موقع برامج هندسية - تصميم ميكانيكي
النتائج 1 إلى 10 من 28
    ود الفاتح
    ود الفاتح غير متواجد حالياً
    موقع به العديد من برامج التصميم الميكانيكي
    http://www.mitcalc.com/
    Mechanical, Industrial and Technical Calculations
    Your day-to-day partner on the way to an excellent product.
    Recommend to a friend
    Extension Pack - EP07
    Service Pack - SP06
    Released MITCalc 1.50
    Released MITCalc 1.40b
    Released the new
    Extension Pack - EP06
    Released the new
    version - MITCalc 1.30
    <A href="http://www.mitcalc.com/en/news_051116.htm">11/16/2005
    Released the new
    version - MITCalc 1.22
    MITCalc for Solid Edge
    Extension Pack - EP05
    Are you a mechanical engineer, design engineer, engineering draughtsman, technical employee, or a student at a college? Do you need to work with a professional computational system? But you are not willing or cannot pay thousands of dollars for inadequately complex or incomprehensible solutions? Then you may just need MITCalc.
    MITCalc is a set of engineering, industrial, and technical calculations for your day-to-day routines. It will reliably, precisely, and most of all quickly guide you through the design of components, the solution of a technical problem, or a calculation of an engineering point without any significant need for expert knowledge.
    MITCalc contains both design and check calculations of many common tasks, such as: spur gear, bevel gear, worm gear, planetary gearing, timing belt, v-belt and chain drives, bearings, springs, beam, buckling, plates, shaft, bolt connection, shaft connection, force couplings of shafts, pins, tolerances, tolerance analysis, welded connection, technical formulas and many others. You also have available many material, comparison, and decision tables, including a system for the administration of resolved tasks.
    Description in PDF format: English version, Persian (Farsi) version
    MITCalc is an open system designed in Microsoft Excel to which you can make further modifications or user extensions without any programming skills.
    You don’t have to learn MITCalc because you already know how to use it. The straightforward and fully comprehensive user interface with complex on-line help and the “expert notes” system will allow you to be more productive in just a few minutes.
    MITCalc supports simple interconnection of individual parts between either each other, or your calculation, or tables. You can easily customize a solution to any special task you need.
    MITCalc cooperates with many 2D and 3D CAD systems (AutoCAD, AutoCAD LT, IntelliCAD, Autodesk Inventor, SolidWorks, SolidEdge, Pro/Engineer...). To draw a designed solution in 2D or insert correspondent 3D models and their assemblies is a matter of seconds.
    Do you think you may be interested in MITCalc and you would like to try it? You don’t need to wait! Download it right here (30-day evaluation). We truly believe that MITCalc will be a fundamental tool in everyday process of solving your technical tasks.
    © Copyright 2003-2009, All rights reserved.
    من مواضيع ود الفاتح :
    التعديل الأخير تم بواسطة د.محمد باشراحيل ; 2010-01-06 الساعة 01:17 PM
    نايف علي
    نايف علي غير متواجد حالياً
    عضو فائق التميز
    الصورة الرمزية نايف علي
    Received: 11
    Given: 10
    جاري التصفح
    يعطيك ألف عافية
    إذا اعتاد الفتى خوض المنايا ::: فأهون مايمر به الوحول
    afreet
    afreet غير متواجد حالياً
    مشكووووووور
    eng.osamaa
    eng.osamaa غير متواجد حالياً
    الصورة الرمزية eng.osamaa
    مشششششششششششششششششكو اخي الكريم
    lmaher_26
    lmaher_26 غير متواجد حالياً
    موقع رائع جداً و لكن كل البرامج trial
    lmaher_26
    و بحثت كثيراً في الإنترنت و لم أجد اي كراك لهذه البرامج
    الناجي الطيب محمد
    الناجي الطيب محمد غير متواجد حالياً
    الصورة الرمزية الناجي الطيب محمد
    بارك الله فيك ود الفاتح
    الدباح
    الدباح غير متواجد حالياً
    الصورة الرمزية الدباح
    شكرا جدا ونرجو المزيد
    elrasheedy
    elrasheedy غير متواجد حالياً
    تماااااااااااااااااااااااااااااااااااااااااااااااا اااااام
    سامي صلاح عبده
    سامي صلاح عبده غير متواجد حالياً
    ود الفاتح لك الشكر والتقدير
