معجم هندسة التعدين(u)
النتائج 1 إلى 2 من 2
    علاء الهدي
    علاء الهدي غير متواجد حالياً
    Illustrated Mining Terms
    U
    Ultimate analysis - Precise determination, by chemical means, of the elements and compounds in an ore..
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20U_files/a_vanso.jpg[/IMG]
    Undercut - To cut below or undermine the face by chipping away the ore by pick or mining machine. In some localities the terms "undermine" or "underhole" are used.[IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20U_files/ucuta.jpg[/IMG]Underground mine – Also known as a "deep" mine. Usually located several hundred feet below the earth's surface, an underground mine's coal is removed mechanically and transferred by shuttle car or conveyor to the surface.
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20U_files/model1.gif[/IMG]
    Underground station - An enlargement of an entry, drift, or level at a shaft at which cages stop to receive and discharge cars, personnel, and material. An underground station is any location where stationary electrical equipment is installed. This includes pump rooms, compressor rooms, hoist rooms, battery-charging rooms, etc.[IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20U_files/pic6.gif[/IMG]Unit train – A long train of between 60 and 150 or more hopper cars, carrying only coal between a single mine and destination.
    Universal coal cutter - A type of coal cutting machine which is designed to make horizontal cuts in a coal face at any point between the bottom and top or to make shearing cuts at any point between the two ribs of the place. The cutter bar can be twisted to make cuts at any angle to the horizontal or vertical.
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20U_files/cont.gif[/IMG]
    Upcast shaft - A shaft through which air leaves the mine.
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20U_files/LAK00756.jpg[/IMG]
    Return to TERMS MENU
    عربي نت
    عربي نت غير متواجد حالياً
    بارك الله فيك
