Question about carbon ring
النتائج 1 إلى 5 من 5
    العماري2
    العماري2 غير متواجد حالياً
    Good morning all,
    I have question about steam turbine and I would like to hear from you the answer.
    We all know that the steam turbine used carbon ring as sealing part between steam and oil of bearing. My concern is why we use carbon rings not another metal like aluminum as in compressor.
    من مواضيع العماري2 :
    emshaker
    emshaker غير متواجد حالياً
    dear brother
    i am working into a power generation plant with high power and i don't never hear about that called carbon ring which seal between steam and bearing oil .
    the common method for sealing use is the steam seal sealing ,but
    i head about carbon rings for sealing into air compressor reciprocating type ,it's job to seal between oil side and compressed air side
    i hope these information be useful
    emshaker
    العماري2
    Dear brother,
    I have a doubt if you are really work at such a place.
    For your information, you are dealing with gas turbine NOT a steam turbine.
    emshaker
    thanks for your doubt
    Mech_usama
    Mech_usama غير متواجد حالياً
    i hope its an answer
    i think in my opinion , it is a ceramic ring and it might be carbon , now why read this
    because of the high rotation and high tempreture they use ceramic or carbon rings other wise it gona melt down
    once again i hope am wright
