سؤال في التحلية
صفحة 2 من 2 الأولىالأولى 1 2
النتائج 11 إلى 15 من 15
    نبيل عواد الغباري
    نبيل عواد الغباري غير متواجد حالياً
    مشرف الهندسة الكيميائية
    Received: 63
    شكرا للتوضيح اخي
    H2SO4 + Ca(OCl)2 -------------> HOCl + CaSO4
    أخو الكيمياء
    أخو الكيمياء غير متواجد حالياً
    Chlorine Dioxide - ClO2
    "Used for water treatment for more than sixty years."
    Eka Chemicals has proven experience with ClO2 for more than thirty-five years. First used by Eka as a bleaching chemical to aid in the pulp and paper industry and now used to make our drinking water safer.
    When used as a pretreatment, chlorine dioxide aids in the prevention of carcinogens in your drinking water by selectively oxidizing containments that may otherwise be transformed by chlorine into trihalomethanes (THM's). Simultaneously, ClO2 acts as a biocide inactivating harmful viruses like E. Coli, cryptosporidium and more with minimum contact time.
    ClO2 - A versatile oxidant and biocide
    Applications
    The unique properties of chlorine dioxide make it effective in a wide variety of oxidant and biocide applications. ClO2 effectively controls iron and manganese in drinking water, eliminates slime in cooling towers, controls odors in animal by-product processing plants, disinfects processed meats and vegetables and many other applications.
    ClO2 has excellent application potential in the following areas:
    هذا العالم غريب لاكني اغرب منه
    أخو الكيمياء
    Chlorine dioxide is produced by the reduction of sodium chlorate with hydrogen peroxide under acidic conditions. It’s made easy with Eka’s pre-blended Purate solution.
    Purate® is formulated with just the right amount of chlorate and peroxide and shipped to your site.
    Purate® Composition
    40% Sodium Chlorate
    7-8% Hydrogen Peroxide
    نبيل عواد الغباري
    Received: 63
    جزيل الشكر للايضاح وفقكم الله لما فيه الخير والمعرفة
    سوسن السيد محمد
    سوسن السيد محمد غير متواجد حالياً
    الكلور:-
    يستخدم الكلور لتعقيم المياه الداخلة إلى المكثفات والمبردات (coolers) وذلك للقضاء على الرخويات والصدفيات المتكونة على مداخل مواسير المكثف ويجب أن يكون هناك تركيز مناسب من الكلور الحر المتبقى Free residual chlorine فى المياه الخارجة من المكثفات او المبردات بحيث تتراوح بين ( 0.5 – 1.0 مجم / لتر ) و بذلك سوف تختلف جرعة الكلور المحقونة فى المياه تبعا لاختلاف نوعية المياه و كمية المواد العضوية فيها . و يفضل أن يكون حقن الكلور حقنا مستمرا (cont.dose) بجرعات قليلة نسبيا عن حقنه لمدد قصيرة وجرعات اكبر (shock dose)لتفادى مشاكل السقوط الفجائي فى ال Vaccum فى مكثفات التربينات نتيجة لانسداد المواسير بسبب قتل الأحياء فجائيا داخل المكثفات.
    وفى حالة تشغيل عدد كبير من المكثفات على التوازي فانه يجب إضافة الكلور مباشرة قبل كل مكثف بحيث يكون الحقن عند مدخل كل مكثف وذلك لتقليل وقت التلامس لتفاعل الكلور مع الماء وبالتالى تقليل كمية الكلور اللازمة لتكوين كلور حر متبقى ولذا سوف يتم التركيز على المكثفات الأكثر اتساخا ويضاف لها كميات كلور أكثر للقضاء على ما بها من مواد عضوية.
    يتم حقن الكلور فى خط سحب المياه الأولية وذلك لأكسدة المواد العضوية والقضاء على الصدفيات وهو يستخدم على هيئة كلور سائل حيث ان :-
    CL2 + H2O HOCL + HCL
    HOCL OCL- + H+
    ويتاين حامض الهيبو كلورس بطريقة لحظية بمجرد تكونه الى H+ و OCL- بدرجة يعتمد على الpH ودرجة الحرارة حيث يتاين بدرجة قليلة عندما يقل الرقم الهيدروجينى عن 6 وبين ( 6 – 8 ) يتاين تأينا كاملا وذلك يعنى أن ايون الهيبوكلوريت OCL- يكون فعال عند :
    pH = ( 6 – 10 ) وحامض الهيبوكلوركس HOCL يكون فعال عند PH = ( 2 – 6 )
    ويعتقد ان التفاعل الحيوى والكيميائي الذى يحدث بين الكلور والأحياء المائية والذى يؤدى الى قتل الخلايا الحية هو عملية أكسدة غير عكسية لأحد الإنزيمات اللازمة لحياة هذه الكائنات وهو ترايوذى فوسفات دى هيدررو جيناز
    ( Triose phosphate dehydrogenase) حيث يستخدم هذا الإنزيم فى أكسدة الجلوكوز وجميع نشاطات الخلية الحيوية ويزيد فى كفاءة الكلور على تحطيم ه1ذا الإنزيم الحيوى وقدرة الغاز على اختراق جدران الخلايا الحية والوصول الى محتوياتها الداخلية والتفاعل معها.
    ومن مميزات الكلور:-
    1- له قدرة فعالة فى عملية تعقيم المياه وتطهيرها من الكائنات العضوية حيث انه يخترق جدار الخلية الحية.
    2- يعتبر ذو تكلفة بسيطة لو قورن باى مواد مؤكسدة اخرى .
    3- سهل القياس وسهل التحكم فى عملية الحقن.
    ومن عيوبه:-
    1- بزيادة كمية الكلور من الممكن أن يصل إلى الريزن فى وحدة نازع الأملاح ويقلل كفاءته.
    2- اى تسرب منه يسبب الاختناق الذى قد يؤدى إلى الموت.
    3- يمكن أن يتحد مع الأحماض العضوية الذاتية فى المياه مثل Humic acid ويكون ما يسمى بTrihalomethans (THM) الذى قد يسبب أمراض سرطانية.
    وعموما نجد أن حقن المواد المؤكسدة يركز عليه فى اشهر الربيع ابتدءا من مارس حتى سبتمبر وهى شهور النمو لتلك الكائنات.
    ودائما يكون هناك سيطرة على عمليات الحقن بحيث لا يزيد الكلور المتبقى عن 0.5ppm فى المياه المرشحة.
