كتاب ACI 318-05 Building Code Requirements for Structural Concrete
النتائج 1 إلى 4 من 4
    descovery_2000
    descovery_2000 غير متواجد حالياً
    Received: 11
    اليكم هذا الكتاب
    url=http://www.y1y1.com/u][/url
    نبذة عن الكتاب
    The code portion of this document covers the design and construction of structural concrete used in buildings and where applicable in nonbuilding structures. Among the subjects covered are: drawings and specifications; inspection; materials; durability requirements; concrete quality, mixing and placing; formwork; embedded pipes; construction joints; reinforcement details; analysis and design; strength and serviceability; flexural and axial loads; shear and torsion; development and splices of reinforcement; slab systems; walls; footings; precast concrete; composite flexural members; prestressed concrete; shells and folded plate members; strength evaluation of existing structures; special provisions for seismic design; structural plain concrete; strut-and-tie modeling in Appendix A; alternative design provisions in Appendix B; alternative load and strength-reduction factors in Appendix C; and anchoring to concrete in Appendix D. The quality and testing of materials used in construction are covered by reference to the appropriate ASTM standard specifications. Welding of reinforcement is covered by reference to the appropriate ANSI/AWS standard.
    حمل من هنا
    http://rapidshare.de/files/21866301/A-1-A-1.rar.html
    او من هنا
    http://www.megaupload.com/sa/?d=ZVCB7D2Y
    او من هنا
    http://www.games-4u.net/up/get.php?c...-05-545454.zip
    ومن الله التوفيق
    hassananas
    hassananas غير متواجد حالياً
    Received: 224
    Given: 6
    dear sir
    this is the text of the Aci code
    its not a book
    this is the bible of Aci
    thank you
    علي الرفاعي
    علي الرفاعي غير متواجد حالياً
    مشكوووووووووووووووووووووووووور
    mohy_y2003
    mohy_y2003 غير متواجد حالياً
    الصورة الرمزية mohy_y2003
    Received: 350
    Given: 439
    مشكور جدا وجزاك الله خيرا
