الات حاسبه علميه scientific calculator
النتائج 1 إلى 10 من 15
    حمدي_2004
    حمدي_2004 غير متواجد حالياً
    هذه بعض الالات الحاسبه العلميه والتي تعمل على نظام التشغيل xp
    الروابط وبعد كل رابط تعريف بالاله كما هو مكتوب في الموقع
    http://easyreadyreckoner.com/Setup.exe
    EasyReadyReckoner is a scientific calculator with numerous conversion
    tables such as weight and distance. All results and inputs are written
    to a spool, they can then be printed or saved to a file and reopened
    later. A running total feature is also incorporated. The memory engine
    has seven memories which will be saved even when the application is
    closed. These memories can be recalled to the calculator's input or
    they can be deleted individually to make a place for new values. The
    calculator allows Radian, Degree and Gradient calculations. It also
    includes scientific values e.g. for trigonometry and much more
    http://www.phy.uni-bayreuth.de/~btp3...ta/computa.zip
    ComPuta does much more than your usual calculator - in addition to
    the usual arithmetic calculations, ComPuta can solve your non-linear
    equations, find the extrema (local minima and maxima) of your
    functions. Generate tables of values for your functions, interpolate
    functions from data for specific points or in intervals, integrate and
    differentiate your functions and solve your first order initial value
    problems using the best algorithms. ComPuta is easy to use, it does
    what it says it does efficiently and there is no boring long
    documentation to read. Of course there are advanced tricks and options
    in ComPuta, but you dont have to learn them unless you want to.
    ComPuta is small in size, less than 200kb, a single executable and
    does not modify your system in any way. You can add comments in your
    computations and your tasks are automatically saved so that you can
    continue from where you stopped
    http://admin.u15194059.onlinehome-se...ucation&ID=396
    Sicyon is an all-in-one calculation tool for physicists, engineers
    and chemists; students, professors and researchers - everybody using
    physical or chemical formulas and tables of constants. It is easy-to-
    use and has everything you need to calculate or analyze expressions or
    program functions (VBScrip/JScript). Sicyon combines an intuitive
    interface and an object oriented approach to provide a fast learning
    curve while staying at a high level of efficiency.
    من مواضيع حمدي_2004 :
    mayhop
    mayhop غير متواجد حالياً
    اشكرك اخي العزيز
    MOSTAFAMAHMOUD
    MOSTAFAMAHMOUD غير متواجد حالياً
    شكرا ياباشا على الهدايا القيمه
    Genius Engineer
    Genius Engineer غير متواجد حالياً
    الله يعطيك العافية ....
    محمد المصرى77
    محمد المصرى77 غير متواجد حالياً
    شكرا على هذه البرامج و جارى التجربة
    amg
    amg غير متواجد حالياً
    بارك الله فيك
    العلم نور ونور الله لا يُهدى لعاصي
    eng_mtarekm
    eng_mtarekm غير متواجد حالياً
    برنامج Sicyon قيم لكنه unregistered آمل لو يوجد طريقة لتسجيله
    docpharmD
    docpharmD غير متواجد حالياً
    e-mail me if the link expire
    my e-mail in my profile
    CVLMASTER
    CVLMASTER غير متواجد حالياً
    الصورة الرمزية CVLMASTER
    Received: 18
    Thank you very much for your efforts
    sail
    sail غير متواجد حالياً
    الصورة الرمزية sail
    thaks for you
    see you in happy taime
