تشطيبات الارضيات
النتائج 1 إلى 3 من 3
    .ahmed
    .ahmed غير متواجد حالياً
    تشطيبات الارضيات
    عاجل جدااااااااااااااااااا
    ارجو المساعدة فى تشطيبات المختلفة للارضيات فى الفنادق
    من مواضيع .ahmed :
    moshehawy
    moshehawy غير متواجد حالياً
    أرضيات الرخام الإيبوكسى
    أصدقائى الأعزاء
    أرجو من سيادتكم جميعا زيارة الرابط التالى للإطلاع على أحدث أنشطتى كما أرجو منكم مساعدتى بإمدادى بآرائكم البناءة و النصح إن وجد فأنتم خيرة أصدقائى و أنتم فقط من أثق فى حبهم لى والحرص على مصالحى
    http://egyptinteriors.com/companydet...0-68569b3e6805
    [LEFT]Dear Friends
    It's so much honor for me to introduce my new innovative flooring system B&B EPOXY MARBLE.
    I'm Chemist / Mohamed Abdel Fattah Shehawy ( 15 years experience in the field of protective and industrial coatings ) used to work for some of the leading Egyptian coatings companies but now I'm starting my own company ( B&B Coatings ) which is specialized in the protective and industrial coatings for steel and concrete and I'd like to introduce my new innovative flooring system B&B EPOXY MARBLE.
    Description
    B&B Epoxy Marble system offers excellent protection to concrete floorings and highly attractive marble shape performance. B&B Epoxy Marble is a multi‐component,
    decorative, multi-colored, seamless, high build epoxy flooring system that consists of :
    1‐ Epoxy Polyamide Cured Primer (Sealing Coat).
    2- Pigmented Epoxy Polyamine Cured Coating (Basecoat).
    3- Special types of flakes (Colored Flakes).
    4- Epoxy Polyamine Cured Clear Coat (Finish Coat).
    Area of Application
    • Hotels' lobby.
    • Megastores and Showrooms.
    • Warehouses and Factories.
    • Hospitals and Laboratories.
    • Public Garages and Parking.
    • Villas & Apartments (Receptions, Kitchens and Bathrooms).
    • Food Processing Plants and Laundries.
    Please find attached the technical data sheet including some samples.
    I wish my innovations to satisfy you and be one of your options when designing flooring systems for your new projects
    With my best regards
    B&B Coatings
    General Manager
    0124745467 (002)
    [email protected]
    هاوي تخطيط
    هاوي تخطيط غير متواجد حالياً
    هذه بعض المواضيع اتمنى ان تستفيد منها
    http://www.arab-eng.org/vb/t170543.html
    http://www.arab-eng.org/vb/t173853.html
    http://www.arab-eng.org/vb/t170475.html
    http://www.arab-eng.org/vb/search.ph...1&pp=25&page=2
    كما ان هناك ملف في المرفقات عن كل مايتعلق بالتشطيبات
    لك تحياتي وتقديري
