مصطلحات في الهندسة الصناعية
النتائج 1 إلى 6 من 6
    Shibani
    Shibani غير متواجد حالياً
    هذه بعض المصطلحات المهمة في الهندسة الصناعية، أرجو أن تزيد من تعميق الفائدة.
    Flow Process Analysis (FPA): Analyses a process into a sequence of process elements in the order in which they occur
    Flow Processing/Flow Production: An efficient method of converting raw material into finished product eliminating or minimising transportation, handling of parts and work in progress
    Lead Time Analysis: Activity to identify the elements of lead time to measure how long a customer has to wait before receiving a product
    Lead Time: The total time a customer, internal or external, must wait to receive a product after placing an order
    Lead Time Profiles: Activity to identify and quantify factors that determine how quickly a product reaches the next or end customer
    Lean Manufacturing: A business performance improvement tool that focuses on enhancing quality, cost, delivery and people. Exposes waste and makes continuous improvement possible
    Levelled Production: A means of evenly distributing both the quantity and variety of parts across a production period avoiding overburden and under-utilisation in the workplace
    Mistake/Error Proofing (Poke Yoke):Means for eliminating defects by making a process robust to mistakes (foolproof)
    Process Mapping: Method for depicting a process, material or information flow in a diagrammatic form. Defines key process input and outputs
    Pull System: A customer driven work replenishment system involving 'pulling' the exact quantity of parts required out of a finished parts stores. A Kanban issues the instruction to replenish the stock
    Push System: Description of the process involving manufacturers launching materials and components required to product goods according to a production plan
    Root Cause: The real cause or origin of a problem
    Sigma: A measure of variation from the mean which when applied to the business process represents the number of defects or failures likely to occur per million opportunities
    Single Minute Exchange of Dies (SMED) (Set Up Reduction): Method for reducing tool changeover times facilitating increased capacity, smaller batch sizes, lower inventory and reduced lead times
    Six Sigma: A 'measure of goodness' involving the application of statistical methods to business processes to improve operating efficiency, reduce variation, avoid defects and reduce waste
    Supply Chain Map: Diagrammatic identification of basic logistical and cost details in the supplier-customer procession
    Takt Time: Takt is the German word for 'beat' and represents the pace at which the customer requires the product. Takt time is the rate at which parts have to be produced to match the customer requirements
    Total Productive Maintenance: Activity that targets zero downtime of machinery/equipment, zero defects and zero accidents by the pro-active identification of potential problems
    Value Stream: A value stream is all the actions, (both value added and non-value added), that are required to bring a product through the main flows essential to nearly every product
    Value Stream Mapping: A pencil and paper improvement tool that provides an understanding of the flow of material and information as a product makes its way through the value stream
    Value Management: Process that establishes the most reliable performance which a product or process must do to make it work and sell at the least possible cost
    Workplace Organisation: Uncluttered and orderly management of the working environment
    Zero Defects: Manufacturing free from faults achieved by the elimination of errors in a product or process
    ferasgolf
    ferasgolf غير متواجد حالياً
    شكرا جزيلا لك على هذه المصطلحات الهمة
    وننتظر منك المزيد
    شكوت إلى وكيع سوء حفظي فارشدني إلى ترك المعاصي
    وقال بان العلم نور ونور الله لا يهدى لعاصي
    Shibani
    شكرا علي المرور وأن شء الله نضع المزيد
    bazokka
    bazokka غير متواجد حالياً
    نشكرك على هذه المصطلحات ونرجو المزيد طبعا ولكن عايزين نبقى محددين ونعرف الناس المصطلحات ديه معناها ايه بالعربى
    عبدالله الرشدان
    عبدالله الرشدان غير متواجد حالياً
    شكرا جزيلا على جهودك الطيبة
    صناعة المعمار
    صناعة المعمار غير متواجد حالياً
    Received: 8
    بارك الله بك اخي :)
    اللهم لك الحمد حمداً كثيراً ولك الشكر شكراً كثيرا ، حمداً كما ينبغي لجلال
    وجهك وعظيم سلطانك ،،،
    لك الحمد ما أكرمك
    ولك الحمد ما أرحمك
    ولك الحمد ما أعظمك
    اللهم أننا نشهدك أننا نشتاق إليك فلا تحرمنا من لذة القرب منك في الدنيا ولا
    لذة النظر إلى وجهك الكريم في الآخرة
