Row ::حرم او Right Of Way
النتائج 1 إلى 10 من 12
    م.عبير
    م.عبير غير متواجد حالياً
    ما هي القوانين أو النظم و الستاندرات المتبعة لحماية مسار خطوط الأنابيب البترولية..
    من المتعارف عليه أن هناك حرم لمسار الخط البترولي يجب عدم تجاوزه أو البناء فوقه ..لكن هل هناك ستاندر عالمي بهذا الخصوص ؟؟
    و هل هناك ستاندر يحدد حدود الملكية Right Of Way
    مع جزيل الشكر
    عبير
    م.عبير
    لا زلت انتظر المساعدة
    شكراً
    الجدى
    الجدى غير متواجد حالياً
    الصورة الرمزية الجدى
    Received: 11
    م/ عبير
    يمكنك الرجوع الى الكود العالمى فى شأن تنظيم خطوط البترول و هو
    Asme 31.8
    حيث مذكور به كل شئ عن خطوط البترول
    الجدى
    Received: 11
    The area classification of the pipeline is based upon population density. This is used to determine the Location Class (section 1.2.1b) of the pipeline and the basic Design Factor (section 1.2.1c).
    The method to be employed in determining the location class is laid out in section 840.2 of ASME B31.8 - 1992 edition.
    In general a zone 200m (220 yards) wide is considered either side of the route of the pipeline. The pipeline route is divided into sections of 1 mile so that the individual sections will include the maximum number of buildings for human occupancy. Each separate dwelling unit in a multiple dwelling unit building is to be counted as a separate building.
    Location Classes
    The location classes for Design and Construction according to ASME B31.8 are as follows:
    Location Class
    Number of buildings intended for Human Occupancy
    10 or fewer
    more than 10 but fewer than 46
    3
    more than 46
    4
    more than 46 and including multistorey buildings and where there may be many other utilities
    Note. Where a collection of buildings indicates that the location class is identified as class 2, 3 or 4 then that location class shall continue for 0.2 km from the last building (section 840.2 a 2 in ASME B31.8 - 1992 Edition).
    In addition to the classification above, section 840.3 of ASME B31.8 -1992 indicates additional criteria to be applied for concentrations of people in location class 1 and 2 areas and the consequences of failure near a concentration of people such as found in a place of public assembly, eg a Mosque, school, hospital, hotel, holiday village etc. This means that all these places within location class 1 and 2 areas should be classified as location class 3. This should also apply to normally occupied buildings in location class 1 and 2 .
    When the pipeline route is being classified for the purpose of determining the design factor for pipeline construction or afterwards as part of the pipeline surveillance activities all consideration must be given to the possibility of future development.
    Whilst identifying Location Classes and recognising the requirement for pipelines to work at different stress levels in different location classes ASME B31.8 does not place any restriction on the proximity of a pipeline to a building or group of buildings. This can lead to buildings being built close to pipelines or pipelines being constructed close to buildings. Section 1.2.2 of this document provides advice on the proximity limits.
    م.عبير
    شكراً أستاذ محمد على الرد و التوضيح ..بارك الله بك ..
    كنت اعتقد أن الـ Asme B31.8 له علاقة بالـ Piping ضمن المستودعات النفطية فقط و ليس بـتمديد الـ Pipe Lines ... ساعود إلى الفقرات التي نوهت عنها لاطابقها مع موضوع بحثي ... شكراً جزيلاً مرة ثانية
    عبير
    الجدى
    Received: 11
    اقتباس المشاركة الأصلية كتبت بواسطة م.عبير مشاهدة المشاركة
    عبير
    عفواً و نسأل الله العظيم أن يجعله خالصا ً لوجهه العظيم و يتقبل منا
    عثمان عبد الحفيظ
    عثمان عبد الحفيظ غير متواجد حالياً
    الصورة الرمزية عثمان عبد الحفيظ
    Given: 3
    حماية خطوط الانابيب تتم عبر برنامج الاسكادا غالباً وهناك ايضاً الحماية الكاثودية وكذلك الحماية من العابرات الضغطية والحماية من التمدد الطولي في الانابيب أما تحديد مسار الخط فتتدخل فيه أشياء كثيرة كالعوائق الطبيعية وحدود الترخيص .
    اعمل في مشروع في تصميم خطوط انابيب البترول اتمني منك معلومات أكثر توضيحا حتي استطيع ان امدك أو أوجهك للكتاب المناسب
    ونسأل الله التوفيق لنا ولكم
    م.عبير
    الأستاذ عثمان ، شكراً لاهتمامكم ...
    المعروف أن خط البترول عند تمديده يترك على جانبيه شريط من الأرض بعرض 15 م ( و ليس من الضروري أن يكون الأنبوب في منتصفها ...)و تسمى حرم مسار الخط
    يمنع البناء أو الزراعة أو الحفر أو أية إشغالات على حرم الخط و ذلك لحمايته و تسهيلاً لوصول الشركة المالكة له لصيانته .....
    اريد أن اعرف هل هناك مواصفة تذكر هذه المعلومات بهذا الوضوح و ذلك حتى استند عليها
    وشكراً
    د.محمد باشراحيل
    إستشاري الملتقى
    Received: 127
    Given: 15
    وايضا هناك حرم Right Of Way لخطوط نقل الطاقة الهوائية
    ومحطات التوليد والتحويل .
    موضوع احببت رفعه .
    شكرا م. عبير والمهندس محمد طلعت الجدي ومهندس عثمان وللجميع.
    fokary
    fokary غير متواجد حالياً
    Received: 13
    عندى استفسار هل هذا القانون يطبق فى مصر هم لا؟
    حيث انى اعمل فى احدى شركات البترول وتوجد احدى لبمشروعات السكنيه القوميه المبنيه على الخط الخاص بنقل انتاج الشركه الى تنكات التخزين بدون ترك اى مسافات او غيره وعلاوه على ذلك ان الخط تعرض للكسر فى احدى المرات نتيجه اعمال الحفر لاساسات المبانى الموجوده فوقه
