برنامج لة نفس امكانات Hysys 3.2 اسمة (coco Simulator)حجمة 7.3 Mb جاهز للتحميل ؟؟
النتائج 1 إلى 10 من 43
    softchem
    softchem غير متواجد حالياً
    Received: 10
    اذا لم تستطع الحصول على hysys 3.2 اليك هذا البرنامج الرائع والذى يتكون من اربعة برامج فرعية بالاضافة الى برنامج chem sep v5.91
    [IMG]http://www.arab-eng.org/vb//uploaded/30270_1168983031.gif
    [/IMG]
    رابط التحميل:
    http://cocosimulator.org/index_download.html
    softchem
    Received: 10
    What is COCO
    COCO (CAPE-OPEN to CAPE-OPEN) is a free-of-charge CAPE-OPEN compliant steady-state simulation environment consisting of the following components:
    COFE - the CAPE-OPEN Flowsheet Environment is an intuitive graphical user interface to flow-sheeting. COFE has sequential solution algorithm using automatic tear streams. COFE displays properties of streams, deals with unit-conversion and provides plotting facilities.
    TEA - COCO's Thermodynamics for Engineering Applications, is based on the code of the thermodynamic library of ChemSep and includes a data bank of over 150 commonly used chemicals. The package exhibits more than 100 property calculation methods with their analytical or numerical derivatives.
    COUSCOUS - the CAPE-OPEN Unit-operations Simple package is shipped with COCO. It contains a splitter, a mixer, heat-exchangers, pumps and reactors amongst other unit operations. ChemSep-LITE, a limited version of ChemSep with a maximum of 5 components and 50 stages, can serve as an equilibrium distillation unit operation in COCO. A full version of the equilibrium and non-equilibrium column simulator can be obtained at http://www.chemsep.com/. ChemSep-LITE is included in the COCO installation.
    CORN - the CAPE-OPEN Reaction Numerics package that comes with COCO facilitates specifying any kind of kinetic or equilibrium reaction. Simple reactor units, like conversion reactors, CSTRs and plug flow reactors that can use the CORN package come with the COUSCOUS package.
    softchem
    Received: 10
    يا جماعة هذا البرنامج سعرة غالى وعندما نزلتة فى الملتقى قلت انة سوف يكون مهما للجميع وخصوصا مهندسى التصميم, الظاهر لا احد يهتم بالبرامج والكتب او انا فى وادى والاخوة فى واد اخر
    PVC
    PVC غير متواجد حالياً
    الله يعطيك العافية
    لكن هل هذا البرنامج يحتوي membrane unit وليس كبقية البرامج لا تحتوي الا separator
    وشكرا...
    PVC
    الله يعطيك العافية
    وشكرا...
    ch_ward
    ch_ward غير متواجد حالياً
    جزاك الله كل خير
    الناس مش فى وادى تانى ولا حاجه
    بس الدنيا مشاغل .........زى منتا عارف
    جزاك الله خيرا على البرنامج مره تانيه.........
    أنا كنت محتاجو جدا جدا
    أبو محمد الزير
    أبو محمد الزير غير متواجد حالياً
    الله يعطيك العافية ولك جزيل الشكر على البرنامج
    Karim07
    Karim07 غير متواجد حالياً
    بارك الله فيك
    قمرهم كلهم
    قمرهم كلهم غير متواجد حالياً
    شكرا لك وننتظر منك المزيد
    تغيير
    تغيير غير متواجد حالياً
    جزاك الله خيراً
