فيروس Godzilla
النتائج 1 إلى 3 من 3
    جامعي ولكن
    جامعي ولكن غير متواجد حالياً
    فيروس Godzilla
    اعاني من وجود هذا الفيروس في جهازي ارجوا المساعدة
    للعلم يضهر على كل صفحة انترنت افتحها Hacked by Godzilla
    engramy
    engramy غير متواجد حالياً
    الصورة الرمزية engramy
    Received: 12
    أخي العزيز لا تقلق فالحل سهل إن شاء الله.
    It seems to be exploiting the fact that autorun is not generally disabled in XP for USB drives. I got it from the night school i attend bringing my homework home.
    It doesn't seem to do any harm apart from sticking a stupid message up in internet explorer. None of the virus detectors currently detect it.
    There is apparently a small program written to remove this but i cant find it on the web at the moment
    You need to open the disk explorer and set your file options to see everything (including system files).
    Right click on each disk drive and USB drive you use and go into them using explore. Do NOT double click on them as this runs the autorun and script.
    On each drive you will find
    Autorun.inf
    MS32DLL.dll.vbs
    You will also find these files in the /Windows directory
    Delete them all - make sure you check any USB drives you may have used since you got the problem.
    Run Regedit and search for Godzilla. Delete that key or change it to something you prefer.
    Normal caution should apply to all steps. If you dont know what you are doing find someone who does
    engramy
    Received: 12
    ويمكنك إستخدام الـ godzilla remove tools وهي موجود في المرفقات
    برجاء الرد إذا كانت المشكلة إنتهت أم لم تنتهي
