برنامج ... Portable Advanced Uninstaller PRO 8.1 ... للمهندسيين
النتائج 1 إلى 5 من 5
    Mu7ammad
    Mu7ammad غير متواجد حالياً
    Received: 8
    Windows OS | Size: 35.35 Mb
    احـــد البرامج المعروفة لحذف البرامج ومخلفاتها وملحقتاها بطريقة امنة من على جهازك ، والمميز فى هذه النسخة اماكنية الاستخدام بدون التحميل على الجهاز
    This easy-to-use Windows application uninstaller makes your computer run more efficiently by removing software and files that were left behind after you uninstalled software that you no longer use. In addition, the program performs a number of cleanup activities, making your computer more secure.
    Uninstalling a program is as easy as selecting its name from a list, or dragging and dropping a file or a shortcut on the Advanced Uninstaller PRO desktop icon.
    Advanced Uninstaller PRO's built-in Startup Manager gives you control over the programs that are automatically started by Windows, and offers you detailed information about each of them, including advice about what the program does and whether you should disable it. Advanced Uninstaller PRO includes a huge knowledge base containing startup program descriptions, giving you the ability to distinguish between essential Windows components that you want to keep, and dangerous spyware programs that you want to remove.
    To protect your privacy, the Quick Cleaner performs a one-step removal of the data on your computer that tells other people what you've been doing. It can safely delete the list of Internet pages that you have visited, the web addresses that you have typed, the Internet cookies that were written to your hard drive when you visited web sites, and the recently opened files lists for more than 100 applications, including Microsoft Office, Windows Media Player, ***, MSN, WinZip, RealPlayer, Kazaa, etc.
    Advanced Uninstaller PRO makes it easy to remove all damaged Start Menu shortcuts, to hide or show them at any time, and to alphabetically sort the entire Start Menu. The program can find and delete temporary files left behind by Windows, Internet Explorer, and other applications. You can also tweak Internet Explorer configuration settings, manage and uninstall fonts, uninstall unwanted Control Panel applets, and perform other system tasks efficiently.
    The latest release also contains a powerful Registry cleaner, defragmenter and optimizer which will help you keep your Registry fast, clean, and easily accessible by all programs. There is also a Registry backup utility that lets you easily back up and restore this important system file when it gets damaged or lost.
    DownLoad
    Or
    DownLoad
    .... والله ولى التوفيق ...
    مهند مجدى محمد
    مهند مجدى محمد غير متواجد حالياً
    شكرا جزيلا
    مع تحياتى
    ارجوك تقبل مرورى
    مروان96
    مروان96 غير متواجد حالياً
    Thank you very much
    saswawa
    saswawa غير متواجد حالياً
    Thank U Very Much
    mohamedmousad
    mohamedmousad غير متواجد حالياً
    الصورة الرمزية mohamedmousad
    شكرااااااااااااااااااااااااااااااااااااااااااااااا ااااااا
