معجم هندســة التعديـن
صفحة 2 من 2 الأولىالأولى 1 2
النتائج 11 إلى 17 من 17
    علاء الهدي
    علاء الهدي غير متواجد حالياً
    معجم هندسة التعدين(g)
    Illustrated Mining Terms
    G
    Gallery - A horizontal or a nearly horizontal underground passage, either natural or artificial.
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20G_files/gallery_1_jnc2.jpg[/IMG]
    Gasification – Any of various processes by which coal is turned into low, medium, or high Btu gases. Gathering conveyor; gathering belt - Any conveyor which is used to gather coal from other conveyors and deliver it either into mine cars or onto another conveyor. The term is frequently used with belt conveyors placed in entries where a number of room conveyors deliver coal onto the belt. Geologist - One who studies the constitution, structure, and history of the earth's crust, conducting research into the formation and dissolution of rock layers, analyzing fossil and mineral ******* of layers, and endeavoring to fix historical sequence of development by relating characteristics to known geological influences (historical geology).
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20G_files/staking.jpg[/IMG]
    Geology - a science dealing with the formation of the earth and ore deposits. Gob - The term applied to that part of the mine from which the coal has been removed and the space more or less filled up with waste. Also, the loose waste in a mine. Also called goaf.[IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20G_files/highkeep_vue.jpg[/IMG]Global climate change – This term usually refers to the gradual warming of the earth caused by the greenhouse effect. Many scientists believe this is the result of man-made emissions of greenhouse gases such as carbon dioxide, chlorofluorocarbons (CFC) and methane, although there is no agreement among the scientific community on this controversial issue. Grade - the value of an ore Grain - In petrology, that factor of the texture of a rock composed of distinct particles or crystals which depends upon their absolute size.[IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20G_files/polished1.jpg[/IMG]Grizzly - Course screening or scalping device that prevents oversized bulk material form entering a material transfer system; constructed of rails, bars, beams, etc.[IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20G_files/Grizzly.jpg[/IMG]Ground control - The regulation and final arresting of the closure of the walls of a mined area. The term generally refers to measures taken to prevent roof falls or coal bursts.
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20G_files/props1.gif[/IMG]
    Ground pressure - The pressure to which a rock formation is subjected by the weight of the superimposed rock and rock material or by diastrophic forces created by movements in the rocks forming the earth's crust. Such pressures may be great enough to cause rocks having a low compressional strength to deform and be squeezed into and close a borehole or other underground opening not adequately strengthened by an artificial support, such as casing or timber. Grout - a filling agent inserted by pressure into loose and broken rock or ground Gunite - A cement applied by spraying to the roof and sides of a mine passage.
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20G_files/gunite.gif[/IMG]
    Return to TERMS MENU
    علاء الهدي
    معجم هندسة التعدين(h)
    H
    Hanging wall - the top or upper enclosing wall of a vein. Haulage - The horizontal transport of ore, coal, supplies, and waste. The vertical transport of the same is called hoisting.
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20H_files/ugtruck.jpg[/IMG]
    Haulageway - Any underground entry or passageway that is designed for transport of mined material, personnel, or equipment, usually by the installation of track or belt conveyor.
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20H_files/SANDFILL2.jpg[/IMG]
    Headframe - The structure surmounting the shaft which supports the hoist rope pulley, and often the hoist itself.
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20H_files/headf.gif[/IMG]
    Heading - A vein above a drift. An interior level or airway driven in a mine. In longwall workings, a narrow passage driven upward from a gangway in starting a working in order to give a loose end.
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20H_files/olddrift.jpg[/IMG]
    Head section - A term used in both belt and chain conveyor work to designate that portion of the conveyor used for discharging material. Heaving - Applied to the rising of the bottom after removal of the coal; a sharp rise in the floor is called a "hogsback". Highwall – The unexcavated face of exposed overburden and coal in a surface mine or in a face or bank on the uphill side of a contour mine excavation.
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20H_files/highwall.jpg[/IMG]
    Highwall miner – A highwall mining system consists of a remotely controlled continuous miner which extracts coal and conveys it via augers, belt or chain conveyors to the outside. The cut is typically a rectangular, horizontal cut from a highwall bench, reaching depths of several hundred feet or deeper. Hoist - A drum on which hoisting rope is wound in the engine house, as the cage or skip is raised in the hoisting shaft.
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20H_files/hoist.jpg[/IMG]
    Hoisting - The vertical transport coal or material. Horizon - In geology, any given definite position or interval in the stratigraphic column or the scheme of stratigraphic classification; generally used in a relative sense.[IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20H_files/recon6.jpg[/IMG]Hydraulic - Of or pertaining to fluids in motion. Hydraulic cement has a composition which permits it to set quickly under water. Hydraulic jacks lift through the force transmitted to the movable part of the jack by a liquid. Hydraulic control refers to the mechanical control of various parts of machines, such as coal cutters, loaders, etc., through the operation or action of hydraulic cylinders.[IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20H_files/SANDFILL1.jpg[/IMG]Hydrocarbon – A family of chemical compounds containing carbon and hydrogen atoms in various combinations, found especially in fossil fuels.
    fielo
    fielo غير متواجد حالياً
    أنا ما تعدنجي لكن شكل المعجم ده مفيد جداَ
    شكراً للزميل علاء الدين الهدي
    علاء الهدي
    شكراً جزيلاً لك يا أستاذ/ محمد عثمان (fielo)
    علاء الهدي
    معجم هندسة التعدين(i)
    I
    Igneous rock - rock that has solidified from a molten state.
