Piping Handbook
النتائج 1 إلى 9 من 9
    alcoholahmed
    alcoholahmed غير متواجد حالياً
    Piping Handbook
    Summary:
    Instant answers to your toughest questions on pipingcomponents and systems!It's impossible to know all the answers when piping questions are on the table - the field is just too broad. That's why even the most experienced engineers turn to Piping Handbook, edited by Mohinder L. Nayyar, withcontribution from top experts in the field. The Handbook's 43 chapters - 14 of them new to this edition and 9 new appendices provide, in one place, everything you need to work with any type of piping, in any type of piping system: *design *layout*selection of materials *fabrication and components *operation*installation *maintenanceThis world-class reference is packed with a comprehensive array of analytical tools, and illustrated with fully-worked-out examples and case histories. Thoroughly updated, this seventh edition features revised and new information on design practices, materials, practical applicationsand industry codes and standards plus every calculation you need to do the job.
    Covers materials and their properties and limitations, hundreds of piping systems design details, sections on bolted and threaded joints, erosion and corrosion, double containment piping systems, international piping material specifications, and standards, and SI units and U.S. customary.
    Features:
    Full coverage of materials and their properties and limitations
    Hundreds of piping systems design details
    New sections on bolted and threaded joints, erosion and corrosion, double containment piping systems, international piping material specifications, standards
    and much more!
    The Piping Handbook now in its seventh edition, covers the entire field of piping and related subjects. It is the most useful, complete, well-organized, and internationally applicable professional reference in the field.
    Featuring 90% completely new or meticulously revised text, 15 added sections, and the inclusion of SI units, this bestselling guide thoroughly reflects the latest changes in piping design, practice, materials, and industry standards.
    Piping Fundamentals
    Introduction to Piping
    Piping Components
    Piping Materials
    Piping Codes and Standards
    Manufacturing of Metallic Piping
    Fabrication and Installation of Piping
    Bolted Joints
    Prestressed Concrete Cylinder Pipe and Fittings
    Grooved and Pressfit Piping Systems
    Selection and Application of Valves
    Generic Design Considerations
    Hierarchy of Design Documents
    Design bases
    Piping Layout
    Stress Analysis of Piping
    Piping Supports
    Heat Tracing of Piping
    Thermal Insulation of Piping
    Flow of Fluids
    Cement-Mortar and Concrete Linings for Piping
    Fusion Bonded Epoxy Internal Linings and External Coatings for Pipeline Corrosion Protection
    Rubber Lined Piping Systems
    Plastic Lined Piping for Corrosion Resistance
    Double Containment Piping Systems
    Pressure and Leak Testing of Piping Systems
    Piping Systems
    Water Systems Piping
    Fire Protection piping Systems
    Steam Systems Piping
    Building Services Piping
    Oil Systems Piping
    Gas Systems Piping
    Process Systems Piping
    Cryogenic Systems Piping
    Refrigeration Systems Piping
    Hazardous Piping Systems
    Slurry and Sludge Systems Piping
    Wastewater and Stormwater Systems Piping
    Plumbing Systems Piping
    Ash Handling Piping Systems
    Compressed Air Piping Systems
    Compressed Gases and Vacuum Piping Systems
    Fuel Gas Distribution Piping Systems
    Nonmetallic Piping
    Thermoplastics Piping
    Fiberglass Piping Systems
    Appendices
    Conversion Tables
    Pipe Properties (US Customary Units)
    Pipe Properties (Metric)
    Tube Properties (US Customary Units)
    Tube Properties (Metric)
    Friction Loss for Water in Feet per 100 Feet of Pipe
    Friction Loss for Water in Meters per 100 Meters of Pipe
    Acceptable Pipe, tube and Fitting Materials per the ASME Boiler and Pressure Vessel Code and the ASME Pressure Piping Code
    International Piping Maaterial Specifications
    Miscellaneous Fluids and Their Properties
    Miscellaneous Materials and Their Properties
    Piping Related Computer Programs and Their Capabilities
    International Standards and Specifications for Pipe, Tube, Fittings, Flanges, Bolts, Nuts, Gaskets and Valves
    Index
    http://rapidshare.com/files/10790136...0070471061.rar
    http://mihd.net/nutecb
    http://file2upload.com/file/5210/pip...71061.rar.html
    Mouhamadkk77
    Mouhamadkk77 غير متواجد حالياً
    السلام عليكم...جزاكم الله خيرا على هذا الموضوع الشيق و لكن أجد صعوبة في التحميل...أرجو المساعدة
    waheed69
    waheed69 غير متواجد حالياً
    بالتوفيق ان شاء الله
    علاء الدين شعث
    علاء الدين شعث غير متواجد حالياً
    الف الف الف شكرا الك وفي ميزان حسناتك
    islamomraneng
    islamomraneng غير متواجد حالياً
    الله يباركلك مجهودك الطيب
    Beeiiko
    Beeiiko غير متواجد حالياً
    The file is not existed
    please reupload
    ع الناصري
    ع الناصري غير متواجد حالياً
    الفايل غير موجود لطفا ،، هل توجد روابط اخرى
    البعث
    البعث غير متواجد حالياً
    مشكووووووووووووووووووورررررررررررررررررررررررررررر
    hewa_mhamad36
    hewa_mhamad36 غير متواجد حالياً
    شكرا لك اخي الكريم ولكن لا اعرف كيف انزله ولكم جزيل الشكر
