برنامج ... KitchenDraw ver.5.0 ... للمهندسيين
النتائج 1 إلى 10 من 10
    Mu7ammad
    Mu7ammad غير متواجد حالياً
    Received: 8
    KitchenDraw ver.5.0
    Windows OS | Size: 11.6 Mb
    Kitchen Draw software is a program that boasts 2-D and 3-D planning capability along with photo-realistic images. Available in 25 different languages, the program has a Catalog Creator Tool that allows cabinet manufacturers and distributors to create their own catalog. It's now possible to move around in real time in a KitchenDraw scene.
    Virtual Reality
    It's now possible to move around in real time in a KitchenDraw scene thanks to the Walkthrough facility.
    Improved dimensions
    A dynamic and automatic dimensioning facility like the one already existing in KD4.5 for elevation views has been developed for plan views. In addition to increase the ease of use, this new feature allows to produce better looking floor plans.
    Furthermore, it's now possible to place angular dimensions as well as radius dimensions. This is particularly useful to establish special worktops plans to the manufacturers.
    Size and precision of the scenes
    The scenes format has been changed with KitchenDraw version 5. Now, the numerical values are 32 bits long.
    Actually that means it's now possible to plan huge scenes with a much better accuracy.
    As an example, it would be possible to plan a scene having a 200 kilometres side with a precision of a tenth of a millimetre.
    In order to take advantage of this new possibility, new measurement units have been introduced:
    mm (1 mm) : the dimensions are given in millimetres with a precision of 1 millimetre (without any decimal)
    mm (1,0 mm) : the dimensions are given in millimetres with a precision of a tenth of a millimetre (one decimal)
    mm (1,00 mm) : the dimensions are given in millimetres with a precision of a hundredth of a millimetre (two decimals)
    cm (1,0 cm) : the dimensions are given in centimetres with a precision of 1 millimetre (one decimal)
    If you use metric measurements, we now advise that you use the mm (1,0 mm) measurement unit.
    Circle arcs in shapes
    In KitchenDraw 5.0, circles arcs are not transformed into a sequence of linear segments but they keep their circle arc identity.
    This is particularly important when it becomes necessary to send technical plans to the manufacturers (special worktops, etc.) because this allows an automatic integration into the production process.
    It's possible to export special worktops plans (worktops inside shape) as .DXF files and to join them to the supplier order file sent by email.
    KDWebShow
    This facility allows a KitchenDraw 5 user to place some of his projects (scenes) on the KitchenDraw server. This way, the corresponding clients will be able to see them remotely through the internet.
    DownLoad
    Original Site
    .... والله ولى التوفيق ...
    darkxx
    darkxx غير متواجد حالياً
    مشكورررررررر
    المهندس عبد القوي
    المهندس عبد القوي غير متواجد حالياً
    الصورة الرمزية المهندس عبد القوي
    مشكور ياحبيبي
    انت حبيبى دائما
    انت حبيبى دائما غير متواجد حالياً
    الصورة الرمزية انت حبيبى دائما
    ما شاء الله - طول عمرك شاطر يا بشمهندس محمد - الى الامام دائما
    امير عوض
    امير عوض غير متواجد حالياً
    الصورة الرمزية امير عوض
    مشكوووووووووووور
    ادور
    ادور غير متواجد حالياً
    عضو متميز جداً
    الصورة الرمزية ادور
    Given: 5
    مشكورررررررررررررررررررر كلم ولكم كل التقدم
    egy_3d
    egy_3d غير متواجد حالياً
    لقد مر أكثر من عام ونصف على طرح الموضوع .. ألم يوجد إصدار جديد من نفس البرنامج؟
    alaa eldin farag
    alaa eldin farag غير متواجد حالياً
    جزاك الله خيرا ولو هناك رابط أخر غير الربد شير يبقي جوزيت خيرا
    اكارم
    اكارم غير متواجد حالياً
    مشكووور
    عمرو ريحان
    عمرو ريحان غير متواجد حالياً
    ارجو اذا ممكن تعريب
    KitchenDraw v4.52ولكم الشكرe
