ان كنت ترغب ان تعرف جهازك مخترق ام لا هذا الموقع الذي يخبرك اذا كان جهازك مخترق أم ل
النتائج 21 إلى 23 من 23
  1. [21]
    بنت القمر85
    بنت القمر85 غير متواجد حالياً
    نفس الحكاية صارت معي شنوووووووو سالفته ؟؟؟؟؟؟؟؟؟؟؟؟؟؟
    ومشكووووووووووورين
  2. [22]
    nadoosh
    nadoosh غير متواجد حالياً
    مشكووووووووووووووووووووووووووووووووووووووووووووووو وووووووووووووووووووور
  3. [23]
    roshin
    roshin غير متواجد حالياً
    Port Scan
    This server will now attempt to open several common ports on your computer. The results of these attempts will be displayed on this page as Open, Closed, or Secure:
    • If your firewall is configured to block a port, and it is operating correctly, you will see Secure and an event will be logged on your firewall.
    • A Closed port indicates that the port is reachable but there is no program currently accepting connections there.
    • If the port is indicated as Open there is an application or service on your computer actively accepting connections.
    The time to check each port will range from less than a second up to 20 seconds. Ports which are Secure will take the most time.
    Open and Unsecure!
    21 (FTP)
    This port is not being blocked and there is a program accepting connections on this port.
    Closed but Unsecure
    23 (Telnet)
    This port is not being blocked, but there is no program currently accepting connections on this port.
    Closed but Unsecure
    25 (SMTP Mail Server Port)
    Closed but Unsecure
    79 (Finger)
    Closed but Unsecure
    80 (HTTP)
    Closed but Unsecure
    110 (POP3 Mail Server Port)
    Closed but Unsecure
    139 (Net BIOS)
    Closed but Unsecure
    143 (IMAP)
    Closed but Unsecure
    443 (HTTPS)
    Test complete.
    Reachable ports were found. If these ports were not deliberately left open, there may be a problem with your firewall operation or configuration.
    maza ta3ni hazihi alrisala
    RORO
