structural program///RSTAB 5.15.001
النتائج 1 إلى 4 من 4
    hassananas
    hassananas غير متواجد حالياً
    Received: 224
    Given: 6
    Dlubal RSTAB 5.15.001
    The statics programs of the RSTAB family are used to determine the internal forces, support reactions and deformations of any two- or three-dimensional structure. The modular program concept meets individual user demands for specific project requirements. Add-on modules are currently available for steel and timber design, the determination of buckling modes and critical load factors, moving loads, advanced load combinations, construction phases and for dynamic analyses. RSTAB also interacts with SHAPE-THIN, an advanced program for the analysis of section properties for any thin-walled cross-section.
    RSTAB 5.xx is mainly known for its low learning curve and outstandig graphical user interface. The program provides many very productive and helpful features such as:
    Calculation of 2D and 3D structures according to 1st and 2nd order theory, and of cable structures according to 3rd order theory.
    Automatical superpositioning of results according to various criteria such as 'conditional' and 'either/or'.
    Any result combination possible to determine the decisive internal forces and deformations.
    Optional consideration of varying construction levels with changing structural geometries, hinge and support conditions by means of the SUPER-LC module.
    Multi-language interface in English and German. Work in English and print in German or vice versa.
    Integration of user-defined general cross-sections such as I-shaped, C-shaped or channel sections, angles, and many more. Only the dimensions have to be specified, RSTAB calculates all section properties automatically.
    Consideration of web-tapered elements, rigid couplings, non-linear springs with friction and cohesion effects, eccentric connections and elastic foundations.
    Adaptable graphics with animation of the deformations.
    Non-linear calculation of tension, compression and spring members.
    Get it (no mirrors):
    http://rapidshare.com/files/25238540...part1.rar.html
    http://rapidshare.com/files/25242909...part2.rar.html
    http://rapidshare.com/files/25247183...part3.rar.html
    http://rapidshare.com/files/25251849...part4.rar.html
    http://rapidshare.com/files/25234626...part5.rar.html
    More info:
    www.dlubal.de/ProductDetail.aspx?id=1101
    abdoo_farra
    abdoo_farra غير متواجد حالياً
    Received: 41
    بارك اللة فيك
    المهندس ابوعمر
    المهندس ابوعمر غير متواجد حالياً
    عضو متميز جداً
    الصورة الرمزية المهندس ابوعمر
    Received: 47
    Given: 16
    thank u my dear eng
    CVLMASTER
    CVLMASTER غير متواجد حالياً
    الصورة الرمزية CVLMASTER
    Received: 18
    Thanking You Very Much
