Exploratory data analysis -Engineering Statistics Handbook
النتائج 1 إلى 3 من 3
    الصورة الرمزية يحي الحربي
    يحي الحربي
    يحي الحربي غير متواجد حالياً
    عضو فائق التميز
    Received: 16
    http://www.4shared.com/file/11729466...-CRC_786p.html
    How to use the Engineering Statistics Handbook
    Helpful hint Use your browser 'Back' button to return to the page you have just left.
    Use the graphic icon on the tool bar to go 'home' Home. A tool bar appears at the top and bottom of every page. The the graphic icon on the toolbar takes you to the main *******s page, from which each chapter can be reached, as well as Tools & Aids, and a detailed Table of *******s for the entire handbook.
    Use links to move to different levels in a chapter. Chapter navigation. At the top of each page, under the toolbar, there are a set of links that identify the chapter; chapter section; and chapter sub-section that you are currently in. These links can be used to move between levels within the chapter and back to the high level outline for the entire chapter.
    Use arrows to move betwen pages Page navigation. At the top and the bottom of every page there are navigation arrows to take you backward or forward one page. This navigational tool can be used to step through the entire Handbook.
    Download Dataplot and try the Handbook examples yourself Software.Use the free, downloadable software, Dataplot, that is integrated with the Handbook to analyze Handbook examples yourself. Many parts of the book feature case studies or short examples with computations from Dataplot. The Dataplot software can be downloaded from the Dataplot home page and installed on your system so you can run the software with sample data from the Handbook data or your own data. The full documentation for Dataplot is also accessible from the Dataplot home page.
    Activate Dataplot from a case study Running the Software. Dataplot is configured to automatically activate when you click any hyperlink under 'Run this Example Yourself' from a Handbook case study - provided your Web browser has been set up to call up Dataplot. Dataplot then brings up a separate screen which is divided into four windows:
    Upper left - Feedback and computational output
    Lower left - Dataplot commands as they are executed
    Upper right - Graphical output
    Lower right - Spreadsheet of data
    At the bottom of the screen is a wide, rectangular window where you can enter Dataplot commands to be executed.
    Once Dataplot is running it should be possible to click on the hyperlinks for each step in case study to continue the analysis without exiting the software.
    To exit Dataplot when finished with an analysis, click on the Exit button on the menu bar.
    Use Tools & Aids to find the place in the handbook where your problem is matched to a solution Problem/Solution Matching. If your problem is an engineering or scientific problem, try to match the questions you are interested in to the Handbook's list of:
    Engineering Questions.
    If you have already translated your problem into a statistical framework, look under the following aids for guidance:
    Gallery of Graphical Techniques
    Gallery of Analytical Techniques
    If you would like guidance on your problem via a real-life situation, try looking at the:
    Gallery of Case Studies.
    All of these items can be found under Tools & Aids on the Home page.
    For in-depth outline Go to the Detailed Table of *******s from the Home page.
    For a specific topic Click on 'Search Handbook' under Tools & Aids on the Home page.
    أهل الحديث
    أهل الحديث غير متواجد حالياً
    Received: 205
    Given: 261
    جزاك الله خيرآ أخى يحى
    { الَّذِينَ آتَيْنَاهُمُ الْكِتَابَ يَعْرِفُونَهُ كَمَا يَعْرِفُونَ أَبْنَاءَهُمُ }
    خلوف العراقي
    خلوف العراقي غير متواجد حالياً
    الصورة الرمزية خلوف العراقي
    Received: 137
    Given: 54
    جزاكم الله خيرا
    اللهم احفظ العراق واهله
    Trust me I 'm Engineer
    ابن ناصريه العراق
    محاضرات رائعه فيديوا صوت وصوره لجميع مناهج الهندسه المدنية على هذه الروابط
