Technical report about copper --Recycling of Copper
النتائج 1 إلى 3 من 3
    الصورة الرمزية alshangiti
    alshangiti
    alshangiti غير متواجد حالياً
    مشرف وإستشاري هندسة المناجم
    Received: 89
    Given: 8
    For thousands of years, copper and copper alloys have been recycled. This has been a normal economic practice, even if regretted by some. One of the wonders of the old world, the Colossus of Rhodes, a statue spanning the entrance to Rhodes Harbour, was said to have been made of copper. No trace of it remains since it was recycled to make useful artefacts.
    In the Middle Ages it was common that after a war the bronze cannons were melted down to make more useful items. In times of war even church bells were used to produce cannon.
    The entire economy of the copper and copper alloy industry is dependent on the economic recycling of any surplus products. There is a wide range of copper based materials made for a large variety of applications. To use the most suitable and cheapest feedstock for making components gives the most economic cost price for the material.
    Scrap Value - Copper
    The usual commercial supplies of pure copper are used for the most critical of electrical applications such as the production of fine and superfine enamelled wires. It is essential that purity is reproducibly maintained in order to ensure high conductivity, consistent annealability and freedom from breaks during rod production and subsequent wire drawing. Since the applied enamel layers are thin but have to withstand voltage, they must have no surface flaws; consequently the basis copper wire must have an excellent surface quality. Primary copper of the best grade is used for producing the rod for this work. Uncontaminated recycled process scrap and other scrap that has been electrolytically refined back to grade 'A' quality may also be used.
    The copper used for power cables is also drawn from high conductivity rod but to a thicker size than fine wires. The quality requirements are therefore slightly less stringent. The presence of any undesirable impurities can cause problems such as hot shortness which gives expensive failures during casting and hot rolling. For the same reason, scrap containing such impurities can only be used for this purpose if well diluted with good quality copper.
    For non-electrical purposes, copper is also used to make large quantities of plumbing tube, roofing sheet and heat exchangers. High electrical conductivity is not mandatory and other quality requirements are not so onerous. Secondary copper can be used for the manufacture of these materials, though still within stipulated quality limits for impurities.
    Where scrap copper is associated with other materials, for example after having been tinned or soldered, it will frequently be more economic to take advantage of such contamination than try to remove it by refining. Many specifications for gunmetals and bronzes require the presence of both tin and lead so this type of scrap is ideal feedstock. Normally it is remelted and cast to ingot of certified analysis before use in a foundry. Scrap of this type commands a lower price than uncontaminated copper.
    Scrap Value - Brasses
    The recycling of brass scrap is a basic essential of the economics of the industry. Brass for extrusion and hot stamping is normally made from a basic melt of scrap of similar composition adjusted by the addition of virgin copper or zinc as required to meet the specification before pouring. The use of brass scrap bought at a significantly lower price than the metal mixture price means that the cost of the fabricated brass is considerably less than it might otherwise be.
    The presence in brass of some other elements such as lead is often required to improve machinability so such scrap is frequently acceptable. Besides the common free-machining brasses, there are many others made for special purposes with properties modified to give extra strength, hardness, corrosion resistance or other attributes, so strict segregation of scrap is essential.
    Brass scrap arising from machining operations can be economically remelted but should be substantially free from excess lubricant, especially those including organic compounds that cause unacceptable fume during remelting.
    When brass is remelted, there is usually some evolution of the more volatile zinc. This is made up in the melt to bring it back within specification. The zinc is evolved as oxide that is drawn off and trapped in a baghouse and recycled for the manufacture of other products.
    Brass to be made in to sheet, strip or wire form must be significantly free of harmful impurities in order to retain ductility when cold. It can then be rolled, drawn, deep drawn, swaged, riveted, spun or otherwise cold formed. It is normal therefore to make it substantially from virgin copper and zinc, together with process scrap arising from processing that has been kept clean, carefully segregated and identified.
    Scrap Value - Other Copper Alloys
    Copper alloys such as phosphor bronzes, gunmetals, leaded bronzes and aluminium bronzes are normally made to closely controlled specifications in order to ensure fitness for demanding service. They are normally made from ingots of guaranteed composition together with process scrap of the same composition that has been kept carefully segregated. Where scrap has become mixed, or is of unknown composition, it is first remelted by an ingot maker and analysed so that the composition can be suitably adjusted to bring it within grade for an alloy.
    Good quality high conductivity copper can be recycled by simple melting and check analysis before casting, either to finished shape or for subsequent fabrication. However, this normally only applies to process scrap arising within a copper works. Where copper has been contaminated and it is required to re-refine it, it is normally remelted and cast to anode shape so that it can be electrolytically refined. If, however, the level of impurities in the cast anode is significant, it is unlikely that the cathode produced will then meet the very high standards required of grade 'A' copper used for the production of fine wires.
    Where copper and copper alloy scraps are very contaminated and unsuitable for simple remelting, they can be recycled by other means to recover the copper either as the metal or to give some of the many copper compounds essential for use in industry and agriculture. This is the usual practice for recovery of useable copper in slag, dross or mill scale arising from production processes or from life-expired assemblies of components containing useful quantities of copper.
    Environmental Considerations
    Copper is an essential trace element needed for the healthy development of most plants, animals and human beings. In general, moderate excess quantities of copper are not known to cause problems. Every care is taken to avoid wasting copper and it is recycled where possible. Excess copper is not allowed to escape into the atmosphere as fume, nor into discharged process cooling water, all of which is generally treated to keep within agreed limits.
    Other metals associated with copper alloys are generally not in a form that is dangerous. However, when fume is generated, for example by melting or welding, it may be necessary to use fume extraction equipment. Beryllium is sometimes used as an alloying element in copper to make some of the strongest copper alloys known, being invaluable for the production of heavy duty springs. When alloyed with copper and in the solid state this presents no health hazard. However, if present in the atmosphere, beryllium can cause a health hazard and should be controlled. CDA publication 104 gives advice on health and safety requirements for airborne fume associated with copper-beryllium.
    Product Value
    If the scrap is pure copper and has not been contaminated by anything undesirable, a high quality product can be made from it. Similarly, if scrap consists only of one alloy composition it is easier to remelt to a good quality product, although there may have to be some adjustment of composition on remelting.
    If scrap is mixed, contaminated or includes other materials such as solder then, when remelted, it will be more difficult to adjust the composition within the limits of a chosen specification. Where lead or tin have been included, but no harmful impurities, it is usually possible to adjust composition by the addition of more lead or tin to make leaded bronzes. For some scrap contaminated with undesirable impurities it is sometimes possible to dilute it when melting so that the impurity level comes within an acceptable specification. All these techniques retain much of the value of the scrap. The way in which alloys can be made from scrap is shown in simplified diagrammatic form in the figure. Where scrap has been contaminated beyond acceptable limits it is necessary to re-refine it back to pure copper using conventional secondary metal refining techniques that provide a useful supplement to supplies of primary copper.
    e_kassem1
    e_kassem1 غير متواجد حالياً
    Thumbs up
    جزاك الله خيرا . أنا أريد تصنيع فرن سباكة نحاس يعمل بالغاز الطبيعي لتصنيع بعد المنتجات النحاسية. إذا كان لديك أي معلومات في مجال تصميم و تصنيع إسطمبات سباكة النحاس copper die casting. أرجو أن تمدني بها. هل تعرف أسعار خردة النحاس في مصر.
    alshangiti
    Received: 89
    Given: 8
    اليك بعض المواقع عن copper die casting
    www.moderncasting.com/archive/WebOnly/0405/WebOnly0405.pdf
    www.diecasting.org/faq/ - 37k