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20I_files/Scoria.jpg[/IMG]
    Impermeable - not allowing fluids to move readily through the rock or soil.
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20I_files/snugfitdrop.gif[/IMG]
    Incline - Any entry to a mine that is not vertical (shaft) or horizontal (adit). Often incline is reserved for those entries that are too steep for a belt conveyor (+17 degrees -18 degrees), in which case a hoist and guide rails are employed. A belt conveyor incline is termed a slope. Alt: Secondary inclined opening, driven upward to connect levels, sometimes on the dip of a deposit; also called "inclined shaft".
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20I_files/incline-mtauburn2.jpg[/IMG]
    Incompetent - Applied to strata, a formation, a rock, or a rock structure not combining sufficient firmness and flexibility to transmit a thrust and to lift a load by bending.
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20I_files/incompetent.jpg[/IMG]
    Not mining related but applicable.
    Indicated coal resources – Coal for which estimates of the rank, quality, and quantity have been computed partly from sample analyses and measurements and partly from reasonable geologic projections. The points of observation are ½ to 1 ½ miles apart. Indicated coal is projected to extend as an ½ mile wide belt that lies more than ¼ mile from the outcrop or points of observation or measurement. Inferred coal resources – Coal in unexplored extensions of the demonstrated resources for which estimates of the quality and size are based on geologic evidence and projection. Quantitative estimates are based largely on broad knowledge of the geologic character of the deposit and for which there are few, if any, samples or measurements. The estimates are based on an assumed continuity or repletion of which there is geologic evidence; this evidence may include comparison with deposits of similar type. Bodies that are completely concealed may be included if there is specific geologic evidence of their presence. The points of observation are 1 ½ to 6 miles apart. In situ - In the natural or original position. Applied to a rock, soil, or fossil when occurring in the situation in which it was originally formed or deposited.[IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20I_files/Tusk_in_situ.jpg[/IMG]Intake - The passage through which fresh air is drawn or forced into a mine or to a section of a mine.
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20I_files/intake.jpg[/IMG]
    Isopach - A line, on a map, drawn through points of equal thickness of a designated unit. Synonym for isopachous line; isopachyte.[IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20I_files/Cisco7Isopach2d.jpg[/IMG]
    علاء الهدي
    معجم هندسة التعدين(j)
    J
    Jackleg - A percussion drill used for drifting or stopping that is mounted on a telescopic leg which has an extension of about 2.5 m. The leg and machine are hinged so that the drill need not be in the same direction as the leg.Job Safety Analysis (J.S.A.) - A job breakdown that gives a safe, efficient job procedure. Joint - A divisional plane or surface that divides a rock and along which there has been no visible movement parallel to the plane or surface.[IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20J_files/marlfrs.jpg[/IMG]
    علاء الهدي
    معجم هندسة التعدين(l)
    L
    Lagging - planks or split-round timber placed around timbered sets to keep material from falling into the opening. Also used for flooring.[IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20L_files/Tank6.jpg[/IMG]Lamp - The electric cap lamp worn for visibility. Also, the flame safety lamp used in coal mines to detect methane gas concentrations and oxygen deficiency.
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20L_files/main-2.jpg[/IMG]
    Lateral - a horizontal mine working. Layout - The design or pattern of the main roadways and workings. The proper layout of mine workings is the responsibility of the manager aided by the planning department.
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20L_files/model1.gif[/IMG]
    Leaching - using chemicals or solvents to win the valuable material from ore
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20L_files/leaching.gif[/IMG]
    Level - all the connected horizontal mine openings at a certain elevation. Liquefaction – The process of converting coal into a synthetic fuel, similar in nature to crude oil and/or refined products, such as gasoline.
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20L_files/cuig11-1.gif[/IMG]
    Lithology - The character of a rock described in terms of its structure, color, mineral composition, grain size, and arrangement of its component parts; all those visible features that in the aggregate impart individuality of the rock.
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20L_files/weisenfluh3.jpg[/IMG]
    Load - To place explosives in a drill hole. Also, to transfer broken material into a haulage device. Loading machine - Any device for transferring excavated material into the haulage equipment.
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20L_files/miner4.gif[/IMG]
    Loading pocket - Transfer point at a shaft where bulk material is loaded by bin, hopper, and chute into a skip.
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20L_files/t_under_conveyor02.jpg[/IMG]
    Longwall Mining – One of three major underground coal mining methods currently in use. Employs a steal plow, or rotation drum, which is pulled mechanically back and forth across a face of coal that is usually several hundred feet long. The loosened coal falls onto a conveyor for removal from the mine.
    [IMG]file:///C:/Documents%20and%20Settings/Administrator/Desktop/معجم%20هندسة%20التعدين/Mining%20Terms%20-%20L_files/longwall.jpg[/IMG]
    Low voltage - Up to and including 660 volts by federal standards.
