PROJECT MANAGEMENT Technique
النتائج 1 إلى 10 من 12
    الصورة الرمزية m_halawa
    m_halawa
    m_halawa غير متواجد حالياً
    1. PERT (Program Evaluation and Review Technique)
    Analysis
    PERT Duration Estimate = (P + 4M + O) / 6
    Where:
    P = Pessimistic Duration Estimate
    M = Most Likely Duration Estimate
    O = Optimistic Duration Estimate
    ♦ Used when a task has a great amount of uncertainty
    ♦ By creating 3 distinct estimates (P, M & O) and using the above
    formula to calculate your working estimate, you have factored in
    the uncertainty
    ♦ Final estimates will be appropriate should your tasks come in
    with a normal distribution of variation
    SD = (P - O) / 6
    Where:
    SD = Standard Deviation
    TV = [ (P – O) / 6] ²
    Where:
    TV = Task Variance
    PV = √ sum (TV)
    Where:
    PV = Project Variance
    ♦ Used to calculate the task and project variance
    ♦ A larger variance indicates greater uncertainty within the
    estimates
    ♦ Can be used as a +/- degree of certainty
    2. Communications Channels
    CC = N (N-1) / 2
    Where:
    CC = Number of Communication Channels that Exist
    N = Number of Entities / People who Need to Communicate
    ♦ Used to calculate the number of unique communications
    channels that exist
    ♦ Helps in understanding the potential complexity of
    communication
    3. Investment Determinations
    Present Value (PV)
    PV = FV / (1 + r) ⁿ
    Where:
    FV = future (forecasted) cash flows of an initiative (revenue or
    cost)
    r = interest rate
    n = number of time periods
    ♦ Used to calculate the current value of future cash flows
    ♦ Assists in project initiative spending decisions by comparing
    anticipated benefits from uncertain projects with typical
    investment strategies
    Net Present Value (NPV)
    NPV = sum (PV revenue cash flows) – sum (PV cost cash flows)
    ♦ Used to calculate the current value of the total anticipated
    benefits of a potential initiative
    ♦ Used to compare possible investment initiatives
    Internal Rate of Return (IRR)
    ♦ Used to compare the anticipated rate of return of multiple
    initiatives
    Payback Period
    ♦ Number of time periods it takes to recover your investment in the
    project (i.e. total revenue=total cost) and start generating
    incremental revenue
    Benefit Cost Ratio (BCR)
    BCR = benefits (revenue) / cost
    ♦ If BCR > 1, the initiative benefits are anticipated to outweigh the
    costs
    ♦ Used to compare the ratio of benefits to costs of multiple
    initiatives
    Opportunity Cost
    ♦ The NPV lost by choosing to not complete an initiative
    Sunk Cost
    ♦ Costs that have already been spent and should not factor into
    future investment decisions (including project continuance)
    Law of Diminishing Returns
    ♦ The principal that states the more that you put into something,
    the less you get out of it. BCR is the mathematical basis for the
    law
    ♦ Beyond strict math, the principal is used to counter flawed logic
    such as doubling resources will half duration
    Working Capital (WC)
    WC = current assets – current liabilities
    ♦ Represents the amount of money available to an organization to
    invest in initiatives
    4. Earned Value Analysis Formulas
    Cost
    EV = % complete x BAC (calculated at task or work product level, result is summed
    for project EV)
    *CV = EV – AC
    *CPI = EV / AC
    *EAC = AC + (BAC - EV) / CPI
    *EAC = BAC / CPI (simpler equivalent of above formula)
    *ETC = EAC – AC
    *VAC = BAC – EAC
    *V = BAC – AC (calculated at completion)
    * can be calculated at task or work product level, generally used at a project level
    Where:
