الاخوه والاخوات برجاء المساهمة فى ترجمة هذه الموصافات الفنية للوصول لادق ترجمة فنية ولكم منى جزيل الشكر
Pneumatic Anesthesia Ventilator
Flow Generator, Time Cycled, Volume Preset and Pressure Limited
Suitable for Adults, Children and Infants
Its Rugged Design Prevents Accidental Damage
Used with all Standard Open & Semi- Closed Circle Systems
Model vend PAC V50
1. INSPIRATORY Time Control; 0.2 - 2 sec
2. EXPIRATORY Time Control; 0.5 - 4 sec
3.1:E RATIO: Infinitely
4. TIDAL VOLUME; Adjustable50-2000 ml
5. FLOW Control; 0.25 -1L /sec
6. FREQUENCY; From -10 K) 10 - 85 b/min
7. INFLATION PRESSURE Monitor; 100 cm H20
8. INSPIRATORY REUEF PRESSURE; At 60 cm H20
1. Metal Adult Patient Valve
2. Input Hose
1. Pena PAC ALARM SYSTEM: A High and Low Pressure (Disconnect)
Alarm Monitor with Audible and Visual Indication.
2. JACKSON REES
3. NEWTON VALVE; For Neonatal Anesthesia CONVERTING the Ventilator
From FLOW GENERATOR TO PRESSURE GENERATOR
4. Metal Bain Adaptor •with B«in Circuit
5. Consumable Bain Adaptor & Circuit
منتظر ردودكم فى اقرب فرصة
اخوكم دكتور هاكر
