اخواني بحاجة لمساعدة مدفوعة الثمن في proengineer
النتائج 1 إلى 8 من 8
    ابو بيان
    ابو بيان غير متواجد حالياً
    اخواني عندي Assingment في Proengineer واحتاج لمساعدة ومستعد للدفع مقابل الجهد
    tahreer
    tahreer غير متواجد حالياً
    pro-engineering
    hi,
    something i found about pro-engineering
    An Overview of Pro/ENGINEER
    The Foundation of Pro/ENGINEER
    What is Pro/ENGINEER?
    Pro/ENGINEER is a computer graphics system for modeling various mechanical designs and
    for performing related design and manufacturing operations. The system uses a 3D solid
    modeling system as the core, and applies the feature-based, parametric modeling method.
    In short, Pro/ENGINEER is a feature-based, parametric solid and surface modeling system
    with many extended design and manufacturing applications.
    Pro/ENGINEER and Features of Advanced CAD System
    Pro/ENGINEER is the first commercial CAD system entirely based upon the feature-based
    design and parametric modeling philosophy. Today most software producers have
    recognized the advantage of this approach and changed their products onto this platform.
    Nevertheless, the differences between a feature-based, parametric solid modeling CAD
    system, such as Pro/ENGINEER, and a conventional CAD system include:
    Advanced CAD System Conventional CAD System
    Solid Model Wireframe and Solid Model
    Parametric Model Fixed Model
    Feature-Based Modeling Primitive-Based Modeling
    Single Data Structure and Full and
    Associativity
    Function-Oriented Data Structure Format
    Interpreters
    Subject-oriented, sub-modeling Systems A Single Geometry-based System
    Manufacturing Information Associated with
    Features
    Texts Attached to Geometry Entities
    Generation of an Assembly by Assembling
    Components
    Generation of an Assembly by Positioning
    Components
    Integrated Surface Model
    An Overview
    • Ease of Use: Pro/ENGINEER was designed to begin where the design engineer begins with
    features and design criteria. Over the years, a menu system and style that are compatible to
    the Windows operation have been developed. Pro/ENGINEER provides the ability to sketch
    directly on the solid model, feature placement is simple and accurate.
    • Full Associativity: Pro/ENGINEER is based on a single data structure, with the ability to
    make change built into the system. Therefore, when a change is made anywhere in the
    development process, it is propagated throughout the entire design-through-manufacturing
    process, ensuring consistency in all engineering deliverables.
    • Parametric, Feature-Based Modeling: Pro/ENGINEER's features contain non-geometric
    information, such as manufacturing processes and associated costs, as well as information
    about location and relationships. This means that features do not require coordinate systems
    for placement, and they "know" how they are related to the rest of the model. As a result,
    changes are made quickly and always adhere to the original design intent.
    • Powerful Assembly Capabilities: Assembling components is easy with Pro/ENGINEER
    Simply tell the system to "mate," "insert," or "align" the components and they are assembled,
    always maintaining the design intent. Also, the components "know" how they are related, so
    if one changes, either positionally or geometrically, the other will change accordingly. Parts
    can be designed right in the assembly and defined by other components, so if they move or
    change size, the part will automatically update to reflect the change.
    • Robustness: The Pro/ENGINEER family of products is based on a double precision, nonfaceted
    solid modeling core. This provides the engineer with the most accurate representation
    of geometry, mass properties, and interference checking available.
    • Change Management: Powerful change capabilities are inherent with Pro/ENGlNEER full
    associativity, enabling design-through-manufacturing disciplines to execute their functions in
    parallel. Tools for parametric data management successfully manage these simultaneous
    processes and promote an organized, controlled workflow.
    • Hardware Independence: Pro/ENGINEER runs on all of the major UNIX and Windows
    NT platforms, maintaining the same look and feel on every system.
    Pro/ENGINEER Functionality
    The basic functionality of Pro/ENGINEER is broken into several areas:
    • Part Design
    ◊ Create sketched features including protrusions, cuts, and slots made by either extruding,
    revolving sweeping along a 2D sketched trajectory, or blending between parallel sections
    ◊ Create "pick and place features, such as holes, shafts, chamfers, rounds, shells, regular
    drafts, flanges, ribs, etc.
    ◊ Sketch cosmetic features
    ◊ Reference datum planes, axes, points, curves, coordinate systems, and graphs for creating
    non-solid reference datum
    ◊ Modify, delete, suppress, redefine, and reorder features, as well as making features "readonly"
    ◊ Create table-driven parts by adding dimensions to the family table
    ◊ Capture design intent by creating relations between part dimensions and parameters
    ◊ Generate engineering information, including mass properties of parts, model cross
    sections, and reference dimensions
    ◊ Create geometric tolerances and surface finishes on models
    ◊ Assign density, units, material properties or user-specified mass properties to a model
    ◊ Additional functionality available through Pro/FEATURE.
