اسطوانه تعليميه 3.1g للتدريب على الفوتوشوب
النتائج 1 إلى 2 من 2
    bondok
    bondok غير متواجد حالياً
    Total Training Masters Collection Advanced
    INFO:
    Total Training Master Collection:
    Advanced Adobe® Photoshop® CS2
    Program 1: Advanced Training For Adobe Photoshop CS2
    0. Setting up 'Shop (25 min)
    Lesson 1: Customizing Preferences
    Lesson 2: Optimizing Color Settings
    Lesson 3: Customizing Keyboard Shortcuts
    Lesson 4: Working in Different Color Spaces
    Lesson 5: Customizing the Info Palette
    Lesson 6: Changing the Background Color
    Lesson 7: Saving Preference Settings
    1. Advanced Levels and 16 Bit (46 min)
    Lesson 1: Introducing Levels & 16 Bit
    Lesson 2: Using the Levels Command
    Lesson 3: Restoring an Image after Adjusting Levels
    Lesson 4: Targeting Shadows & Highlights
    Lesson 5: Setting the Black Point to Match a Target
    Lesson 6: Setting the White Point to Match a Target
    Lesson 7: Adjusting Flesh Tones by Setting the Gray Point
    Lesson 8: Downsampling & Saving for Print
    2. The Bridge and Camera RAW (43 min)
    Lesson 1: Viewing .DNG Images in Bridge
    Lesson 2: Using the White Balance & Color Sampler Tools
    Lesson 3: Adjusting Temperature & Tint
    Lesson 4: Adjusting Exposure & Shadow Levels
    Lesson 5: Adjusting Brightness, Contrast & Saturation
    Lesson 6: Cropping & Upsampling Images
    Lesson 7: Viewing Image Metadata
    Lesson 8: Opening & Saving .DNG Images in Photoshop
    Lesson 9: Editing Multiple Images at Once in Camera Raw
    Lesson 10: Cropping a Group of Images
    Lesson 11: Copying & Pasting Camera Raw Settings
    Lesson 12: Accessing & Purging Cache Files
    3. The Wonders of HDR (37 min)
    Lesson 1: Applying the Levels Command to 16 Bit & 8 Bit Images
    Lesson 2: Applying the Curves Command to 16 Bit & 8 Bit Images
    Lesson 3: Introducing HDR
    Lesson 4: Downsampling with the Image Processor
    Lesson 5: Using the Merge to HDR Command
    Lesson 6: Adjusting the Exposure & Saving HDR Images
    Lesson 7: Downsampling HDR & Adjusting Hue/Saturation
    4. The Art of Sharpen (51 min)
    Lesson 1: Creating a Custom Sharpen
    Lesson 2: Applying the Unsharp Mask Command
    Lesson 3: Adjusting Basic Smart Sharpen Settings
    Lesson 4: Adjusting & Saving Advanced Smart Sharpen Settings
    Lesson 5: Creating a More Accurate Smart Sharpen
    Lesson 6: Using the Fade Command
    Lesson 7: Correcting Motion Blur
    Lesson 8: Sharpening with the Emboss Filter
    Lesson 9: Color Sharpening in Lab Color Mode
    Lesson 10: Color Sharpening with the Fade Command
    5. Adding Blur and Removing Noise (39 min)
    Lesson 1: Using Smart Sharpen to Fix Motion Blur
    Lesson 2: Using the Dust & Scratches Filter to Get Rid of Stray Hairs
    Lesson 3: Adding a Layer Mask to Bring Back Detail
    Lesson 4: Using the Layer Mask to Paint Away Noise inside the Skin
    Lesson 5: Using the Remove Noise Filter
    Lesson 6: Blending Layers in the Layer Style Dialog Box
    Lesson 7: Removing Compression Artifacts with the Reduce Noise Filter
    Lesson 8: Working with the New Surface Blur Filter
    Lesson 9: Getting Rid of Whiskers Using the Average Filter
    6. Mixing the Perfect Monochrome (53 min)
    Lesson 1: Using the Channel Mixer to Create an Autumnal Effect
    Lesson 2: Mixing Channels & Adjusting Blending Options
    Lesson 3: Converting an RGB Image to Grayscale Automatically
