ماذا تعرف عن ال Hammering؟
النتائج 1 إلى 10 من 15
    chopin
    chopin غير متواجد حالياً
    السؤال
    ما هي؟
    اسبابها؟
    نتائجها؟
    علاجها؟
    نرجو من الجميع المشاركة
    waadmazag
    waadmazag غير متواجد حالياً
    Post Hammering
    Hammering normally occurs when both condensate and steam are flowing in the same pipe. There are two types of hammering that could happen in steam systems: 1) steam hammering 2) water hammering. Steam hammering is caused by the creation of the cool area located in the pipes containing saturated steam. This creates slugs of water and low pressure areas along the way which will cause the slugs of water to move very fast to those low pressure areas creating vibration or noise (hammering) whenever come across an elbow or T-shape pipe.
    Water hammering is usually caused by condensate accumulation in a pipe that is usually the output of a heating unit. The flowing of the steam thorough the accumulated condensate in such a pipe causes ripples in the water leading to turbulence builds up until the water forms solid masses. These solid masses are driven by the velocity of the steam and it can cause hammering in it two ways as following:
    1) As the solid masses of water and the steam strike the first elbow hammering will begin.
    2) If the solid masses of water and the steam out of the heat exchange unit are introduced to a flash drum that contains relatively cold water, bubbles flowing along with the steam will implode and cause water hammering.
    h
    نمواذا تبغى تتعلم زياده جرب الويب سايتات هاذي
    http://www.steamspecialist.com/doe.htm
    http://www.engtips.com/gviewthread.c.../391/qid/10094
    http://www.bellgossett.com/Press/good.htm
    http://www.hanford.gov/lessons/sitell/ll96/96i062.txt
    Eng.Foam
    Eng.Foam غير متواجد حالياً
    شكرا جزيلاً
    شكراً جزيلا
    sultan0064
    sultan0064 غير متواجد حالياً
    مشكور وجزاك الله عنا كل خير وبارك الله فيك معلومات مهمه
    REACTOR
    REACTOR غير متواجد حالياً
    الصورة الرمزية REACTOR
    Given: 4
    الاجابة الموجودة هي جزئية فظاهرة Hammering و تسمى الطرق و تظهر في المضخات في حالة وجود غاز مصاحب للسائل الذي يتم ضخة و هي تسبب ضرر كبير لجسم المضخة الداخلي و الريش مع الوقت بالاضافة لنقص الكفاءة اما اسبابها فقال احدهم الاخ waadmazag و هي و جود البخار مع السائل و ان كان هذه حالة خاصة اما السبب الرئيس فهو ان ضغط السحب اكبر من الضغط البخاري للسائل مما يتبب في حالة تمزق للسائل (( بالبلدي المضخة بتشد و السائل مش قادر يتحرك بنفس قدرة المضخة على الشد)) فيتبخر جزء من السائل مسببة ظاهرة الطرق
    إن حقائق اليوم هي أحلام الأمس , و أحلام اليوم هي حقائق الغد
    محمد الاكرم
    محمد الاكرم غير متواجد حالياً
    الصورة الرمزية محمد الاكرم
    Received: 617
    Given: 999
    LIALY
    LIALY غير متواجد حالياً
    الصورة الرمزية LIALY
    مشكوووووووووورين و شكرااااااااااااااا جزيلا Reactor على التوضيح
    REACTOR
    Given: 4
    و اياكم ........:)
    اخونا محمد الاكرم وضع ملف جميل جدا و هو اول رابط بة شرح وافي و ايضا طرق المعالجة لهذه الظاهرة و الصراحة من اراد الاستفادة انزال هذه الملفات و سارفق بعد اذن الاخ الرابط الاول
    و شكرا جزيلا مرة اخرى
    محمد الاكرم
    Received: 617
    Given: 999
    اقتباس المشاركة الأصلية كتبت بواسطة reactor مشاهدة المشاركة
    و اياكم ........:)
    شـكــ وبارك الله فيك ـــرا لك ... لك مني اخلص تحية
    محمد الاكرم
    Received: 617
    Given: 999
    شـكــ وبارك الله فيكم ـــرا لك ... لكم مني أجمل تحية .