    • Assembly Design
    ◊ Place components and subassemblies using commands like mate, align, and insert to
    create full product assemblies
    ◊ Disassemble components from an assembly
    ◊ Modify assembly placement offsets
    ◊ Create and modify assembly datum planes, coordinate systems, and cross sections
    ◊ Modify part dimensions in assembly mode
    ◊ Generate engineering information, bills of materials, reference dimensions, and assembly
    mass properties
    ◊ Additional functionality available through Pro/ASSEMBLY.
    • Design Documentation (Drawings)
    ◊ Create numerous types of drawing views, including general, projection, auxiliary,
    detailed, exploded, partial, area cross-section, and perspective
    ◊ Perform extensive view modifications, including changing the view scale and the boundaries
    of partial or detailed views, adding projection and cross-section view arrows, and
    creating snapshot views
    ◊ Create drawings with multiple models, delete a model from a drawing, set and highlight
    the current model of a drawing
    ◊ Use a sketch as a parametric drawing format
    ◊ Manipulate dimensions, including show, erase, switch view, flip arrows, move dimensions,
    text, or attach points
    ◊ Modify dimension values and number of digits
    ◊ Create, show, move, erase, and switch view for standard notes
    ◊ Include existing geometric tolerances in drawing notes
    ◊ Update the model geometry to incorporate design changes
    ◊ Export a drawing IGES file
    ◊ Markup drawings to indicate changes to be made
    ◊ Additional functionality available through Pro/DETAIL.
    • General Functionality
    ◊ Database management commands
    ◊ Layer control for placing items on a layer and displaying layers
    ◊ Measuring commands for distance, geometric information angle, clearance, and global
    interference on parts and assemblies
    ◊ Viewing capabilities to pan, zoom, spin, shade, and re-orient models and drawings.
    The Function Modules of Pro/ENGINEER
    The core of Pro/ENGINEER is the feature-based, parametric solid modeling system for
    modeling mechanical parts. The part model created by this system can be used to form
    mechanical assemblies and to produce engineering drawings. The model can also be used to
    carry out other related manufacturing activities such as the generation of CNC tool paths and
    Bills of Material.
    BASIC MODE DIESCRIPTION
    Sketcher Define the 2D cross-section (or section) of an object model for sweeping.
    Part Create the solid model of a part.
    Assembly Form the solid model of an assembly of multiple components.
    Drawing Produce engineering drawings of parts and assemblies created in
    Pro/ENGINEER. These drawings are fully associative with the 3D solid
    model. When a dimension in the drawing is changed the dimension of the
    associated 3D model(s) will be automatically updated, and vice versa.
    Manufacture Define the machining operations that are required to manufacture a part
    modeled using Pro/ENGINEER.
    These are frequently used Pro/ENGINEER modes. Their functions in modeling a mechanical
    design are illustrated in Figure 1.
    Figure 1. Commonly Used Function Modes of Pro/ENGINEER
    All products of Pro/ENGINEER and Different Modes of Pro/ENGINEER Wildfire include:
    Pro/ENGINEER Detailed Design (CAD)
    Pro/ENGINEER Flex3C
    Pro/ENGINEER Foundation Advantage
    Pro/ENGINEER Advanced Assembly
    Pro/ENGINEER API Toolkit
    Pro/ENGINEER Design Collaboration
    Pro/ENGINEER Expert Framework
    Pro/ENGINEER Student Edition
    Pro/ENGINEER Simulation (Analysis and Result Display) (CAE)
    Pro/ENGINEER Advanced Structural and Thermal
    Pro/ENGINEER Structural and Thermal
    Pro/ENGINEER Fatigue Advisor
    Pro/ENGINEER Mechanism Dynamics
    Pro/ENGINEER Behavioral Modeling
    Pro/ENGINEER Production (CAM)
    Pro/ENGINEER Complete Mold Design
    Pro/ENGINEER Complete Machining
    Pro/ENGINEER Computer-Aided Verification
    Pro/ENGINEER Expert Moldbase
    Pro/ENGINEER NC Sheetmetal
    Pro/ENGINEER Plastic Advisor
    Pro/ENGINEER Prismatic and Multi-surface Milling
    Pro/ENGINEER Production Machining
    Pro/ENGINEER Progressive Die
    Pro/ENGINEER Tool Design
    Pro/ENGINEER Routed Systems
    Pro/ENGINEER Routed Systems Designer
    Pro/ENGINEER Piping Design
    Pro/ENGINEER Cabling Design
    Pro/ENGINEER Workgroup Data Management
    Pro/INTRALINK
    Windchill Pro/ENGINEER Extension
    Pro/ENGINEER Conceptual and Industrial Design
    Pro/CONCEPT
    Pro/ENGINEER Advanced Rendering
    Pro/ENGINEER Interactive Surface Design
    Pro/ENGINEER Reverse Engineering
    eDrawings for Pro/ENGINEER
    Windchill
    Windchill PDMLink
    Windchill ProjectLink
    Windchill PartsLink
    Windchill Integrations
    Windchill MCAD & ECAD Integrations
    Windchill Enterprise Systems Integrations
    Windchill DynamicDesignLink
    Windchill ProductView
    Pro/MECHANICA
    Pro/DESKTOP
    DIVISION
    DIVISION Mockup
    DIVISION ProductView
    DIVISION Reality
    CADDS 5i
    CADDS 5i Modeling Foundation
    CADDS 5i Mechanical
    CADDS 5i Shipbuilding
    CADDS 5i Data Exchange
    CADDS 5i Optegra
    DIMENSION III
    Granite Interoperability Kernel
    Harmony
    InterComm
    InterComm Expert
    InterComm EDAcompare
    InterComm EDAconduit
    PLM Solutions
    Product Development System
    Product Lifecycle Management (PLM)
    Product First
    Documentation and On-line Help
    • Pro/ENGINEER Wildfire 2.0 Resource Center
    The Resource Center appears each time when one starts Pro/ENGINEER Wildfire 2.0. It
    can be accessed at:
    http://www.ptc.com/community/proewf2/newtools/index.htm
    Pro/ENGINEER Wildfire 2.0 User Tools
    Menu Mapper
    Learn the improved menu structure of
    Pro/ENGINEER Wildfire. Get detailed menu paths
    from Release 2000i2, 2001 or Wildfire to Wildfire
    2.0.
