Case Studies in Reliability and Maintenance (Wiley Series in Probability and Statisti
النتائج 1 إلى 10 من 13
    الصورة الرمزية Eng-Maher
    Eng-Maher
    Eng-Maher غير متواجد حالياً
    مشرف قسم الهندسة البحرية.
    Received: 103
    Given: 408
    Eng-Maher
    Received: 103
    Given: 408
    محتوى الكتاب
    *******s
    Contributors xvii
    Preface xxv
    1. Introduction and Overview 1
    Wallace R. Blischke and D. N. Prabhakar Murthy
    1.1. Introduction, 1
    1.2. Reliability, Maintenance, Maintainability, and Quality, 3
    1.3. History of Reliability and Maintainability, 9
    1.4. Applications, 10
    1.5. Life Cycle Concepts, 11
    1.6. Tools and Techniques for the Study of Reliability, 14
    1.7. Reliability and Maintenance Data and Analysis, 19
    1.8. Issues in Reliability and Maintenance, 23
    1.9. Case Studies: An Overview, 24
    References, 32
    PART A. CASES WITH EMPHASIS ON PRODUCT DESIGN 35
    2. Space Interferometer Reliability-Based Design Evaluation 37
    Donald H. Ebbeler, Jr., Kim M. Aaron, George Fox, and W. John Walker
    2.1. Introduction, 37
    2.2. Problem Description, 38
    2.3. Alternative Optical Interferometer Designs, 39
    2.4. Evaluation of Alternative Designs, 53
    viii *******S
    2.5. Interpretations, Conclusions, and Extensions, 59
    References, 60
    Exercises, 60
    Acronyms, 61
    3. Confidence Intervals for Hardware Reliability Predictions 63
    Chun Kin Chan and Michael Tortorella
    3.1. Introduction, 63
    3.2. Approach, 64
    3.3. Problem Description, 64
    3.4. Reliability Modeling, 66
    3.5. Subassembly Hardware Reliability Prediction, 71
    3.6. Construction of Component Failure Rate Database, 75
    3.7. Comparing Field Reliability Results with Predictions, 78
    3.8. Implementation, 79
    3.9. Conclusions, 79
    References, 80
    Exercises, 81
    4. Allocation of Dependability Requirements in Power Plant Design 85
    Seppo Virtanen and Per-Erik Hagmark
    4.1. Introduction, 85
    4.2. System Characterization, 87
    4.3. Modeling Dependability and Requirements, 87
    4.4. Allocation of Requirements, 94
    4.5. Continued Allocation in the Fault Tree, 101
    4.6. Conclusions, 103
    References, 105
    Exercises, 106
    PART B. CASES WITH EMPHASIS ON DEVELOPMENT
    AND TESTING 109
    5. The Determination of the Design Strength of Granite Used as
    External Cladding for Buildings 111
    Malcolm J. Faddy, Richard J. Wilson, and Gerry M. Winter
    5.1. Introduction, 111
    5.2. Properties of Granite, 113
    *******S ix
    5.3. Reliability Criteria, 115
    5.4. Current Practices, 117
    5.5. Case Study, 122
    5.6. Conclusions, 129
    References, 130
    Exercises, 131
    Appendix A. Rosa Antico Data, 132
    Appendix B. White Berrocal Data, 134
    6. Use of Sensitivity Analysis to Assess the Effect of Model Uncertainty
    in Analyzing Accelerated Life Test Data 135
    William Q. Meeker, Luis A. Escobar, and Stephen A. Zayac
    6.1. Introduction, 135
    6.2. Weibull Distribution and Initial Data Analysis, 138
    6.3. Response Surface Model Analysis, 146
    6.4. Effect of Stroke Displacement on Spring Life, 151
    6.5. Concluding Remarks, 157
    References, 158
    Exercises, 158
    Appendix A. SPLIDA Commands for the Analyses, 159
    Appendix B. Spring-Accelerated Life Test Data, 161
    7. Virtual Qualification of Electronic Hardware 163
    Michael Osterman, Abhijit Dasgupta, and Thomas Stadterman
    7.1. Introduction, 163
    7.2. Automotive Module Case Study, 167
    7.3. Summary, 184
    References, 184
    Exercises, 185
    8. Development of a Moisture Soak Model for Surface-Mounted
    Devices 187
    Loon Ching Tang and Soon Huat Ong
    8.1. Introduction, 187
    8.2. Experimental Procedure and Results, 189
    8.3. The Moisture Soak Model, 191
    8.4. Discussion, 199
    References, 201
    Exercises, 202
    9. Construction of Reliable Software in Resource-Constrained
    Environments 205
    Mladen A. Vouk and Anthony T. Rivers
    9.1. Introduction, 205
    9.2. Constrained Development, 207
    9.3. Model and Metrics, 210
    9.4. Case Studies, 216
    9.5. Summary, 227
    References, 227
    Exercises, 230
    10. Modeling and Analysis of Software System Reliability 233
    Min Xie, Guan Yue Hong, and Claes Wohlin
