\config.nt
    expand e:\i386\autoexec.nt_ c:\windows\system32\autoexec.nt
    expand e:\i386\command.co_ c:\windows\system32\command.com
    exit
    Substitute "e:\" for your CD-ROM driver letter, and "c:\windows" for where your OS is located.
    [SIGPIC][/SIGPIC]
    اعقل الناس اعذر الناس للناس
    م.رائد الجمّال
    Received: 15
    for more information about this error visit the link below , there 2 methods to solve it
    http://support.microsoft.com/kb/324767
    [SIGPIC][/SIGPIC]
    م.رائد الجمّال
    Received: 15
    sorry ayah
    but it late here , so i left the solution and a link u can read from them also here another link from Microsoft support
    http://support.microsoft.com/kb/250343
    read them and see what the best choice to do
    keep me in touch of what u did
    hope every thing be ok
    best regrades
    raed al jammal
    [SIGPIC][/SIGPIC]
    محبة الله ورسوله*
    Received: 30
    Given: 13
    اقتباس المشاركة الأصلية كتبت بواسطة م.رائد الجمّال مشاهدة المشاركة
    sorry ayah
    best regrades
    raed al jammal
    العفو أخي م/رائد
    وفعلا هذا هي ملفات مفقودة تم فقدانها أعتقد سبب فقدان هذه الملفات
    هو نتيجه لوجود فيروس بالجهاز وهو يدعي sys.exeأو NOOOH
    وقد عمل هذا الفيروس على أشياء عديدة منها تعطيل التاسك منجر والريجستري ...
    وهذه مشاركة لي في أحد المنتديات الاخري وكان حل أزاله الفيروس كالاتي:
    خطوات الحل
    دخلت على save mode بضغط على f8 باستمرار عند إعادة التشغيل
    ثم ذهب إلى جهاز الكمبيوتر ومن أدوات أخترت خيارات المجلد ومن ثم عرض
    وشلت علامة التشكـ من على أخفاء ملفات نظام التشغيل المحمية ( المستحسن)
    ثم تطبيق وموافق
    واروح إلى القرص الصلب C باضغط بالزر الايمن ثم فتح وامسح ملف يدعي Sys.exe وملف Outorun
    ومن ثم ادخل إلى مجلد ويندوز ومن ثم مجلد web واحذف نفس الملفات
    ثم اروح إلى باقي الاقراص لو كانت موجودة معاي
    بعدين أدخل من run واكتب فيها gpedit.msc راح يدخلي على القروب بوليسي من هناك أروح على تكوين المستخدم ومن ثم قوالب الادارة ثم نظام اروح إلى ادراة المهام باليمين ثم خصائص واختار معطل ثم موافق ومن نفس المكان اروح على prevent access to registry editing tools
    وتبع الريجستري واعمل معطل واخرج واعمل اعادة تشغيل وبعدين لله الحمد لا احصل فيروس ولاشيء
    واقدر أدخل غلى الريجستري والتاسك منجر و...
    من وجهة نظرك هل ترى ان هذا حل مناسب لأني اعتقد أن سبب تعطيل بعض المهام هو الفيروس
    أما حل فقدان الملفات سوف اطرح عليك الحل ولكن لم اقم بعمله إلى هذه الحظة
    قمت في البداية بعمل بحث عن هذه الثلاثة الملفات في جهاز خالي من أي فيروس
    ومن ثم أقوم بإضافة (نسخ) هذا الملفات إلى الجهاز المفتقد لها
    ولكن الملفات ليس موجود كما تفضلت في هذا المسار
    وجدتها في المسار التالي
    c:\windows\Repair
    وكل ذلك سوف اقوم به وانا بداخل savemode
    فهل هذه الخطوات مجديه
    وهل تعتقد ان هذه تكمل الموضوع نقاط التشغيل...
    وتقبل تحياتي وألف شكر
    م.رائد الجمّال
    Received: 15
    c:\windows\Repair
    ok ayah that will solve the problam id u copy it
    but i think u didnt read what i typed be4 cearfully . so read it again and u will see it the same
    so go ahead and so it
    best regardes
    raed aljammal
    [SIGPIC][/SIGPIC]
    محبة الله ورسوله*
    Received: 30
    Given: 13
    جربت الطريقة ونفعت
    والحمدلله
    وجزاكــ الله كل خير
    م.رائد الجمّال
    Received: 15
    اقتباس المشاركة الأصلية كتبت بواسطة آية أحمد مشاهدة المشاركة
    جربت الطريقة ونفعت
    والحمدلله
    وجزاكــ الله كل خير
    you are too welcome
    Allah bless u also
    [SIGPIC][/SIGPIC]
    رشدي15
    رشدي15 غير متواجد حالياً
    انا عندي نفس الفيروس Nooh
    انا عندي نفس المشكله بس نظامي WINDOS xp home edition الامر gpedit.msc لايعمل ارجوكم ايش الحل
    محبة الله ورسوله*
    Received: 30
    Given: 13
    اقتباس المشاركة الأصلية كتبت بواسطة رشدي15 مشاهدة المشاركة
    ممكن أخي تتبع الرابط التالي
    http://www.arab-eng.org/vb/showthread.php?t=54125
    وإذا لم ينفع حمل الملف المرفق
    واضغط على Enable all وبعدها راح يتفعل معاك الريجستري والتاسك منجر وخيارات المجلد
    واعمل اظهار للمجلدات المخفية وإذا على الاقراص تبعك وابدأ في حذف الفيروس
    وربنا يوفقكــ
