برنامج ليسب رائع لنقل أى Txt الى الاوتوكاد
النتائج 1 إلى 10 من 29
    الصورة الرمزية المقترب
    المقترب
    المقترب غير متواجد حالياً
    Received: 74
    Given: 8
    سلام للاخوان
    ايش لونكم جميعا
    مابدرى حدا راح يرد السلام ام لا
    المهم اليكم البرنامج والله يكرمكم من يستطيع استخدامه يكتب هنا كيف لانى بحاول وما عمل معى ربما يعمل معكم
    البرنامج اسمه
    TXTIN
    ..........................;TEXTIN.LSP By: Jeffery P. Sanders
    ;This program takes any text file and prints it in AutoCAD.
    ;define program - listing your variable names here
    ; resets them to nil after the program finishes
    (defun C:TEXTIN(/ lts ernote inspt filen fil lineone)
    ;turn echo off
    (setvar "cmdecho" 0)
    ;get ltscale (Note: ltscale should always equal dimscale)
    (setq lts(getvar "ltscale"))
    ;set the exit note to display successful
    (setq ernote "\n....TextIn Complete.")
    ;get the text insertion point
    (setq inspt(getpoint "\nInsertion Point: "))
    ;use dialog box to get file name / the 4 allows
    ;the user to type in a new file extension
    ;the "txt" sets the default to be "*.txt"
    (setq filen
    (getfiled "Select Text File" "" "txt" 4)
    ;if file exist, open file to read
    (if (setq fil(open filen "r"))
    ;progn necessary for multiple statements inside if statement
    (progn
    ;while the line from text file does not equal nil
    (while (setq lineone(read-line fil))
    ;print the text in AutoCAD drawing
    (command "text" inspt(* lts(getvar "textsize"))0.0 lineone)
    ;move down one line each loop by resetting the insertion point
    (setq inspt
    ;start the polar function i.e. [polar pt angle distance]
    (polar
    ;from the insertion point
    inspt
    ;set the angle to go down i.e. (270 deg OR pi + pi/2 radians)
    (* pi 1.5)
    ;distance down to the next line is (textsize x 1.5) x ltscale
    (* lts (* 1.5(getvar "textsize")))
    ) ; close the polar function
    ) ; close the setq
    ) ; close the while loop
    ;close the text file
    (close fil)
    ) ; close the if progn statement
    ;else set the exiting remark as an error
    (setq ernote (strcat "\nCannot Find File: " filen))
    ) ; close the if statement
    ;turn echo on
    (setvar "cmdecho" 1)
    ;print the exiting remark
    (princ ernote)
    (princ "\n ") ; clear command line
    (princ) ; no echo
    ) ; close the program
    ارجو الفائده منه
    والسلام
    engramy
    engramy غير متواجد حالياً
    الصورة الرمزية engramy
    Received: 12
    أخي الكريم
    لقد حاولت كثيرا في هذا البرنامج
    ولكن برنامج الـ AutoCAD لا يريد تحميل هذا الت LISP ويعنى الخطأ
    error: misplaced dot on input
    zkloal
    zkloal غير متواجد حالياً
    تم اصلاحة
    فقط اضف في اول السطر الاول ;
    والبرنامج اشغل عندي 100% والحمدلله ثم لك الشكر يلخي على البرنامج
    وهذا البرنامج بعد التعديل
    ;..........................;TEXTIN.LSP By: Jeffery P. Sanders
    ;turn echo off
    (setq filen
    (progn
    (setq inspt
    (polar
    inspt
    (* pi 1.5)
    ) ; close the setq
    (close fil)
    ;turn echo on
    (princ ernote)
    (princ) ; no echo
    engramy
    Received: 12
    فعلا البرنامج إشتغل
    100 %
    بس أنا ضفت مسافة في السطر الخامس بعد كلمة TEXTIN
    (defun C:TEXTIN (/ lts ernote inspt filen fil lineone)
    ولتشغيله إكتب TEXTIN
    sosohoho
    sosohoho غير متواجد حالياً
    Received: 9
    السلام عليكم يا حبيبي لا نحتاج الى برامج لكتابة الجالكتابات في برنامج الاوتوكاد فانا اعرف طريقة تذهب الى احدى البرامج مثل وورد او اكسل وتذهب الى وورد ارت وتكتب الجملة وبعده تذهب الى اوتوكاد وتعمل سبيشل بيست وتختار الاختيار الثانى على ما اعتقد ان لم تخني ذاكرتي وتاتي الكليمات بالشكل المطلوب مع تحيات sosohohoمن عيتكاوة
    محمد نحلة
    محمد نحلة غير متواجد حالياً
    الف شكر ياخىى
    سنمار1974
    سنمار1974 غير متواجد حالياً
    أخي العزيز لا تحتاج أبدا إلى برنامج للكتابة في الأوتوكاد كل ما في الامر هو ان تكتكب في الwordأو excelتعمل كوبي للحافظة ثم باست .
    وللعلم تستخدم هذه الطريقة فقط في البرامج التي لا تدعم الكتابة باللغة العربية
    محمود مرسى
    محمود مرسى غير متواجد حالياً
    ان شاء الله سوف احاول استخدام الليسب وهقول لك كيف يعمل
    احمدعبدالجبار
    احمدعبدالجبار غير متواجد حالياً
    هو وين البرنامج
    engramy
    Received: 12
    اقتباس المشاركة الأصلية كتبت بواسطة احمدعبدالجبار مشاهدة المشاركة
    هو وين البرنامج
    البرنامج موجود في المرفقات
    فقط قم بعمل Load له في برنامج الـ AutoCAD
