تصميم كامل لماكنه لف ملفات المتورات او اي نوع ملفات
النتائج 11 إلى 20 من 36
    م.رائد الجمّال
    الصورة الرمزية م.رائد الجمّال
    Received: 15
    [SIGPIC][/SIGPIC]
    اعقل الناس اعذر الناس للناس
    م.رائد الجمّال
    Received: 15
    [SIGPIC][/SIGPIC]
    م.رائد الجمّال
    Received: 15
    [SIGPIC][/SIGPIC]
    م.رائد الجمّال
    Received: 15
    For coil forms that are too small for the cone mandrel you can improvise slit chucks, The material can be wood, metal, or plastic. Simply drill a #7hole through a dowel or rod of practical length andtap one end 1/4-20 to fit the main spindle threads. You can then mount it on a headless bolt chucked in a drill press, hand drill or lathe and bore the opposite end to the required size to suit the form you want to wind on. Then slit the bored end with the hacksaw and install a hose clamp of appropriate size to clamp the work. A variety can be made to suit the small forms you have on hand.
    The hand crank and friction wheel are a simple affair as shown in detail 8. The crank itself is bent up of 3/16" rod and brazed or soldered into a hole drilled in a 114" set-screw collar opposite the set-screw hole. The friction wheel can be turned of aluminum or any metal if you have a lathe. Or if a lathe is not available you could produce it with the drill press by first drilling the 114" bore andinstalling the set-screw to hold the stock on a 114" rod held in the chuck. An improvised tool rest would enable you to work it to its final shape and size. Yet another alternate is to obtain a drive pulley from a domestic sewing machine and close the groove with epoxy putty. Then mount it on a 114" mandrel held in the drill press and form the half-round groove with a file or cutting tool. The rubber tire that is used to drive the bobbin winder on a domestic sewing machine is rolled into the groove to provide the friction drive.
    A flat is filed on each end of the crank shaft for the set-screws to bear against. And the shaft is installed as shown in the drawing with two 114" set-screw collars for thrust bearings and friction wheel and crank in the appropriate positions. The pressure of the friction plate against the friction wheel is adjusted by the position of the thrust bearing collar on the main spindle. An excess amount of pressure will distort and damage the rubber tire so you want just enough pressure for effective drive.
    The ratio between the crank shaft and the main spindle is infmitely variable by moving the friction wheel to any position along its shaft so that it contacts the friction plate at varying points. This is an important feature because if the ratio were simply one to one successive turns would fall one on top of the other and the desired pattern would not evolve. While a gear drive would be more positive it would not be possible to achieve the very fine adjustment that can be had with this simple friction drive. It requires only a little experimenting to discover the optimum adjustment for each coil job and very good results are had.
    The cams are made as illustrated in detail 9. Again, while brazing is the preferred method of Joining the cam plates to the set-screw collars, the job can be done effectively by soft soldering. The cam plates are 114" X 1-112" fender washers with the set-screw collar hubs mounted an appropriate amount off center. I made my set in increments of 118" to 314" and that is a rather broad range for all ordinary work. Of course any size between can be made and a self supporting universal coil as small as 3/32" wide is not too difficult to wind. 314" may be the practical limit to width for reasons we will discuss later. It proves generally easier to elongate the center hole in the washer with a round file than to tryto drill a partial hole off center. And the set-screw collar can be held in position on the cam plate with a 114" bolt while brazing or soldering.
    [SIGPIC][/SIGPIC]
    م.رائد الجمّال
    Received: 15
    [SIGPIC][/SIGPIC]
    م.رائد الجمّال
    Received: 15
    [SIGPIC][/SIGPIC]
    م.رائد الجمّال
    Received: 15
    [SIGPIC][/SIGPIC]
    م.رائد الجمّال
    Received: 15
    [SIGPIC][/SIGPIC]
    م.رائد الجمّال
    Received: 15
    [SIGPIC][/SIGPIC]
    م.رائد الجمّال
    Received: 15
    [SIGPIC][/SIGPIC]
