كـتب رائعة في الصــيانة Maintenance
صفحة 6 من 12 الأولىالأولى ... 2 3 4 5 67 8 9 10 ... الأخيرةالأخيرة
النتائج 51 إلى 60 من 111
  1. [51]
    أهل الحديث
    أهل الحديث غير متواجد حالياً
    Received: 205
    Given: 261
    Lubricants and Lubrication
    * Publisher: Wiley-VCH
    * Number Of Pages: 890
    * Publication Date: 2007-03-16
    * ISBN / ASIN: 3527314970
    * EAN: 9783527314973
    Buy New $230.30
    This completely revised second edition incorporates the latest data available and reflects the knowledge of one of the largest companies active in the business. The authors take into account the interdisciplinary character of the field, considering aspects of engineering, materials science, chemistry, health and safety. The result is a volume providing chemists and engineers with a clear interdisciplinary introduction and guide to all major lubricant applications, focusing not only on the various products but also on specific application engineering criteria
    http://mihd.net/m052jn
    http://rapidshare.com/files/76895440/LL2ndEdWil3527314970.rar.html
    http://www.mediafire.com/?5lynicsodje
    { الَّذِينَ آتَيْنَاهُمُ الْكِتَابَ يَعْرِفُونَهُ كَمَا يَعْرِفُونَ أَبْنَاءَهُمُ }
  2. [52]
    أهل الحديث
    Received: 205
    Given: 261
    Hydrodynamic Lubrication
    By Yukio Hori
    * Publisher: Springer
    * Number Of Pages: 250
    * Publication Date: 2005-12-19
    * ISBN-10 / ASIN: 4431278982
    * ISBN-13 / EAN: 9784431278986
    Hydrodynamic lubrication plays an important role in mechanical engineering, although not very many books have been published on the subject. This book was written with graduate students, researchers and designers in view.
    The first four chapters are preparations for the following five chapters, where several most important subjects in hydrodynamic lubrication are discussed in detail, based on the authors own researches. Examples are oil whip (stability of rotating shafts), foil bearings in connection with magnetic tape storages, squeeze film between rigid surfaces and visco-elastic surfaces, theoretical and experimental analyses of temperature rise in bearings, those of turbulent lubricating film using the k-epsilon model
    http://mihd.net/upsktb
    http://rapidshare.com/files/12495868/hl.rar.html
  3. [53]
    أهل الحديث
    Received: 205
    Given: 261
    Engineering Tribology
    By Gwidon Stachowiak, A W Batchelor
    * Publisher: Butterworth-Heinemann
    * Number Of Pages: 832
    * Publication Date: 2005-09-07
    * ISBN-10 / ASIN: 0750678364
    * ISBN-13 / EAN: 9780750678360
    As with the previous edition, the third edition of Engineering Tribology provides a thorough understanding of friction and wear using technologies such as lubrication and special materials. Tribology is a complex topic with its own terminology and specialized concepts, yet is vitally important throughout all engineering disciplines, including mechanical design, aerodynamics, fluid dynamics and biomedical engineering. This edition includes updated material on the hydrodynamic aspects of tribology as well as new advances in the field of biotribology, with a focus throughout on the engineering applications of tribology.
    New to this edition are end-of-chapter problems and an accompanying solutions manual, increasing the books value as a textbook. The book offers an extensive range if illustrations which communicate the basic concepts of tribology in engineering better than text alone. All chapters include an extensive list of references and citations to facilitate further in-depth research and thorough navigation through particular subjects covered in each chapter.
    * Includes newly devised end-of-chapter problems, as well as an accompanying solutions manual.
    * Provides a comprehensive overview of the mechanisms of wear, lubrication and friction in an accessible manner designed to aid non-specialists.
    * Gives a reader-friendly approach to the subject using a graphic illustrative method to break down the typically complex problems associated with tribology
    PDF Size: 53.95 MB
    http://mihd.net/fh4v1m
    http://rapidshare.com/files/82502458/0750678364.rar
  4. [54]
    خبير.ص
    خبير.ص غير متواجد حالياً
    La préparation des moteurs
    Préparation des moteurs
    By Patrick Michel
    * Publisher: Rta - Revue Technique
    * Number Of Pages: 207
    * Publication Date: 1991-12-11
    * ISBN-10 / ASIN: 2726880371
    Format : Djvu
    207 pages
    Edition : Rta - Revue Technique
    Langage : French
    http://mihd.net/onp8l0
    http://www.filefactory.com/file/441abb/
    http://rapidshare.com/files/79459966/preparation_des_moteurs.djvu
    1 2 3 VIVA L’ALGERIE
    اذا الشعب يوما اراد الحياة ----------- فلابد ان يستجيب القدر
    و لابد لليل ان ينجلي --------- -- ---- ولابد للقيد ان ينكسر
  5. [55]
    أهل الحديث
    Received: 205
    Given: 261
    Lubrication and Reliability Handbook
    By M J NEALE
    * Publisher: Newnes
    * Number Of Pages: 256
    * Publication Date: 2000-12-11
    * ISBN-10 / ASIN: 0750651547
    * ISBN-13 / EAN: 9780750651547
    This handbook helps engineers in industry with the operation and maintenance of machinery. It provides the information that these engineers need in a form that is instantly accessible and easy to read.