    Lesson 4: Creating a Grayscale Image Using the Channel Mixer
    Lesson 5: Using the Color Range Command to Create a Layer Mask
    Lesson 6: Balancing Source Channels
    Lesson 7: Punching up Luminosity Values Using the Curves Command
    Lesson 8: Flattening a Converted Grayscale Image
    Lesson 9: Converting to Grayscale in the Camera Raw Dialog Box
    Lesson 10: Cropping & Adjusting the Curves of a Grayscale Image
    Lesson 11: Editing Curves in the Camera Raw Dialog Box
    Lesson 12: Compositing Versions of a Grayscale Image
    7. Duotones, Spot Colors, and Gradient Maps (47 min)
    Lesson 1: Monochrome & Multi-Ink Monochrome Images
    Lesson 2: Converting Images to Duotones
    Lesson 3: Adjusting a Duotone Curve to Balance the Inks in an Image
    Lesson 4: Editing a Duotone
    Lesson 5: Loading Preset Duotones
    Lesson 6: Inspecting the Independent Channels of an Image
    Lesson 7: Adding Spot Colors to an Image
    Lesson 8: Saving an Image
    Lesson 9: Using Gradient Maps
    Lesson 10: Working with Deke's Predefined Gradients
    Lesson 11: Modifying Adjustment Layers
    8. Advanced Retouching Techniques (46 min)
    Lesson 1: Rotating a Canvas & Using Variations
    Lesson 2: Creating a Gradient Selection & Filling with History
    Lesson 3: Painting with the History Brush
    Lesson 4: Using the Healing Brush Tools
    Lesson 5: Using Color Range to Generate a Selection to Make a Patch
    Lesson 6: Filling in Seams of a Patch with the Healing Brush
    Lesson 7: Retouching Using the History Brush, Cloning & Fading
    Lesson 8: Adding Noise with the Healing Brush & Fading Opacity
    Lesson 9: Moving & Transforming a Selection from One Image to Another
    Lesson 10: Adjusting the Levels of One Image to Match Another
    Lesson 11: Merging Two Layers Using the Healing Brush
    Lesson 12: Using the Liquify Filter to Retouch an Image
    Lesson 13: Softening Transitions & Bolstering Shadows
    9. Vanishing Point (61 min)
    Lesson 1: Preparing to Use the Vanishing Point Filter
    Lesson 2: Creating a Grid
    Lesson 3: Adding Planes to a Grid
    Lesson 4: Editing an Image inside Vanishing Point
    Lesson 5: Healing Transformed Areas
    Lesson 6: Retouching Using the Stamp Tool
    Lesson 7: Pasting & Compositing with Vanishing Point
    Lesson 8: Adjusting Masks for Better Composites
    Lesson 9: Accounting for Different Perspectives
    Lesson 10: Pasting Text into Vanishing Point
    10. Smart Objects (37 min)
    Lesson 1: Placing an Illustrator® File as a Smart Object
    Lesson 2: Using Illustrator to Edit the *******s of a Photoshop File
    Lesson 3: Importing an Image into a Composition
    Lesson 4: Converting a Standard Layer to a Smart Object
    Lesson 5: Duplicating & Transforming Smart Objects
    Lesson 6: Applying Warp Transformations to Smart Objects
    Lesson 7: Modifying Smart Objects in the Liquify Dialog Box
    Lesson 8: Changing the Color of Smart Objects
    Lesson 9: Applying a Color Overlay to a Single Smart Object
    Lesson 10: Grouping Layers & Making Final Transformations
    وصله التورنت
    http://www.pioneerz.net/upload/20338_01170024250.jpg
    بعد الحصول على الوصله برجاء مسح (.JPG) من الاسم فتحصل على وصلة التورنت
    واعتذر عن هذه اللفه ولكنى لم استطيع رفع التورنت مباشره
    برجاء الدعاء لى ولوالدى
    mohamedsinger
    mohamedsinger غير متواجد حالياً
    شكرا جزيلا وجزاك الله خيرا
