بصراحة عندي مشروع في applied heat exchanger
وابغى منكم المساعده اذا امكن في بعض المعلومات
(double pipe heat exchanger sizing)
information: desing an optimum size double pipe heat exchanger which is to be employed to heat 5 kg/s of dowtherm from (15 to 65 درجة الحراره)
using hot water cooled in the process from 95 th 75.
the pressure drop on the water side is a given constraint which must not be more than 200000 N/m2 while the pressure drop on the dowtherm side is also a given constraint which must be more than 150000 N/m2.
use the properties of water
properties of dowtherm at a mean temperatuer of 40 are as follows:
density(1044 kg/m3
spisific heat(1622 J/kg-k
conductivity(0.138 W/m-k
viscosity(0.0027 N-s/m2
prandtle # 31.7
copper allys as well as stainless steel are both compatible with dowtherm
requirements:
* provide a project report that is according to the acceptable format
including a cover page table of co tents , a main body which includes a disussion of the step by step desing methodology with flow chart
هذا هو المشروع بس والله متلخبط ماني عارف كيف ابدا فيه ياليت القى المساعده في هذا الموقع لاني في شباب دلوني على الموقع هذا وقالوا لي تلقى فيه الحل باذن الله ياليت تعطوني حل او معلومات تساعدني خلال 3 ايام من كتابة الموضوع
