تصميم كامل لماكنه لف ملفات المتورات او اي نوع ملفات
النتائج 1 إلى 10 من 36
    الصورة الرمزية م.رائد الجمّال
    م.رائد الجمّال
    Received: 15
    الاخوه و الاخوات الاعزاء هدا مخطط كامل لتصميم ماكنه للف الملفات
    In this project our mechanical challenge is to mount the coil form and rotate it in a positive relationship with a counting device so that a specific number of turns can be layed on the form in a neat pattern. Quite simple in the case of a common solenoid or close wound coil on a cylindrical form. And only slightly more challenging if the turns must be spaced rather than close wound. But when the required pattern is what has come to be known as "Universal winding" the challenge is somewhat greater. Then a mechanism must be added to guide the wire in a transverse pattern while keeping count of the number of turns. In the design presented here the transverse motion is provided by a cam to convert the rotary motion of the crank shaft to the straight line motion of the wire guide. A simple friction wheel and plate accomplishes a right angle in the rotary motion to drive the coil form. And another cam operates the counter to complete the mechanism. A simple cone chuck or slit chuck holds the form and an assortment of cams provide for a variety of widths while the variable ratio friction drive allows any transverse pattern within a wide range.
    The design presented is not original except in its adaptation to common materials. Hand operated machines operating on this same principle were widely marketed for many years so the concepts are well tried. The units that were commercially available a number of years ago were built upon die-cast frames and they used die-stamped sheet metal components that are impractical for individuals to produce at home. The objective in this adaptation is to accomplish the same effects with commonly available items and without the use of machine shop equipment. A lathe would prove useful but is not at all necessary. A drill press is preferred but all of the drilling can be done with a hand drill if necessary. Also it would be preferred to braze or silver solder the cams and friction plate but these operations can be done satisfactorily by soldering with a propane torch. Alternate methods for producing and assembling the various parts will be discussed so that it becomes practical to assemble this simple machine with only a few common tools and just ordinary hand skills.
    Reasonable care should be taken in all of the layout, cutting and drilling operations. But none of the operations would be termed "precision work". Hole centers should be center-punched and the drills sharp and true. The objective is for a reasonably close, friction-free fit of the spindles and cam follower, and a neat appearance on the cut edges, which are made free of burrs by filing or grinding to eliminate cutting hazards. Taken one part at a time even an inexperienced person should be able to interpret the drawings and carry out the operations. The text will be minimal but I'll tryto describe in detail anything that does not seem obvious in the drawings.
    Only seven simple parts are found in the main frame in addition to the screws that are used to assemble it. And the first one to make will be the wooden base as shown in detail 1 shown on page 2. Plywood or any hardwood will be OK. And if you intend to paint or varnish the base it can be drying while you make the remaining parts.
    من مواضيع م.رائد الجمّال :
    [SIGPIC][/SIGPIC]
    اعقل الناس اعذر الناس للناس
    م.رائد الجمّال
    Received: 15
    [SIGPIC][/SIGPIC]
    م.رائد الجمّال
    Received: 15
    [SIGPIC][/SIGPIC]
    م.رائد الجمّال
    Received: 15
    [SIGPIC][/SIGPIC]
    م.رائد الجمّال
    Received: 15
    [SIGPIC][/SIGPIC]
    م.رائد الجمّال
    Received: 15
    [SIGPIC][/SIGPIC]
    م.رائد الجمّال
    Received: 15
    [SIGPIC][/SIGPIC]
    م.رائد الجمّال
    Received: 15
    [SIGPIC][/SIGPIC]
    م.رائد الجمّال
    Received: 15
    [SIGPIC][/SIGPIC]
    م.رائد الجمّال
    Received: 15
    I removed the belt hook from the counter while it was disassembled because it was of no use in this application. And it was a simple matter to drill a couple of 118" holes through the case and bracket and Join the parts with pop rivets. The best procedure is to drill one hole each in the case and bracket and install the first rivet. Then drill the second hole through both members to ensure perfect alignment. The rivets in this instance had to be installed from inside the case for there was scant clearance between the case wall and the counter mechanism. The heads of the rivets are much thinner than the expanded ends, And I struck the heads a blow or two witha small hammer to thin them a bit more. If you adapt a different type of counter the only requirement is to orient the button or lever so that it will be operated by the spindle cam.
    The counter lever pivots on the supply spool spindle and it is dimensioned to reach the operating button or lever of the counter. 1/16" thick sheet metal is adequate for the job. Make it as shown in detail 6 or modify to accommodate such counter as you use.
    The supply spool spindle is made of 114" diameter rod with 1/4-20 threads cut on one end. A standard 114" set-screw collar is used to position the counter lever on the shaft. And a pair of 1/4-20 nuts fasten the supply spool spindle to its bracket. The counter is located to align with the lever and to clear the main spindle. Locatethe two mounting holes through the holes in the bracket. Drill them #29 in the spindle bracket and tap them 8-32. Install the counter with two machine screws.
    The coil spindle is made up of several simple parts. A114" diameter rod 4-314" long is threaded 1/4-20 for about 112" on one end. While it would be best to cut the threads in a lathe, it can be done quite well using a guided die-stock so that the threads will be perpendicular to the axis of the shaft. These threads are for the coupling nut so a serious wobble will result if they are not quite true axially. The opposite end of the shaft has a flat filed for a length of about an inch for the set-screws to seat against.
    The friction plate is made by joining a standard 114" set-screw collar to a 114" X 1-112" fender washer. While brazing or silver soldering is the preferred method of joining, it can be done withsoft solder using a propane torch. Since both the collar and the washer are plated it will be necessary to remove the plating if you use soft solder. Use a file, grinder or abrasive cloth to remove the plating. Acid flux is required for soldering ferrous metals. And it will be best to tin the surfacesto be joined before sweating them together. If properly done the soft solder will be strong enough for this purpose. Whether brazing or soldering, avoid breathing any resultant fumes. Cadmium is especially hazardous and any such vapors are to be avoided.
    The counter cam is simply a 114" set-screw collar with a round head machine screw replacing the original socket head set-screw. Trim the screw to the appropriate length to both lock the collar in place on the shaft and so that the head of the screw will depress the counter lever with each rotation of the main spindle.
    [SIGPIC][/SIGPIC]