    10.1. Introduction, 233
    10.2. NHPP Software Reliability Growth Models, 235
    10.3. Case Study, 238
    10.4. Problems and Alternatives, 240
    10.5. Case Study (Continued), 244
    10.6. Discussion, 247
    References, 248
    Exercises, 249
    11. Information Fusion for Damage Prediction 251
    Nozer D. Singpurwalla, Yuling Cui, and Chung Wai Kong
    11.1. Introduction, 251
    11.2. Approach Used, 252
    11.3. Binary Random Variable and Test Data, 253
    11.5. Information Fusion: A Bayesian Approach, 255
    11.6. Data Analysis and Interpretation, 262
    11.7. Conclusions, 263
    References, 263
    Exercises, 264
    Appendix, 264
    x *******S
    11.4. Physical Parameters and Expert Testimonies, 253
    PART C. CASES WITH EMPHASIS ON DEFECT PREDICTION
    AND FAILURE ANALYSIS 267
    12. Use of Truncated Regression Methods to Estimate the Shelf Life
    of a Product from Incomplete Historical Data 269
    William Q. Meeker and Luis A. Escobar
    12.1. Introduction, 269
    12.2. Truncated Data Background, 273
    12.3. Truncated Regression Model for the Truncated Product
    A Shelf-Life Data, 277
    12.4. Comparison of Truncated and Censored Data
    Analysis, 283
    12.5. Concluding Remarks and Extensions, 286
    References, 288
    Exercises, 288
    Appendix. SPLIDA Commands for the Analyses, 290
    13. Determining Software Quality Using COQUALMO 293
    Sunita Chulani, Bert M. Steece, and Barry Boehm
    13.1. Introduction, 293
    13.2. Software Reliability Definitions, 294
    13.3. Constructive Quality Model (COQUALMO), 294
    13.4. Case Study, 307
    13.5. Conclusions, 309
    References, 310
    Exercises, 311
    14. Use of Extreme Values in Reliability Assessment
    of Composite Materials 313
    Linda C. Wolstenholme
    14.1. Introduction, 313
    14.2. Test Data and Background Knowledge, 314
    14.3. Model Fitting and Prediction, 314
    14.4. Strength Testing, 324
    14.5. Discussion, 328
    References, 329
    Exercises, 329
    *******S xi
    15. Expert Judgment in the Uncertainty Analysis of Dike Ring
    Failure Frequency 331
    Roger M. Cooke and Karen A. Slijkhuis
    15.1. Introduction, 331
    15.2. Uncertainty Analysis, 332
    15.3. Expert Judgment Method, 333
    15.4. The Dike Ring Expert Judgment Study, 337
    15.5. Results, 339
    15.6. Conclusions, 345
    References, 347
    Exercises, 348
    Appendix. Example of Elicitation Question: Model Term
    Zwendl, 349
    PART D. CASES WITH EMPHASIS ON MAINTENANCE AND
    MAINTAINABILITY 351
    16. Component Reliability, Replacement, and Cost Analysis with
    Incomplete Failure Data 353
    Nicholas A. J. Hastings
    16.1. Introduction, 353
    16.2. Maintenance Data, 354
    16.3. Modeling Failures, 357
    16.4. Component Replacement Policy Options, 361
    16.5. Planned Replacement—Analysis and Costs, 364
    16.6. Conclusion, 372
    References, 373
    Exercises, 374
    Appendix. RELCODE Software, 375
    17. Maintainability and Maintenance—A Case Study on Mission
    Critical Aircraft and Engine Components 377
    U. Dinesh Kumar and John Crocker
    17.1. Introduction, 377
    17.2. The Airline Company Profile, 381
    17.3. Analysis of Unscheduled Maintenance, 383
    17.4. Engine Reliability and Maintenance Policies, 387
    xii *******S
    الحمد لله
    Eng-Maher
    Received: 103
    Given: 408
    هذا الكتاب يعلمك طرق الصيانه وذلك بعمل حالات دراسيه للعيوب المتكرره والعمل على تفاديها ب اسلوب علمى مدروس ومدعم بخبرات .
    الحمد لله
    سعود الكعبي
    سعود الكعبي غير متواجد حالياً
    شكرا جزيلا أخي العزيز
    أتمنى الدعاء لي
    بهاءالدين
    بهاءالدين غير متواجد حالياً
    الصورة الرمزية بهاءالدين
    تسلم ايدك دىمادة عندى السنة اللى جايه ان شاء الله
    motaz_95
    motaz_95 غير متواجد حالياً
    الصورة الرمزية motaz_95
    Received: 20
    ابداع مستمر
    جزيت خيرا
    [SIGPIC][/SIGPIC]
    Eng-Maher
    Received: 103
    Given: 408
    مشكووور اخى بهاء ..... واتمنى لك التوفيق من كل قلبى
    كما اخص ب الشكر اخى معتز بارك الله فيك
    الحمد لله
    امجد66
    امجد66 غير متواجد حالياً
    شكرا جزيلا
    Eng-Maher
    Received: 103
    Given: 408
    اقتباس المشاركة الأصلية كتبت بواسطة امجد66 مشاهدة المشاركة
    شكرا جزيلا
    مشكور امجد
    الحمد لله
    speed99a
    speed99a غير متواجد حالياً
    شــــــــكـــــــــراً جـزيــــــــــلاً الله يحفظك
