Autodesk AutoCAD 2006 Training
النتائج 1 إلى 10 من 13
    en_ess78
    en_ess78 غير متواجد حالياً
    Our training tutorial on Autodesk AutoCAD software is used by industry professionals such as the film movie business, 3d animators, 3d modelers, animation specialist, game designers, architect designers, engineers.
    AUTOCAD 2006 Volume 1
    Introduction
    The Workspace
    What is the Document?
    The Command Prompt
    Saving
    Working In AutoCAD
    Setting up Units
    Navigating
    Drawing a Line
    Drawing Objects
    MOdifying Tools
    Move, Rotate, Scale
    Cut, Copy And Paste
    Mirror And Offset
    Stretch, Trim, Explode
    Joining And Grouping
    Fillet
    Chamfer
    Grouping
    Ungrouping
    Hatch Patterns And Fills
    Hatch User Defined
    Hatch Predefined
    Hatch Options
    Colored Hatches
    Tips And Tricks
    Gradients
    Drawing Order
    UCS
    What We Have Learned
    Volume 2
    Drawing Area
    Quadrants
    Drawing Limits
    Grid
    Digital T And Triangles
    Review
    Introduction
    Offset & lines
    Polygons
    Trim
    Working with Copies
    Setting Up
    Creating Objects
    Creating An Array
    Last Array
    3d Illusion
    Different Objects
    Creating Perfect Sqaures
    Connecting Corners
    Exploding
    Dimensions
    Linear Dimensions
    Aligned
    Jogged And Angle
    Dimensions
    Text
    Intro to Text
    Formatting
    Advanced Formatting
    Options
    Volume 3
    More 2d
    2d Work
    Basics
    2d Tricks
    2d 3d Objects
    Introduction to 3d
    Introduction
    3d Surface Presets
    Creating A 3d Object
    Adding Caps
    Solids And Surfaces
    Difference in Objects
    Difference in Polylines
    Difference in Splines
    Types of Shades
    Rendering
    Render
    Render Prefrences
    Background
    Fog/Depth
    Modifying in 3d
    Basic Tools
    3d Rotate
    2d Array And 3d Array
    2d Mirror And 3d Mirror
    Modeling Tips & Tricks
    Polyline to Spline
    Polyline to Spline Cont.
    Subtracting Objects
    Adding And Intersecting
    Volume 4
    Creating 3d Objects
    Introduction
    Recreating
    Duplicate Array
    Adding/Subtracting
    Creating the Buzzsaw
    2d to 3d Tricks
    Extruding
    Adding/Subtracting
    Dimensioning/Layers
    Wrench
    Introduction
    Adding
    Creating the Polygon
    Subtracting
    3d Meshes
    Ruled Surface
    Tabulated Surface
    Lathe
    Surftabs
    Custom Views
    3d Orbit And Options
    More Options
    Saving Views
    Rendering to Views
    Lights
    Introduction
    Showing And Modifying
    Setting Up the Scene
    Final Render
    Volume 5
    Layers
    Introduction
    Locking/Visability
    More Layers
    Layer Properties Manager
    Blocks
    Creating A Block
    Inserting A Block
    Files as Blocks
    Saving Blocks as Files
    Materials
    Introduction
    Material Library
    Importing
    Mapping
    Viewports And Layout
    Introduction
    Adding A Viewport
    Multiple Viewports
    Adjusting Views
    Tips & Tricks
    Locking Viewports
    Scaling in Layout
    Print Setup
    Publish to Plot
    File Management
    Saving
    Importing
    Exporting
    Help
    واخيرا الروابط
    en_ess78
    Post ايضاح
    الموضوع منقول
    Borgitti
    Borgitti غير متواجد حالياً
    مشششكوووووووور
    a7med4u
    a7med4u غير متواجد حالياً
    مشششكوووووووور
    a7med4u
    جزاك الله خيرآ أخى الفاضل
    عبدومحمد
    عبدومحمد غير متواجد حالياً
    جعلة اللة في ميزان حسناتك
    محمد_الدوسري
    محمد_الدوسري غير متواجد حالياً
    جزاك الله خيرا ً اخي العزيز
    هل هناك طريقة لتخطي الرابت شير.. او هل توجد هذه الملفات على رابط آخر
    usama_2006
    usama_2006 غير متواجد حالياً
    جعلة اللة في ميزان حسناتك ,
    و جزاكى الله كل خير اختى الفاضلة .
    روعة
    روعة غير متواجد حالياً
    كيف احمل برنامج الاتوكاد اخواني الرابط لو سمحتوا
    Ahmed Abuhajjeh
    Ahmed Abuhajjeh غير متواجد حالياً
    انتظار
    شكرا جزيلا