    The manufacturers of machinery give guidelines on the operation, lubrication and maintenance required for their particular equipment. There are however many different machines in an industrial plant or service organisation, often supplied by many different manufacturers, and there is a need to select as many similar lubricants as possible and to use related machine techniques. This book bridges the gap which exists between the available data on the various machines by providing overall guidance on how to co-ordinate the recommendations of the various equipment makers.
    The book is structured in a number of sections that will make it easier to use, and to bring together related topics so that when a reader is focusing on a particular problem they can also refer to related material that is also likely to be of interest.
    THE handbook for an industrial audience consisting of plant engineers and maintenance managers. It describes the essential theory and practice relating to matters of lubrication and reliability.
    Unique layout and presentation of information makes this one of the best practical reference books available
    http://mihd.net/4ue5z1
    http://www.mediafire.com/?9q99bzygqy4
    http://rapidshare.com/files/86674830/LubReliaHan.rar.html
  6. [56]
    أهل الحديث
    Received: 205
    Given: 261
    The Maintenance Management Framework
    Models and Methods for Complex Systems Maintenance
    (Springer Series in Reliability Engineering)
    By Adolfo Crespo Márquez
    * Number Of Pages: 333
    * Publication Date: 2007-06-25
    * ISBN-10 / ASIN: 1846288207
    * ISBN-13 / EAN: 9781846288203
    The Maintenance Management Framework describes and reviews the concept, process and framework of modern maintenance management of complex systems; concentrating specifically on modern modelling tools (deterministic and empirical) for maintenance planning and scheduling. It presents a new perspective of maintenance management by:
    focusing on the course of maintenance actions;
    presenting a structure that ensures proper support for current maintenance managers;
    clarifying the functionality that is required from information technology when applied to maintenance and the functions of modern maintenance engineering; and
    creating a set of practical models for maintenance management planning and scheduling.
    The discussion of all of these issues is supported through the use of case studies.
    The Maintenance Management Framework will be beneficial for engineers and professionals involved in: maintenance management, maintenance engineering, operations management, quality, etc. It will also be of interest to graduate students and researchers in this field.
    3.528 MB
    http://www.filefactory.com/file/95812d/
    http://rapidshare.com/files/88346342/The_Maintenance_Management_Framework.pdf
  7. [57]
    أهل الحديث
    Received: 205
    Given: 261
    CRC Handbook of Lubrication: Theory and Practice of Tribology, Volume II
    Handbook of Lubrication: Theory and Practice of Tribology, Volume II (Handbook of Lubrication)
    By E. Richard Booser
    * Publisher: CRC-Press
    * Number Of Pages: 704
    * Publication Date: 1989-02-01
    * ISBN-10 / ASIN: 0849339022
    * ISBN-13 / EAN: 9780849339028
    This handbook covers the general area of lubrication and tribology in all its facets: friction, wear lubricants (liquid, solid, and gas), greases, lubrication principles, applications to various mechanisms, design principles of devices incorporating lubrication, maintenance, lubrication scheduling, and standardized tests; as well as environmental problems and conservation. The information contained in these two volumes will aid in achieving effective lubrication for control of friction and wear, and is another step to improve understanding of the complex factors involved in tribology. Both metric and English units are provided throughout both volumes
    http://rapidshare.com/files/89327573...ubrication.zip
  8. [58]
    أهل الحديث
    Received: 205
    Given: 261
    Tribology on the Small Scale: A Bottom Up Approach to Friction, Lubrication, and Wear
    (Mesoscopic Physics and Nanotechnology)
    By C. Mathew Mate
    * Publisher: Oxford University Press, USA
    * Number Of Pages: 400
    * Publication Date: 2008-03-01
    * ISBN-10 / ASIN: 0198526784
    * ISBN-13 / EAN: 9780198526780
    Friction, lubrication, adhesion, and wear are prevalent physical phenomena in everyday life and in many key technologies. This book explains how these tribological phenomena originate from atomistic and microscale physical phenomena and shows how this understanding can be used to solve
    macroscale tribology problems. The book is intended to serve both as a textbook for advanced undergraduate and graduate courses in tribology and as an introduction to the field for those scientists and engineers working with technologies where a good grasp of tribology is essential.
    Rar'd PDF
    3.565 MB
    http://rapidshare.com/files/103013256/0198526784.rar
    http://www.filefactory.com/file/06eb35/
  9. [59]
    أهل الحديث
    Received: 205
    Given: 261
    Reliability-Centred Maintenance
    By John Moubray
    * Number Of Pages: 440
    * Publication Date: 1999-05
    * ISBN-10 / ASIN: 0750633581
    * ISBN-13 / EAN: 9780750633581
    RAR-ed DJVU file
    http://rapidshare.com/files/11323235...aintenance.rar
  10. [60]
    أهل الحديث
    Received: 205
    Given: 261
    Maintenance Planning and Scheduling Handbook
    By Richard D. Palmer
    * Publisher: McGraw-Hill Professional
    * Number Of Pages: 544
    * Publication Date: 1999-03-31
    * ISBN-10 / ASIN: 0070482640
    * ISBN-13 / EAN: 9780070482647
    * This guide enables facilities manages to dramatically improve the productivity of their maintenance plan
    * Clearly identifies the six basic principles of planning and the six associated principles of scheduling
    * Provides how-to information on implementing a planning function,
    using work orders, and performing in-house work sampling
    http://rapidshare.com/files/11487145...g_Handbook.rar
