تصميم كامل لماكنه لف ملفات المتورات او اي نوع ملفات
النتائج 21 إلى 30 من 36
  1. [21]
    م.رائد الجمّال
    الصورة الرمزية م.رائد الجمّال
    Received: 15
    [SIGPIC][/SIGPIC]
    اعقل الناس اعذر الناس للناس
  2. [22]
    م.رائد الجمّال
    Received: 15
    [SIGPIC][/SIGPIC]
  3. [23]
    م.رائد الجمّال
    Received: 15
    OPERATION OF THE UMVERSAL COIL WINDER
    For winding simple solenoid coils, close wound coils and layer or random wound coils the cam is removed so that the wire can be guided by hand. Spaced winding can be done by winding on the appropriate sized wire or cord with the coil and later removing it to leave uniform space between the windings.
    Honeycomb coils are done in the same manner as universal coils except that the spacing and pattern is coarser. For honeycomb and universal coils each turn traverses the entire length of the coil and crosses other turnsdiagonally instead of parallel in order to reduce distributed capacitance. This is the function of the wire guide as it is moved across the length of the form by the cam and follower.
    The practical limit to the helix angle of the turnsseems to be 75 degrees or less so wider coils must also be larger in diameter. A design alternate to a single wide coil can be a row of narrow coils in series such as the familiar "pi-spaced" coils used as R F chokes.
    While small gauge enameled wire is practical for narrow coils it proves a difficult task to wind a wide coil with anything but covered wire. And some adhesive agent must be used to hold the turnsin place after they have been layed on. The old standby was resin dissolved in alcohol. But any of the modern very fast drying adhesives might work as well. Some experimenting will be required.
    It is difficult to find covered wire in the modem market so you may have to salvage R F coils from junked radios, TV'sand other electronic equipment. It may be helpful to wind a strand of thread along with the coil turnsto provide some friction to hold turns in the desired pattern.
    The base layer must be carefully layed to establish the pattern and shape of the coil. It helps to provide a sticky surface on the form such as a piece of masking tape with the adhesive side out.
    Tension should be the minimum to conform the wire to the shape of the form. Excessive tension can distortthe pattern and possibly break the wire. Very light pressure can be applied to the supply roll by the finger or an adjustable spring loaded brake pressing against the supply roll.
    Coil forms of any diameter and length can be made over a waxed dowel or rod by winding a narrow strip of card stock in a spiral over the form and following it with another strip spiralled in the opposite direction and glued over it. The wax prevents a glue bond so that the finished form can be pulled off the rod. A coat of polyester resin will strengthen and seal the form. Almost any cylindrical shape of insulating material can be used as a coil form. But of course some materials are better than others and the Q of the coil is effected by the form material.
    [SIGPIC][/SIGPIC]
  4. [24]
    م.رائد الجمّال
    Received: 15
    [SIGPIC][/SIGPIC]
  5. [25]
    م.رائد الجمّال
    Received: 15
    BuildaUniversalCoilWinder
    Radio amateurs and electronics experimenters constantly work with inductance, capacitance, and resistance. In fact, the hobby has but one real goal: to understand and control these electrical phenomena.
    You, as a hobbyist, need components to assemble into circuits. Coils and the inductance they provide are almost always needed. Usually you won't have a proven design that provides exact speciiications. Even if you did, chances are you would have a difficult time locating the coil you need. As a result, you must wind the coilyourseK adding or subtracting turns until you get it right.
    It certainly is possible to hold a cylindrical form myour hands and slowly wind it witha taut wire, but completingthe coil without a mishap and keeping track of the number of turns can be quite difficult. You will slip the windings, tangle the wire, be forced to answer the phone, or answer someone's''Watcha doin'?" Yes, you can wind the coil by hand, but frustration may turn you into an ugly monster before you're done.
    A simple coil winding machine can produce accurate, uniform coils with exactly the number of turns you want. It canalsoturn out complex coils that can be difEicult, if not impossible, to wind by hand.
    Just a few years ago, experimenters could buy two or threesimple hand- operated affordable coil winders. Ifthey're still available, they are certainly not widely advertised.
    This coil winder design presented here is original only inthat it adapts common, widely-available materials. Although this coil winder does provide a few new features, its design is essentially identical to that of the winders available for a few dollars years ago.
    Buy a coil winder if you can, but don't let this project scare you. Although it may look quite complex, it redly is not. Youll find that it is easy to build. Youll not only be proud of the coils it winds, but you willbe proud of the winder, too!
    With this simple, yet detailed manual youll quickly build a machine that can wind universal and honeycomb coils, single-layer and multi-layer solenoids, close-wound and space-wound coils and pi-spaced coils such as those used for RFChokes and transformers.
    It's easy, fUn,and exceptionally usell. Get Started!
    [SIGPIC][/SIGPIC]
  6. [26]
    م.رائد الجمّال
    Received: 15
    ارجو ان ينال اعجابكم
    [SIGPIC][/SIGPIC]
  7. [27]
    مـاجـد
    مـاجـد غير متواجد حالياً
    موضوع رائع شكرا يا اخي على المعلومة الحلوه
  8. [28]
    بكار الوديدي
    بكار الوديدي غير متواجد حالياً
    مشكووووووووووووور جزاكم الله خيرا
  9. [29]
    EHV
    EHV غير متواجد حالياً
    م.رائد الجمّال
    شكرا جزيلا على هذا المجهود الكبير
    Nothing is as easy as it looks
  10. [30]
    م.رائد الجمّال
    Received: 15
    مشكورين اخواني على هذه الكلمات الطيبه
    [SIGPIC][/SIGPIC]
