اريد مساعدة فى الكنترول؟
النتائج 1 إلى 6 من 6
    midors
    midors غير متواجد حالياً
    mbayer
    mbayer غير متواجد حالياً
    as i know the feed back control loop is loop to compare the output with input in your control system to reduce the error in your control system
    (for example if you want to control the temperature to stay at certain temp. you need feed back control loop to compare the output temp. with one you want to reach to make a stable temp. (
    عصام1983
    عصام1983 غير متواجد حالياً
    at example , u have a two moveable machines and u want to move the both in the same speed so there is a controller for two machines and there is a feedback system between the two when the first machine move at some speed the other one try to get that speed
    industry example
    عصام1983
    also you have some machine have some pressure u set in the control panel some value input then u ll see the machine go this value when the pressure go over that value it will reduce the pressure trying to get that value , with some small errors no problem
    eng_sasi
    eng_sasi غير متواجد حالياً
    ال feed back loop هو بيبقي زي sensor مثلا علشان يقارن القيمه الحقيقيه الناتجه من ال system بالقيمه المطلوبه فهيطلع قيمه الخطا الموجود فنبتدي نقلل الخطا ده لاقصي درجه ممكنه لتحسين اداء الsystem ده معناه ببساطه شديده جدا
    عصام1983
    السنسر هو مجرد input يعطي signal للplc program بس ال feedbackعبارة عن دوائر الكترونيه مثال مبسط عندك الcomparater amplifier يقوم بعمليه feedback وبعدين بدك تحول الcurrent to physical action مثل speed or force to cotrol the system that is in general meaning
