~~~~~control system~~~~~
النتائج 1 إلى 3 من 3
    TheKing
    TheKing غير متواجد حالياً
    ازا ممكن حد يساعدني بحل هذا السؤال
    Let us consider a device that consists of a ball rolling on the inside rim of a hoop [11]. this model is similar to the problem of liquid fuel sloshing in a rocket. the hoop is free to rotate about its horizontal principal axis as shown in figure E7.1. the angular position of the hoop may be controlled via the torque T applied to the hoop from a torque motor attached to the hoop drive shaft. if negative feedback is used, the system characteristic equation is
    (a) sketch the root locus
    (b) find the gain when the roots are both equal
    (c) find these two equal roots
    (d) find the sittling time of the system when the roots are equal
    هذا السؤال من كتاب
    modern control system
    tenth edition
    وهو
    exercise 7.1
    من مواضيع TheKing :
    TheKing
    ارجو المساعدة !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!
    محمودصفا
    محمودصفا غير متواجد حالياً
    thankkkkkkkkkkkkkkkksssssssssssss
