Prosteel_3d_v17.1_for_autocad-xforce
النتائج 1 إلى 2 من 2
    أهل الحديث
    أهل الحديث غير متواجد حالياً
    Received: 206
    Given: 261
    Non-Modal Dialog Boxes
    This translates into simplicity for you the user. Interfacing with the program is easy and every entered value within a dialog box is immediately visible at the design part. You can also view the model from a variety of different views without having to cancel the command
    * Open Database Structures
    All shape, plate, and bolt parameters used by ProSteel 3D are posted in databases that can be freely edited and expanded by the user. This makes it easy to add any desired intermediate size or even entire shape catalogues (e.g., non-European standards) to the existing shape databases.
    It is even possible to assign any individual shape series to several different databases, e.g., defining different selection tables for each shape type in case of splice joints
    Direct link from our server
    http://yofreespace.com/download.php?id=E121A308
    http://rapidshare.com/files/4015006/...CAD-XFORCE.rar
    Pass : www.yoknall.com
    asad4444
    asad4444 غير متواجد حالياً
    ارجو توضيح كيف يتم تنزيل البرنامج من الرابط اعلاه
    ولك جزيل الشكر
    MEng. As'ad
