&....Computer start up
النتائج 1 إلى 8 من 8
    Mech_usama
    Mech_usama غير متواجد حالياً
    I have a problem at start up of my computer it take time and whene try to open any file or directory also take over a 30 second can any body help me with that
    with regard osama
    م.رائد الجمّال
    الصورة الرمزية م.رائد الجمّال
    Received: 15
    ok go to start >> run >> then type in the text box msconfig >>then click enter
    a new dialog window will appear u will find many tabs in that window click in the one called start up
    u will find many programs names that start in ur pc as u turn it on , so un chick the not necessary ons, then click apply , u will be asked if u wan to restart ur pc , make restart , and then see the result
    if that didnt success tell me and i will guide u
    all respect
    raed al jammal
    [SIGPIC][/SIGPIC]
    اعقل الناس اعذر الناس للناس
    Mech_usama
    Access denied
    Slam, i did that but it give me an axcess denied you have to log on adminstration
    i dont know there is only one account for me can you figure that i will be great full.
    م.رائد الجمّال
    Received: 15
    okkk try this i think u have virus or trojan at ur pc
    start >> run >> msconfig.exe>>>> then hit enter
    type to me the error message exactly
    [SIGPIC][/SIGPIC]
    Mech_usama
    Read this
    Thanks Engineer raed,
    It give me the Window of System Configuration utility Whene i press ok it give me this( An access denied error was returned while attempting to change a serivce. you may need to log on using an adminstrator account to make the specified changes.
    Then ok it give me
    Start computer or exist restrat
    i dont know if there is an adminstratitor how to check that or where to find
    م.رائد الجمّال
    Received: 15
    Try this one......................
    To resolve this issue follow these steps:
    1. Click on Start->Run->Type "mmc" (without the quotes).
    2. In the Console Window, click on file and then select Add/Remove Snap-in
    3. Click on the Add button. Select Security Configuration and Analysis. Click on
    Add and then click on close.
    4. In the add/remove snap-in window, click on OK
    5. In the console window, right click on the security configuration and analysis
    (either in the left or in the right pane) Select open Database
    6. In the open database window, type "default" (without quotes) as the file name
    and click on ok.
    7. Select setup security option and click on ok.
    8. Again right click on Security Configuration and analysis and click on configure
    computer now.
    9. Click on OK in the window that appears.
    if that didnt work tel me and i will go the top in this feature
    [SIGPIC][/SIGPIC]
    م.رائد الجمّال
    Received: 15
    do this also, right click in my computer icon , properties>>then click in the advance tab after that click in the button start up and recovery.. u will see drop down menu it must be write there
    "Microsoft windows XP professional" /noexecute=optin/fastdetect
    i suggest that u read this
    http://www.arab-eng.org/vb/showthrea...CA%D4%DB%ED%E1
    it have many info about this problem
    as i start think it may be vinous or Trojan
    [SIGPIC][/SIGPIC]
    Mech_usama
    It good, But.....
    Thanke for the file i tried every thing but the problem remain the same which is the computer refuse tany modification on the start up menue ,Am waiting for any more advice .
