Learning ANSYS by flash video
النتائج 1 إلى 10 من 29
    newhak
    newhak غير متواجد حالياً
    copy the links below in flashget and download them to your computer
    there are 26 flash tutorials
    links
    http://www.ansys.com/techmedia/1-create_rectangle.swf
    http://www.ansys.com/techmedia/1-define_rectangles.swf
    http://www.ansys.com/techmedia/2-add_hole_circles.swf
    http://www.ansys.com/techmedia/2-cha...and_replot.swf
    http://www.ansys.com/techmedia/3-cha...rst_circle.swf
    http://www.ansys.com/techmedia/3-dim...le_circles.swf
    http://www.ansys.com/techmedia/4-display_name.swf
    http://www.ansys.com/techmedia/4-mov...ond_circle.swf
    http://www.ansys.com/techmedia/5-add_areas.swf
    http://www.ansys.com/techmedia/5-generate_3_d.swf
    http://www.ansys.com/techmedia/6-change_dimension.swf
    http://www.ansys.com/techmedia/6-create_line_fillet.swf
    http://www.ansys.com/techmedia/7-add_3d_blend.swf
    http://www.ansys.com/techmedia/7-create_fillet_area.swf
    http://www.ansys.com/techmedia/8-add_areas_together.swf
    http://www.ansys.com/techmedia/8-gen...parameters.swf
    http://www.ansys.com/techmedia/9-cre...t_pin_hole.swf
    http://www.ansys.com/techmedia/9-run_in_ds.swf
    http://www.ansys.com/techmedia/10-mo...d_pin_hole.swf
    http://www.ansys.com/techmedia/11-su...om_bracket.swf
    http://www.ansys.com/techmedia/12-save_as_model_db.swf
    http://www.ansys.com/techmedia/13-set_preferences.swf
    http://www.ansys.com/techmedia/14-de...properties.swf
    http://www.ansys.com/techmedia/15-de...nd_options.swf
    http://www.ansys.com/techmedia/16-de..._constants.swf
    http://www.ansys.com/techmedia/17-mesh_the_area.swf
    http://www.ansys.com/techmedia/18-save_as_mesh_db.swf
    http://www.ansys.com/techmedia/19-ap...onstraints.swf
    http://www.ansys.com/techmedia/20-ap...ssure_load.swf
    http://www.ansys.com/techmedia/21-solve.swf
    http://www.ansys.com/techmedia/22-en...ad_results.swf
    http://www.ansys.com/techmedia/23-pl...rmed_shape.swf
    http://www.ansys.com/techmedia/24-pl...eqv_stress.swf
    http://www.ansys.com/techmedia/25-li...n_solution.swf
    http://www.ansys.com/techmedia/26-exit_ansys_pgm.swf
    Please note this post from brother New Tiger Damasgate
    AC MILAN
    AC MILAN غير متواجد حالياً
    الصورة الرمزية AC MILAN
    بارك الله فيــك
    sususordo
    sususordo غير متواجد حالياً
    i cant download these links,plz help me ..
    how can i copy these in flashget??!! and what is it??!!
    thank u..
    لكل شيء إذا ما تم نقصان
    فلا يغر بطيب العيش إنسـان
    هي الأيام كما شاهدتها دول
    من سره زمن سأتـه أزمــان
    MUSLIM125
    MUSLIM125 غير متواجد حالياً
    جزاك الله خيرا
    أما بالنسبة لمن لا بعرف كيف يحملها ,يمكنه ذلك عن طريق برنامج flashget or Download Accelerator
    الخطوات
    خذ هذه الروابط Copy
    افتح من القائمةDownloads
    من قائمة Downloads اضغط add new download
    تفتح لك خانة (كليك يمين فى الفراغ) ثم اعمل Paste
    انتظر قليلا تجد الداونلود أكسيليريتور يحمل الملفات
    قدمونا
    قدمونا غير متواجد حالياً
    وضحّ اكتر لو سمحت وجزاك الله خيراً
    .:llrarll:.
    .:llrarll:. غير متواجد حالياً
    شكرا جزيلا للاخ newhak
    Thanks a lot for you E. newhak
    وبالنسبة للاخوان اللي مو عارفين يحملوا الروابط
    الطريقة كالاتي:
    1) ضع مؤشر الفارة على الرابط.
    2) اضغط زر الفارة الايمن.
    3) من القائمة المنسدلة اختر ( حفظ الهدف بإسم).
    4) ضع الملف في المكان الذي تريد الحفظ فيه.
    ملاحظة يجب ان يكون لديك برنامج:
    flash macromedia
    لتشغيل الروابط
    اتمنى يكون شرحي واضح
    وأي خدمة انا جاهز
    matardk
    matardk غير متواجد حالياً
    شكرا جزيلا
    amd479
    amd479 غير متواجد حالياً
    thanks for all this link for ansys
    الموحد
    الموحد غير متواجد حالياً
    الصورة الرمزية الموحد
    Thank you very much
    ماجد جلميران
    ماجد جلميران غير متواجد حالياً
    الصورة الرمزية ماجد جلميران
    مشكووووووووووووووووووووووووووووووووووووووووووور
