عاجل , للعارفين ب Fluid Mechanics ارجو المساعدة
النتائج 1 إلى 3 من 3
    محمد الحبابي
    محمد الحبابي غير متواجد حالياً
    احتاج الى المساعدة في حل هذا السؤال او ارسال الحل على ال***** يا اخواني المهندسين
    It is desired to design a pump-piping system to keep a 40-million-gallon capacity water tank filled. The pump to be used has the following performance characteristics:
    Q, Gal/min
    270
    405
    540
    675
    810
    945
    1080
    1215
    1350
    1485
    1620
    H, ft
    252
    252
    261
    261
    252
    252
    243
    234
    225
    207
    189
    162
    135
    h, %
    25
    35
    44
    48
    51
    53
    54
    55
    53
    50
    45
    The tank is to be filled with chilly (10oC) ground water from an aquifer, which is S m lower than the tank. The total length of pipes is to be L m. The piping system should have fourtype” valves, 10 elbows of r/d = amount, and galvanized iron pipe of a size to be selected in the design. Consider two pipe sizes of D1 inches and D2 inches internal diameter. For each diameter, find the system operating point and compute the total cost, given the following cost estimates:
    Pump and motor SR30000
    Valves SR500 + SR200 per centimeter of pipe size
    Elbows SR150 + SR75 per centimeter of pipe size
    Pipe SR3 per centimeter of diameter per meter of length
    Electricity SR0.12 per Kilowatt-hour
    Recommend one of the two pipes based on economic considerations (time and money).
    D1D2typeamountLS(inches)(inches)r/D =(m)(m)46Angle valve-wide open23005
    الرجاء المساعدة
    الإيميل abn3mi_405*hotmail
    ولكم جزيل الشكر :rolleyes:
    herouse
    herouse غير متواجد حالياً
    thanks
    عمر البسام
    عمر البسام غير متواجد حالياً
    ماهذا السؤال يا اخي الحبيب
    هل انت موظف او طالب
