مساعده في ترجمه هذه الفقره
النتائج 1 إلى 2 من 2
    dema
    dema غير متواجد حالياً
    In traditional approach, engineer have to wait long to understand the major factors that cause the defects and finally control it. In this work, a fuzzy system approach will be used to minimize the convexity, crack, impurities and surface defects. Providing the most important factors controlling the process are known. Using fuzzy subtractive clustering based system identification and Sugeno type fuzzy inference system are used to model the defects of the ceramic tiles in three the stages of production (preparation, pressing, and firing) to develop a better understanding of the effect of each stage factors on the quality of the produced ceramic tiles. Tile production data will be collected for the preparation stage, pressing stage, and firing stage. Therefore, in the first stage viscosity, fineness, density, and milling hour, in the second stage Tile temperature, tile moisture, and tile thickness, and in the third stage humidity, width shrinkage, water absorption will be considered. All the previously mentioned factors will be identified as input data while Defects of the ceramic tile are the output of the process. The model building process will be carried out by using fuzzy subtracting clustering based system identification in both input and output space. The developed fuzzy logic model can be used to predict the influence of a given set of inputs on the value of specific defect. The model is verified by using further experimentation different sets of inputs. This study deals with the experimental results that obtained during ceramic tile production in International Ceramic Industrial Company.
    i need this paregraph in arabic as anyone know the scientific word as possible as u can..thank for help
    نورالاسراء
    نورالاسراء غير متواجد حالياً
    ترجمتلك هذه الفقره بالقاموس اتمنى من انى اقدرت انساعدك :-
    في النهج التقليدي للمهندس يكون الانتظار طويلا لفهم العوامل الرئيسية التي تسبب عيوب وأخيرا السيطرة عليه.في هذا العمل ، ضبابي نهج النظام ستستخدم لتقليل التحدب كراك والشوائب والعيوب السطحيه.تقديم اهم عوامل السيطرة على العملية معروفة.استعمال المبهم مطروح التجمع الى نظام تحديد نوع مبهم سوغينو الاستدلال النظام تستخدم نموذج عيوب الخزف في ثلاث مراحل الانتاج (أعدادالضغط ،واطلاق النار على تطوير فهم افضل لأثر كل مرحلة على عوامل نوعية في انتاج السيراميك.انتاج البلاط وسيتم جمع البيانات من اجل اعداد المرحلة ، مرحلة الضغط ومرحلة اطلاق النار.لذا ، في المرحلة الأولى ، اللزوجه والكثافة والدقه والطحن ساعة في المرحلة الثانية بلاطة الحراره والرطوبه وبلاطوالبلاط ، وسماكه في المرحلة الثالثة الرطوبه عرض انحسار المياه استيعاب المقبلين.جميع العوامل المذكورة سابقا يتم تحديد مدخلات البيانات وعيوب بلاط السيراميك هي حصيله العملية.بناء النموذج وسوف تنفذ عملية باستخدام مبهم طرح التجمع الى تعريف النظام في كل المدخلات والمخرجات الفضاء.المنطق المبهم في تطوير نموذج يمكن استخدامه لتوقع تأثير معين على مجموعة من المساهمات القيمه المحددة من عيب.النموذج هو التحقق من استعمال اكثر التجريب مجموعات مختلفة من المدخلات.هذه الدراسه تتناول نتائج التجارب التي حصلت خلال انتاج بلاط السيراميك في شركة الخزف الصناعي.
    وهذا القاموس حتى تتاكد من الترجمه:-
    http://www.google.com/translate_t
    مولاى صل وسلم دائما ابدا على حبيبك خير الخلق كلهم