    EV = Earned Value (formerly BCWP, Budgeted Cost of Work Performed)
    BAC = Budgeted at Completion
    CV = Cost Variance
    AC = Actual Cost (formerly ACWP, Actual Cost of Work Performed)
    CPI = Cost Performance Index (<1 Over Spending, >1 Under Spending)
    EAC = Estimate at Completion
    ETC = Estimate to Complete
    VAC = Variance at Completion
    ♦ Used to track cost variances, calculate cost estimating accuracy and
    forecast future costs (and total project cost) based on early results
    ♦ Requires detailed budgeting and task completion percent tracking at a
    ♦ Practically, requires project management software (PMS)
    Schedule
    *SV = EV – PV
    *SPI = EV / PV
    Where:
    SV = Schedule Variance (Expressed in Dollars)
    PV = Planned Value (formerly BCWS, Budgeted Cost of Work Scheduled)
    SPI = Schedule Performance Index (<1 Over Spending, >1 Under Spending)
    ♦ Used to schedule variances, calculate schedule duration estimating
    accuracy and forecast future durations (and total project duration)
    ♦ Requires detailed budgeting, project network diagram creation and task
    completion percent tracking at a task or work product level
    5. Normal Distribution (Sigma or Standard Deviation)
    +/- 1 Sigma = 68.26%
    +/- 2 Sigma = 95.46%
    +/- 3 Sigma = 99.73%
    +/- 4 Sigma = 99.99%
    ♦ Used as a quality standard, 3 or 6 Sigma represents a target (upper and
    lower control limits) for defect-free performance
    6. Project Schedule Buffer
    Sum of the Squares
    Buffer = √ sum (M ²)
    Where:
    M = Most Likely Duration Estimate (often of just critical path
    activities)
    ♦ Used to determine an appropriate duration for the schedule buffer
    ♦ Many other approaches exist including using an arbitrary % of the critical path duration
    Best-practice is to divide the buffer into 3 buffers. The first 1/3rd, the green buffer, can be used without concern. When the project begins using the second 1/3rd, the yellow buffer, the project requires tight control. When the team begins to use the final 1/3rd, the red buffer, the project is in real danger of running overtime.
    7. Accuracy of Estimates
    Order of Magnitude Estimate (Initiation) = -25% to +75
    Budget Estimate (Planning) = -10% to +25%
    Definitive Estimate (Late Planning / Partial Execution) = -5% to +10%.
    8. Risk – Expected Value (EV)
    EV = Probability x Impact
    ♦ Used to determine the expected value of a risk event
    ♦ The sum of the EV, can be used to determine the project reserve (risk contingency budget)
    hasan2004
    hasan2004 غير متواجد حالياً
    بارك الله فيك
    fayin12
    fayin12 غير متواجد حالياً
    شكرا لك يا اخ حلاوة
    Amin Sorour
    Amin Sorour غير متواجد حالياً
    الصورة الرمزية Amin Sorour
    الله ينور يا بشمهندس بجد معلومات قيمه جدا
    الزعيم2000
    الزعيم2000 غير متواجد حالياً
    عضو تحرير المجلة
    الصورة الرمزية الزعيم2000
    Received: 11
    Thumbs up
    ما شاء الله على المعلومات القيمة
    أتمنى التواصل والمزيد لأنه واضح إن حضرتك متبحر
    esas
    esas غير متواجد حالياً
    السلام عليكم يا اخي بس ممكن تبدأ الموضوع من الأول لأني مش فاهم حاجة أو لو فيه كتاب بيتكلم عن الحاجات دي بالتفصيل لأني لسه جديد في موضوع الأدارة
    Mr. Data
    Mr. Data غير متواجد حالياً
    Thaaaaaaaaaaaaaaaaaaanks
    hosini2000
    hosini2000 غير متواجد حالياً
    السؤال الذي يحيرني هو ..
    المهندس الذي يعمل ( cost controller ) ..ماذا يفعل ؟ و كيف يفعله ؟
    برجاء الإجابة على سؤالي و لو أمكن تنظيم دورة عن هذا الموضوع لأنه مهم و لأن الكثير من الشركات في مصر و خارجها تطلب مهندسين لهذه الوظيفة
    eng_mostafaa
    eng_mostafaa غير متواجد حالياً
    جزاك الله خيرا وياريت شرح تقدملنا شرح مفصل
    m_halawa
    والله كان بودي
    الشرح المفصل دي قصة طويلة لكل جزء محتاج فرغ آسف جدا لذلك
