سلسلة التحسين المستمر
صفحة 4 من 5 الأولىالأولى 1 2 3 45 الأخيرةالأخيرة
النتائج 31 إلى 40 من 42
  1. [31]
    محمد رحيم
    محمد رحيم غير متواجد حالياً
    برجا ترجمة هذه المقالات حتى تعم الفائدة
  2. [32]
    الأحرار
    الأحرار غير متواجد حالياً
    جزاك الله خيرا كثيرا
  3. [33]
    صناعي1
    صناعي1 غير متواجد حالياً
    الصورة الرمزية صناعي1
    Received: 19
    Given: 3
    كما يمكن الوصول لهذه المقالات من خلال الموقع
    http://sites.google.com/site/improveprocess/
  4. [34]
    Loverone
    Loverone غير متواجد حالياً
    شكرا جزيلا
  5. [35]
    صناعي1
    Received: 19
    Given: 3
    اقتباس المشاركة الأصلية كتبت بواسطة loverone مشاهدة المشاركة
    شكرا جزيلا
    حياك الله
  6. [36]
    صناعي1
    Received: 19
    Given: 3
    Simulation is a powerful tool, it simply enables you to build your real world inside the simulation software and start playing with it! Sometimes you want to test if the proposed improvement is really an improvement and does what is assumed to. But this can not be easily done in situations when the process improvement requires major changes in the current arrangements (such as change in layout or staffing level).
    Here the power of simulation comes to the front. You can build a model that mimics your actual situation with as much detailed as your team and the simulation package can handle. Also, you can create scenarios for applying the modifications proposed by the process improvement team and start experimenting and evaluating the results.
    Simulation can be very useful when improving material handling systems because you can model your system using simulation package and test any ideas and change whatever you want without changing the real physical arrangements that are expensive usually.
    Doing simulations is not as simple as talking about it. But benefits usually outweigh the costs when you need to make changes that are costly or the outcomes of the "improved process" are not clear
    for this article and more, click here
  7. [37]
    صناعي1
    Received: 19
    Given: 3
    للرفع
  8. [38]
    dalitafun
    dalitafun غير متواجد حالياً
    خير ما رفعت و خير ما شاركتنا به...
    لك جزيل الشكر و نسأل الله ان يجزيك خير الجزاء
  9. [39]
    رائد المعاضيدي
    رائد المعاضيدي غير متواجد حالياً
    عضو تحرير المجلة
    الصورة الرمزية رائد المعاضيدي
    Received: 22
    Given: 12
    جزاك الله خيرا مشرفنا القدير
    وكل عام وانت بالف خير
  10. [40]
    صناعي1
    Received: 19
    Given: 3
    اقتباس المشاركة الأصلية كتبت بواسطة رائد المعاضيدي مشاهدة المشاركة
    و إياكم أخي رائد
    و كل عام و أنت بألف خير