    Personal Productivity Tools
    Learn about new tools to help you work faster and
    smarter and get your job done in record time.
    Process Productivity Tools
    Simplify and accelerate the way you work by
    combining Pro/ENGINEER Wildfire 2.0 with
    Windchill solutions.
    Pro/ENGINEER Wildfire 2.0 Tutorials
    Take a look at the growing number of tutorials available to help you become a better
    Pro/ENGINEER Wildfire 2.0 User.
    Selection Tutorial
    Increase productivity when you master the new
    selection tools.
    Wildfire 2.0 Tutorial for Existing Users
    Get up to speed quickly with all the new
    improvements.
    Wildfire 2.0 Tutorial for New Users
    improvements.
    Getting Started with Pro/ENGINEER Wildfire 2.0
    This downloadable guide provides guidance for new
    users about navigation and workflow in
    Pro/ENGINEER Wildfire to increase productivity.
    Through a series of exercises to create a cell phone
    model, you see how Pro/ENGINEER Wildfire
    passes 3D design information from solid part
    creation, to part assembly, to a detailed drawing.
    Pro/ENGINEER Wildfire Help Tools
    Quick Reference Card (pdf, 1.07 MB)
    Print the full color quick reference card as
    a handy reference for toolbars, selection
    and controls.
    Feature Creation Guide
    Become familiar with the new feature
    creation tools that simplify the design
    process by reducing mouse clicks and
    consolidating similar commands.
    Pro/ENGINEER Wildfire 2.0 Help
    Topic Collections
    For each Help module of Pro/ENGINEER
    Wildfire, you can find a PDF file on the
    Reference Documents page.
    • Pro/ENGINERR On-line Tutorials from MECH410 home page at:
    http://www.me.uvic.ca/~mech410/proe_tutorials.html
    Brief tutorials for various releases of Pro/ENGINERR are posted.
    • Schroff Development Corp. (SDC) Professional Bookstore
    http://www.schroff.com/
    Books for Pro/ENGINEER Wildfire 2.0
    o Introduction to Pro/ENGINEER Wildfire 2.0
    o Design Modeling with Pro/ENGINEER
    o Modeling with Pro/ENGINEER
    o Mechanical Engineering Design with Pro/ENGINEER
    o Parametric Modeling with Pro/ENGINEER
    o Pro/ENGINEER Tutorial & MultiMedia CD
    o Pro/ENGINEER Advanced Tutorial
    o Design Process Management using Pro/INTRALINK
    o Design for Manufacturing with Pro/MANUFACTURING
    o Pro/MANUFACTURING Tutorial
    o Pro/MECHANICA Structure Tutorial
    o Pro/MECHANICA Structure: Elements and Applications
    o Pro/MECHANICA Structure: Elements and Applications - Part 2
    o Pro/MECHANICA Motion - Mechanism Design and Analysis
    o An Introduction to Pro/SHEETMETAL
    o Applications in Sheet Metal: Using Pro/SHEETMETAL and Pro/ENGINEER
    tahreer
    another document
    m7mad_issa
    m7mad_issa غير متواجد حالياً
    عندي ملفات pdf +eXAmple
    if u need send to me
    m7mad_issa
    hi
    this Example of pdf
    lido_cad
    lido_cad غير متواجد حالياً
    Thumbs up Lido_cad***********
    اي حد عنده اي مشكلة في التعامل مع برنامج البرو انا تحت امره
    في اي موديول
    eng-saidsabry
    eng-saidsabry غير متواجد حالياً
    شكرآ على هذة المعلومات ولكننا نريد معرفة المزيد عن برنامج البرو
    sam19815050
    sam19815050 غير متواجد حالياً
    حدد الموضوع وانا باذة الله اسعدك
