تصميم التروس Gears Design
صفحة 8 من 14 الأولىالأولى ... 4 5 6 7 89 10 11 12 ... الأخيرةالأخيرة
النتائج 71 إلى 80 من 138
  1. [71]
    سامي صلاح عبده
    سامي صلاح عبده غير متواجد حالياً
    طريقة عمل هذا البرنامج كما يلي:
    GUIDES FOR RUNNING THE PROGRAM
    1. Copying the program on the desktop or create a shortcut
    2. Double click on the program icon or short cut of "GEARS DESIGN R 1.0" on the desktop to run the program
    3. The first screen is loaded -Splash or introductory
    screen after this clicking and it will stay for five seconds for
    reading the short message about the program, but if no need to
    read this message, one click on this form will cancel it.
    4. Now second screen is loaded for the selection of the
    design mode, is it for bending stress or for surface fatigue ?, by
    clicking on the button of the required mode. When clicking on the
    PROGRAM QUIT button the program will shut down ending the
    design modes.
    5. If the required mode is bending stress the user must
    click on the BENDING STRESS button and the general form for
    common input is loaded and he must enter the gear material by
    clicking the arrow of the combo box and select it from the list.
    After that also he must select the transmission accuracy level and
    the reliability by the same way of entering the gear material. The
    last two steps in this form are the input power -in watts-, the
    angular speed- in revolution per minute- and clicking on the button
    of the required gear to be designed.
    6. If required gear is spur gear and it is button was clicked
    the user must enter the following required data:
    " Selecting the pressure angle
    " Entering the gear ratio
    and clicking on the DESIGN RESULTS button to load the final design
    results (all required data for the manufacturing of the spur gears)
    7. The user can view a report of this design by clicking on the VIEW REPORT button
    8. If it is required to save the report the user can click on
    the PRINT button and the program can print the report
    form using the default printer connected to the computer.
    9. If the required gear is helical and it is button was clicked
    " Selecting number of teeth of the pinion
    " Selecting angle of helix
    design results (all required data for the manufacturing of the helical
    gears).
    10. The user can view a report of this design by clicking on the VIEW REPORT button
    11. If it is required to save the report the user can click on
    12. If the required gear is bevel and it is button was clicked
    and clicking on the design results button to load the final design
    results (all required data for the manufacturing of the bevel gears)
    13. The user can view a report of this design by clicking on the VIEW REPORT button
    14. If it is required to save the report the user can click on
    15. if the design mode required is the surface fatigue the
    user must click on the SURFACE FATIGUE button on the
    introductory form to enter the design of gears according to the
    AGMA pitting resistance formula and the remaining steps are the
    same as in the bending stress formula which are depicted in the
    above paragraphs.
    16. most of the program forms have a quit button when
    clicked on it the form will be unloaded and the user can exit from this
    form until he reach the introductory form from which he can exit
    from the program by clicking on the button of the PROGRAM
    QUIT.
  2. [72]
    aid20002005
    aid20002005 غير متواجد حالياً
    الروابط للأسف لاتعمل يا ريت حد يرفع هذا الملف ثانيا وله جزيل الشكر والعرفان.........................
  3. [73]
    mss3d
    mss3d غير متواجد حالياً
    مشكور اخي الكريم
  4. [74]
    سامي صلاح عبده
    اقتباس المشاركة الأصلية كتبت بواسطة aid20002005 مشاهدة المشاركة
    الملف المرفق في المشاركة رقم 50 به هذا البرنامج نرجو منك تنزيله بالضغط عليه فقط
  5. [75]
    وائل عبده
    وائل عبده غير متواجد حالياً
    شكرا جزيلا يا اخ سامي الموضوع ممتاز جدا جزاك الله كل خير
  6. [76]
    سامي صلاح عبده
    شكر
    اقتباس المشاركة الأصلية كتبت بواسطة محمد عبدالموجود مشاهدة المشاركة
    لك التحية اخ محمد عبد الموجود
  7. [77]
    حسام جاسم
    حسام جاسم غير متواجد حالياً
    الصورة الرمزية حسام جاسم
    مشكورأخي مهندس سامي جزاك الله خير الجزاء.
  8. [78]
    ahmedzizo
    ahmedzizo غير متواجد حالياً
    شكرا جزيلا ونتمنى لك التوفيق ان شاء الله
  9. [79]
    سامي صلاح عبده
    اتمنى التوفيق والسداد لنا جميعا حتى ننهض بهذه الامة حيث لا نهضة بغير هندسة
  10. [80]
    SAYHAAN
    SAYHAAN غير متواجد حالياً
    شكرررررررررررررررررررررررا
    شكرررررررررررررررررررررررررررررررررررررررا
