للمهندسين، المحترفين، الباحثين، و التقنيين،.. I-deas Nx12m2
النتائج 1 إلى 3 من 3
    hassananas
    hassananas غير متواجد حالياً
    Received: 224
    Given: 6
    للمهندسين، المحترفين، الباحثين، و التقنيين،.. I-DEAS NX12M2
    I-deas NX MasterFEM builds on a 30-year CAE heritage and is a full function, industrial-strength simulation environment suitable for both general engineering use and the most demanding CAE specialist. MasterFEM can be relied upon as a standalone simulation environment or seamlessly integrated within NX.
    MasterFEM provides comprehensive set of capabilities and world-class technology for building finite element models and understanding finite element simulation results. It includes the ability to create and modify 3D geometry and surfaces for the purposes of geometry abstraction and finite element modeling. There are two solvers to choose from -- the production proven Model Solution and the industry standard NX Nastran.
    Data input can be accepted from a wide variety of geometry creation sources, as well as industry standard data exchange formats such as IGES, STEP, VDA, JAMA-IS, STL and JT. I-deas NX MasterFEM also has direct interfaces available for MSC.Nastran, ABAQUS, ANSYS, PAM-CRASH, RADIOSS and LS-DYNA.
    Many powerful tools are available within MasterFEM to automate and increase the efficiency of the CAE process. Wireframe, surface and solid geometry can all be used simultaneously in finite element model generation. Free meshing, mapped meshing and manual mesh generation techniques as well as automated tet-based meshing for 3D solid parts are all available in conjunction with unique surface abstraction and section meshing capabilities. Automated tools for checking the quality of elements, mesh smoothing and applying loads and boundary conditions are also included.
    MasterFEM post-processing functions enable the recovery of analysis results and provide extensive graphical and numerical tools, enhancing the understanding of the analysis.
    The user interface can be tailored specifically to the targeted solver, making it easy for the user to understand the finite element model characteristics in solver language familiar to the user. Comprehensive material and physical property definition are included, making MasterFEM the core module for a full multi-CAD, multi-physics digital simulation suite of tools.
    Best in class applications built-in to MasterFEM include composite modeling and analysis, thermal modeling and analysis, durability and fatigue, and world class response dynamics. Add-on applications available include vibro-acoustics and test result correlation.
    Please follow the links below for further Information on the following topics:
    I-deas NX MasterFEM
    Direct Connections to many popular third-party CAD and CAE packages
    Material Catalogs
    NX Laminates Composites Fact Sheet
    NX MasterFEM TMG Thermal/Radiation Fact Sheet
    NX Durability Fact Sheet
    NX Advanced Durability Fact Sheet
    NX Electronic System Cooling Fact Sheet
    NX Response Analysis Fact Sheet
    Integrated Structural Solutions
    Integrated Thermal Solutions
    http://www2.oxedion.com/index.php/d...391153333d7d1ca
    سعر البرنامج في السوق: 1000,000 دولار
    Belive it or Not
    lejuste02
    lejuste02 غير متواجد حالياً
    salam
    this link it's not avaible
    can you confim new link please
    thank you because I-deas is very intresting
    sincerly
    Mu7ammad
    Mu7ammad غير متواجد حالياً
    Received: 8
    تم غلــق الموضوع
    ... لتوقف الروابط ...
    مع الشكر والتقدير
    والله ولى التوفيق
    .... فهــــــــــــرس ملتقــــــــــى البرامـــــــــج ....
    ... اعتــــــذر عن عدم التواجد ...
    ... العين تقراء السطور ... والعقل يقراء ما بين السطور ...
